11-14-2013 03:10 PM - edited 03-16-2019 08:25 PM
hi,
I have meetme working just fine.
I want so that when the organizer hangs up that all calls disconnect from that meetme.
any way?
does this same thing apply also to ad-hoc conf call?
thanks.
11-14-2013 03:36 PM
No, the meet-me doesn't go down unless everyone drops the calls.
The parameter to keep conferences if the initiator drops, or to drop it if he drops the call, are for ad-hoc
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
11-14-2013 06:02 PM
all right can you tell me the parameter for ad-hoc?
also, any way to setup a password in meetme?
or any way to close the meetme so that no one else can jump into the meetme conferance?
thanks.
11-14-2013 07:00 PM
Meet me and pwd has been discussed thousands of times before, no, alternatives can be found on previous CSC threads
Sent from Cisco Technical Support Android App
