MGCP and H323 dial peer conflicts?
r.earle
We have a strange problem with a couple BRIs answering calls. We have MGCP and are trying to migrate to H323. Recently we tested this and the calls seemed to work but stopped all of a sudden and no longer ring back or hear any voice. These are inbound only since for outbound calls we use a PRI offsite. Since the problem occured we have configured only 1 port to use H323 but everytimea call comes in on this port the dial peer voip matches but doesn´t answer and the next BRI interface rings from the Telcos hunt this one picks up the call through MGCP and now we have both BRIs in use on one channel each. Here is the config and hope that made sense.
We are only using BRI 1/1/0 to test h323 at this point. While testing a call I see my call coming in and being answered and then hunting through channels and ultimately being pickup up by a MGCP managed port. I configured the gateway as H323 on callmanager and it did work at some`point.
version 12.4
service timestamps debug uptime
service timestamps log datetime localtime
service password-encryption
hostname C2821
boot-start-marker
boot-end-marker
logging buffered 4096
enable secret
no aaa new-model
clock timezone MAD 1
no network-clock-participate slot 1
network-clock-participate wic 1
network-clock-participate wic 2
network-clock-participate wic 3
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.24.5.1 192.24.5.9
ip dhcp pool Telefonia
   network 192.24.5.0 255.255.255.0
   domain-name arconet.net
   option 150 ip 192.25.98.10
   default-router 192.24.5.1
no ip domain lookup
ip domain name arconet.net
isdn switch-type basic-net3
voice-card 0
dspfarm
dsp services dspfarm
voice-card 1
no dspfarm
voice dsp slot 0 command history enable
voice class h323 1
h225 timeout tcp establish 3
application
  global
  service alternate default
archive
log config
  hidekeys
class-map match-any Limit_Rate
match ip precedence 0  1  2  3
match ip precedence 4  5  6  7
class-map match-any Adv_Bronze_Silver_Gold
match access-group 120
class-map match-any Adv_Platinum
match access-group 110
match ip precedence 5
class-map match-any Adv_Control
match ip precedence 6
match ip precedence 6  7
policy-map <Advanced_OUT>
class Adv_Platinum
    police 1152000 4470 4470 conform-action transmit  exceed-action drop
  priority 1152
class Adv_Bronze_Silver_Gold
  bandwidth 2624
    police 3776000 47200 47200 conform-action transmit  exceed-action drop
class Adv_Control
    police 64000 8000 8000 conform-action transmit  exceed-action drop
  bandwidth 32
policy-map <Advanced_MC_IN_A+C>
class Adv_Platinum
  set ip precedence 5
  set ip precedence 2
policy-map Limit_Rate_<Advanced_OUT>
class Limit_Rate
  shape average 3810000
  service-policy <Advanced_OUT>
interface Loopback0
ip address 10.1.1.35 255.255.255.255
interface Loopback1
ip address 10.254.2.41 255.255.255.255
interface Multilink1
description ACCESO POS: AGREGACION 2xE1
ip address 10.120.30.222 255.255.255.252
ip virtual-reassembly
no cdp enable
ppp multilink
ppp multilink group 1
ppp multilink multiclass
service-policy output Limit_Rate_<Advanced_OUT>
interface GigabitEthernet0/0
no ip address
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/0.10
encapsulation dot1Q 10
ip address 10.192.5.2 255.255.255.248
no cdp enable
service-policy input <Advanced_MC_IN_A+C>
interface GigabitEthernet0/0.11
encapsulation dot1Q 11
ip address 10.192.5.9 255.255.255.248
no cdp enable
interface GigabitEthernet0/0.20
description Telefonia Susme
encapsulation dot1Q 20
ip address 192.24.5.1 255.255.255.0
h323-gateway voip interface
h323-gateway voip h323-id C2821-DTMSEVPR2
h323-gateway voip bind srcaddr 192.24.5.1
interface GigabitEthernet0/1
no ip address
ip nat outside
shutdown
duplex auto
speed auto
interface BRI0/1/0
