02-07-2013 10:08 AM - edited 03-16-2019 03:35 PM
Is there anyway a voice message left in unity can be sent out on email with the actual message transcriped onto the email not just the standard message left by the unity connection messaging system?
02-07-2013 10:17 AM
You can receive a message using your outlook , based on the integration between cisco unity connection and microsoft outlook . The message will include the file in .wav file .
thank you
02-07-2013 11:07 AM
Actually it depends on what you are specifically asking for. If you mean transcribed as in the voice recording is converted to text and sent as an email that is different than simply receiving a voice message as an attachment in an email client.
Hailey
Rate helpful posts!
02-07-2013 01:21 PM
Yes I noticed in unity (after I posted)that there is an option for send transcriptions of voice messages but its grey out on my unity. I have asked my unity guru why this is, awaiting an answer.
02-07-2013 01:23 PM
The transcription option is a subscription service - presumably you have not subscribed/paid for it.
Aaron
02-07-2013 01:30 PM
You would need to purchase a TTS (Text-to-Speech) server and Cisco "LicRealspeakSessionsMax" licenses. Than you would configure Unity to communicate with the TTS server. A known Cisco supported TTS server vendor is Nuance.
Yosh
02-07-2013 01:34 PM
Thanks everybody for your quick responses.