no ip address
isdn point-to-point-setup
isdn incoming-voice voice
isdn bind-l3 ccm-manager service mgcp
isdn static-tei 0
interface BRI0/1/1
no ip address
isdn static-tei 0
interface BRI0/2/0
no ip address
isdn static-tei 0
interface BRI0/2/1
no ip address
isdn static-tei 0
interface BRI0/3/0
no ip address
isdn static-tei 0
interface BRI0/3/1
no ip address
isdn static-tei 0
interface BRI1/0/0
no ip address
isdn static-tei 0
interface BRI1/0/1
description SIN SERVICIO
no ip address
shutdown
isdn static-tei 0
interface BRI1/1/0
no ip address
isdn static-tei 0
interface BRI1/1/1
no ip address
isdn static-tei 0
ip local policy route-map Local_Traffic
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.192.5.1
no ip http server
no ip http secure-server
logging source-interface Loopback1
logging 10.25.97.200
access-list 1 permit 10.25.97.200
access-list 110 permit ip any 192.25.98.0 0.0.0.255
access-list 110 permit ip any 192.24.0.0 0.0.255.255
access-list 120 deny   ip any 192.24.0.0 0.0.255.255
access-list 120 deny   ip any 192.25.98.0 0.0.0.255
access-list 120 permit ip any any
access-list 160 permit ip 192.25.5.0 0.0.0.255 172.26.1.0 0.0.0.255
access-list 160 permit ip 192.25.5.0 0.0.0.255 172.27.225.0 0.0.0.255
access-list 160 permit ip 192.25.5.0 0.0.0.255 172.27.226.0 0.0.0.255
access-list 160 deny   ip any any
snmp-server community xxx RO 1
snmp-server community xxx RW 1
snmp-server trap-source Multilink1
snmp-server source-interface informs Multilink1
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps vrrp
snmp-server enable traps ds1
snmp-server enable traps tty
snmp-server enable traps eigrp
snmp-server enable traps xgcp
snmp-server enable traps flash insertion removal
snmp-server enable traps ds3
snmp-server enable traps envmon
snmp-server enable traps icsudsu
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps isdn chan-not-avail
snmp-server enable traps isdn ietf
snmp-server enable traps ds0-busyout
snmp-server enable traps ds1-loopback
snmp-server enable traps ethernet cfm cc mep-up mep-down cross-connect loop config
snmp-server enable traps ethernet cfm crosscheck mep-missing mep-unknown service-up
snmp-server enable traps disassociate
snmp-server enable traps deauthenticate
snmp-server enable traps authenticate-fail
snmp-server enable traps dot11-qos
snmp-server enable traps switch-over
snmp-server enable traps rogue-ap
snmp-server enable traps wlan-wep
snmp-server enable traps atm subif
snmp-server enable traps bgp
snmp-server enable traps bulkstat collection transfer
snmp-server enable traps memory bufferpeak
snmp-server enable traps cnpd
snmp-server enable traps config-copy
snmp-server enable traps dial
snmp-server enable traps dsp card-status
snmp-server enable traps dsp oper-state
snmp-server enable traps entity
snmp-server enable traps fru-ctrl
snmp-server enable traps resource-policy
snmp-server enable traps event-manager
snmp-server enable traps frame-relay multilink bundle-mismatch
snmp-server enable traps frame-relay subif
snmp-server enable traps hsrp
snmp-server enable traps ipmulticast
snmp-server enable traps mpls ldp
snmp-server enable traps mpls traffic-eng
snmp-server enable traps mpls vpn
snmp-server enable traps msdp
snmp-server enable traps mvpn
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface-old
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps pppoe
snmp-server enable traps cpu threshold
snmp-server enable traps rsvp
snmp-server enable traps ipsla
snmp-server enable traps syslog
snmp-server enable traps l2tun session
snmp-server enable traps l2tun pseudowire status
snmp-server enable traps vsimaster
snmp-server enable traps vtp
snmp-server enable traps pw vc
snmp-server enable traps ccme
snmp-server enable traps srst
snmp-server enable traps voice
snmp-server enable traps dnis
snmp-server host 10.25.97.200 version 2c
route-map natgde permit 10
match ip address 160
route-map Local_Traffic permit 10
set ip precedence internet
control-plane
voice-port 0/0/0
echo-cancel coverage 24
cptone C1
timing hookflash-out 500
impedance complex2
voice-port 0/0/1
voice-port 0/1/0
input gain 6
output attenuation -2
compand-type a-law
cptone C1
voice-port 0/1/1
input gain 6
compand-type a-law
cptone C1
voice-port 0/2/0
input gain 6
compand-type a-law
cptone C1
voice-port 0/2/1
input gain 6
compand-type a-law
cptone C1
voice-port 0/3/0
input gain 6
compand-type a-law
cptone C1
voice-port 0/3/1
input gain 6
compand-type a-law
cptone C1
voice-port 1/0/0
input gain 4
compand-type a-law
cptone C1
voice-port 1/0/1
cptone C1
voice-port 1/1/0
input gain 6
compand-type a-law
cptone C1
voice-port 1/1/1
input gain 6
compand-type a-law
cptone C1
ccm-manager fallback-mgcp
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 192.25.98.10
ccm-manager config
ccm-manager download-tones
mgcp
mgcp call-agent 192.25.98.10 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip codec g711alaw
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0.20
mgcp bind media source-interface GigabitEthernet0/0.20
mgcp profile default
dial-peer voice 10 pots
incoming called-number 95.......
direct-inward-dial
port 0/2/0
dial-peer voice 11 pots
preference 1
direct-inward-dial
port 0/2/1
dial-peer voice 12 pots
preference 1
direct-inward-dial
port 0/3/0
dial-peer voice 13 pots
direct-inward-dial
port 0/3/1
dial-peer voice 20 pots
destination-pattern 9[1-9].......
no digit-strip
port 0/2/0
dial-peer voice 21 pots
preference 3
no digit-strip
port 0/3/0
dial-peer voice 22 pots
preference 4
destination-pattern 6........
no digit-strip
port 0/3/1
dial-peer voice 16 pots
destination-pattern 95.......
direct-inward-dial
port 1/1/0
dial-peer voice 999000 pots
service mgcpapp
port 0/0/0
dial-peer voice 955 voip
huntstop
session target ipv4:192.25.98.10
dtmf-relay h245-signal
dial-peer voice 14 pots
preference 1
direct-inward-dial
port 1/1/1
dial-peer voice 17 pots
preference 1
shutdown
direct-inward-dial
port 0/1/0
dial-peer voice 18 pots
shutdown
direct-inward-dial
port 0/1/1
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
limit-dn 7910 2
limit-dn 7940 4
limit-dn 7960 4
ip source-address 192.24.5.1 port 2000 strict-match
max-ephones 48
max-dn 72 dual-line preference 1
system message primary Sistema de Supervivencia
system message secondary Serv supervivencia
keepalive 60
no huntstop
alias 1 95xxxx to 1418
time-format 24
date-format dd-mm-yy
line con 0
password xxx
login
line aux 0
line vty 0 4
password xxx
login local
scheduler allocate 20000 1000
ntp clock-period 17179937
ntp update-calendar
ntp server 10.120.1.26
end
These are not two separate calls I monitor this while testing and it always answers after matching dial peer 955 voip but  nothing happens then the next port in the telcos hunt picks up the call while the incoming port remains active.
C2821-DTMSEVPR2#show voice call stat
CallID     CID  ccVdb      Port             DSP/Ch  Called #   Codec    Dial-peers
0xA95      16F4 0x47319490 1/1/0.1          1/1:1   95XXXXXXX  g729r8    10/955
0xA97      16F5 0x46B67B64 0/3/1.0          0/1:1  *           g729r8    0/0
2 active calls found
Thanks in advance for any help.
Ron
8 Replies 8
dksingh
Hmm...interesting....
I don't like that we are hitting dialpeer 10 on the inbound just cuz
it is pointing to a mgcp controlled BRI. May not be anything...
Can u make the incoming called-num on dialpeer 16 more specific/
explicit next time u test it and capture following debugs for one test call:
deb isdn q931
deb voip ccapi inout
deb mgcp pack
Pl. include....
sh isdn stat
sh mgcp end
Pl. specify calling and called number for the capture.
Thx.
DK
The incoming called number is 955658800 and the calling number is 607345209. Here is the debugs the call is answered on port 1/1/0. I did not have incoming called number on dial-peer 16 just destination pattern. EDIT: I did configure the incoming called number to be more specific and it does match dial peer 16/955 instead of 10 but I still don´t get voice until the MGCP controlled port picksup.
2d21h: ISDN BR1/1/0 Q931: RX <- SETUP pd = 8  callref = 0x10
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x89
                Exclusive, B1
        Calling Party Number i = 0x0183, '607345209'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0xA1, '955658800'
                Plan:ISDN, Type:National
2d21h: //-1/69DB20CF8580/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=607345209
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=955658800
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
2d21h: //-1/69DB20CF8580/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x47319490, Call Info(
   Calling Number=607345209,(Calling Name=)(TON=Unknown, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=955658800(TON=National, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=10, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
2d21h: //-1/69DB20CF8580/CCAPI/ccCheckClipClir:
   In: Calling Number=607345209(TON=Unknown, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Out: Calling Number=607345209(TON=Unknown, NPI=ISDN, Screening=Network, Presentation=Allowed)
2d21h: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
2d21h: :cc_get_feature_vsa malloc success
2d21h:  cc_get_feature_vsa count is 1
2d21h: :FEATURE_VSA attributes are: feature_name:0,feature_time:1189239000,feature_id:2923
2d21h: //2923/69DB20CF8580/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=607345209(TON=Unknown, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=955658800(TON=National, NPI=ISDN))
2d21h: //2923/69DB20CF8580/CCAPI/cc_process_call_setup_ind:
   Event=0x46B07CE8
2d21h: //2923/69DB20CF8580/CCAPI/ccCallSetContext:
   Context=0x490F402C
   >>>>CCAPI handed cid 2923 with tag 10 to app "_ManagedAppProcess_Default"
2d21h: //2923/69DB20CF8580/CCAPI/ccCallProceeding:
2d21h: //2923/69DB20CF8580/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=955, Params=0x490F1514, Progress Indication=NULL(0)
2d21h: //2923/69DB20CF8580/CCAPI/ccCheckClipClir:
   Destination Pattern=955658..., Called Number=955658800, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=69DB20CF-E00D-11DF-8580-001E13CE2E20, Outgoing Dial-peer=955
2d21h: //2923/69DB20CF8580/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=607345209
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=955658800
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
2d21h: //2923/69DB20CF8580/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x46FAB490, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=607345209,(Calling Name=)(TON=Unknown, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=955658800(TON=National, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=955, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
2d21h:  cc_get_feature_vsa count is 2
2d21h: :FEATURE_VSA attributes are: feature_name:0,feature_time:1189237920,feature_id:2924
2d21h: //2924/69DB20CF8580/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
2d21h: //2924/69DB20CF8580/CCAPI/ccCallSetContext:
   Context=0x490F14C4
2d21h: //2923/69DB20CF8580/CCAPI/ccSaveDialpeerTag:
2d21h: ISDN BR1/1/0 Q931: TX -> CALL_PROC pd = 8  callref = 0x90
        Channel ID i = 0x89
                Exclusive, B1show voice call stat
0xB6B      175F 0x47319490 1/1/0.1          1/1:1   955658800  None      10/955
1 active call found
C2821-DTMSEVPR2#
2d21h: //2924/69DB20CF8580/CCAPI/cc_api_set_called_ccm_detected:
   CallInfo(called ccm detected=TRUE ccmVersion 3)
2d21h: //2924/69DB20CF8580/CCAPI/cc_api_call_proceeding:
   Interface=0x46FAB490, Progress Indication=NULL(0)
2d21h: ISDN BR0/3/1 Q931: RX <- SETUP pd = 8  callref = 0x29
        Sending Complete
                Standard = CCITT
        Channel ID i = 0x89
                Exclusive, B1
        Calling Party Number i = 0x0181, '956182122'
2d21h: MGCP Packet received from 192.25.98.10:2427--->
CRCX 11171824 BRI/S0/SU3/P1/1@C2821-DTMSEVPR2.arconet.net MGCP 0.1
C: D0000000013fedae000000F580000029
L: p:30, a:G.729, s:off, t:b8
M: recvonly
2d21h: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x46B67B64, Interface Type=6, Destination=, Mode=0x9,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=D0000000013fedae000000F580000029)
2d21h:  cc_get_feature_vsa count is 3
2d21h: :FEATURE_VSA attributes are: feature_name:0,feature_time:1189236840,feature_id:2925
2d21h: //2925/6B32C3078581/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
2d21h: //2925/6B32C3078581/CCAPI/ccCallSetContext:
   Context=0x47DE0378
   Interface=0x46A564B4, Interface Type=9, Destination=0.0.0.0, Mode=0x9,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=TRUE,
2d21h:  cc_get_feature_vsa count is 4
2d21h: :FEATURE_VSA attributes are: feature_name:0,feature_time:1189239432,feature_id:2926
2d21h: //2926/6B32C3078581/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
2d21h: //2926/6B32C3078581/CCAPI/ccCallSetContext:
   Context=0x47DDFDF8
2d21h: //2926/6B32C3078581/CCAPI/cc_api_call_connected:
   Interface=0x46A564B4, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
2d21h: //2925/6B32C3078581/CCAPI/cc_api_call_proceeding:
   Interface=0x46B67B64, Progress Indication=NULL(0)
2d21h: //2925/6B32C3078581/CCAPI/cc_api_call_connected:
   Interface=0x46B67B64, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
   Connection Handle=0
2d21h: //2925/6B32C3078581/CCAPI/ccCallModify:
   Nominator=0x1000, Params=0x493ED940, Call Id=2925
2d21h: //2925/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0xB6D, digit_event=0x1, enable=TRUE, consume=FALSE)
2d21h: //2925/6B32C3078581/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=2925
2d21h: //2925/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x46B67B64, callID=0xB6D, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
2d21h: //2925/6B32C3078581/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x46B67B64, Call Id=2925
   Call Entry(Initial Digit Timeout=10000(ms), Inter Digit Timeout=10000(ms))
2d21h: //2925/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x493EDAE4, callID1=0xB6D, callID2=0xB6E, tag=0x0)
2d21h: //2925/6B32C3078581/CCAPI/ccConferenceCreate:
   Conference Id=0x493EDAE4, Call Id1=2925, Call Id2=2926, Tag=0x0
2d21h: //2925/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x51C, Source Interface=0x46B67B64, Source Call Id=2925,
   Destination Call Id=2926, Disposition=0x0, Tag=0xFFFFFFFF
2d21h: //2926/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x51C, Source Interface=0x46A564B4, Source Call Id=2926,
   Destination Call Id=2925, Disposition=0x0, Tag=0x0
2d21h: //2925/6B32C3078581/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x51C, Destination Call Id=2926)
2d21h: //2926/6B32C3078581/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x51C, Destination Call Id=2925)
2d21h: //2925/6B32C3078581/CCAPI/cc_api_caps_ind:
   Destination Interface=0x46A564B4, Destination Call Id=2926, Source Call Id=2925,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=200(ms), Fax Nom=300(ms))
2d21h: //2926/6B32C3078581/CCAPI/cc_api_caps_ind:
   Destination Interface=0x46B67B64, Destination Call Id=2925, Source Call Id=2926,
   Caps(Codec=0x4, Fax Rate=0x2, Vad=0x1,
   Modem=0x2, Codec Bytes=30, Signal Type=2)
   Playout Max=250(ms), Fax Nom=300(ms))
2d21h: //2926/6B32C3078581/CCAPI/cc_api_caps_ack:
   Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=30, Signal Type=2, Seq Num Start=9867)
2d21h: //2925/6B32C3078581/CCAPI/cc_api_caps_ack:
2d21h: //2925/6B32C3078581/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x46B67B64, Call Id=2925
2d21h: //2925/6B32C3078581/CCAPI/cc_api_voice_mode_event:
   Call Id=2925
   Call Entry(Context=0x47DE0378)
2d21h: //2925/6B32C3078581/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x51C, Call Id1=2925, Call Id2=2926
2d21h: MGCP Packet sent to 192.25.98.10:2427--->
200 11171824 OK
I: 67
v=0
c=IN IP4 192.24.5.1
m=audio 17618 RTP/AVP 18 100
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194,200-202
a=X-sqn:0
a=X-cap: 1 audio RTP/AVP 100
a=X-cpar: a=rtpmap:100 X-NSE/8000
a=X-cpar: a=fmtp:100 192-194,200-202
a=X-cap: 2 image udptl t38
2d21h: ISDN BR0/3/1 Q931: TX -> CALL_PROC pd = 8  callref = 0xA9
        Channel ID i = 0x89
                Exclusive, B1
RQNT 11171825 BRI/S0/SU3/P1/1@C2821-DTMSEVPR2.arconet.net MGCP 0.1
X: 1
R: D/[0-9ABCD*#]
S: G/rt
Q: process,loop
2d21h: //2925/6B32C3078581/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms)
   Call Entry(Inter Digit Timeout=4000(ms), Initial Digit Timeout=4000(ms))
2d21h: //2925/6B32C3078581/CCAPI/ccRestartDigitTimeoutMsec:
   Digit Timeout=0, Call Id=2925
   Call Entry(Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms))
   Nominator=0x1000, Params=0x493ED320, Call Id=2925
2d21h: //2925/6B32C3078581/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Ring Back,
   Tone Direction=Network, Params=0x0, Call Id=2925
200 11171825 OK
MDCX 11171826 BRI/S0/SU3/P1/1@C2821-DTMSEVPR2.arconet.net MGCP 0.1
I: 67
X: 1
M: sendrecv
R: D/[0-9ABCD*#]
S:
Q: process,loop
v=0
o=- 103 0 IN EPN BRI/S0/SU3/P1/1@C2821-DTMSEVPR2.arconet.net
s=Cisco SDP 0
t=0 0
m=audio 26736 RTP/AVP 18
c=IN IP4 192.25.98.8
   Stop Tone On Digit=FALSE, Tone=Null,
2d21h: //2925/6B32C3078581/CCAPI/ccCallModifyExtended:
   Nominator=0x493ED678, Params=0x493ECB18, Call Id=2925
2d21h: //2926/6B32C3078581/CCAPI/ccCallModify:
   Nominator=0x18E30, Params=0x493ECCA8, Call Id=2926
2d21h: //2926/6B32C3078581/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x46A564B4, Call Id=2926
200 11171826 OK
2d21h: ISDN BR0/3/1 Q931: TX -> ALERTING pd = 8  callref = 0xA9
        Progress Ind i = 0x8088 - In-band info or appropriate now available
2d21h: ISDN BR0/3/1 Q931: TX -> CONNECT pd = 8  callref = 0xA9
2d21h: ISDN BR0/3/1 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x29
2d21h: //2924/69DB20CF8580/CCAPI/cc_api_call_cut_progress:
   Interface=0x46FAB490, Progress Indication=NOT END TO END ISDN(1), Signal Indication=SIGNAL RINGBACK(1),
   Cause Value=0
   Call Entry(Responsed=TRUE)
2d21h: //2923/69DB20CF8580/CCAPI/ccCallCutProgress:
   Progress Indication=NOT END TO END ISDN(1), Signal Indication=SIGNAL RINGBACK(1), Cause Value=0
   Voice Call Send Alert=FALSE, Call Entry(AlertSent=FALSE)
2d21h: //2923/69DB20CF8580/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=2923
2d21h: //2923/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x491B1CC0, callID1=0xB6B, callID2=0xB6C, tag=0x0)
2d21h: //2923/69DB20CF8580/CCAPI/ccConferenceCreate:
   Conference Id=0x491B1CC0, Call Id1=2923, Call Id2=2924, Tag=0x0
2d21h: //2923/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x51D, Source Interface=0x47319490, Source Call Id=2923,
   Destination Call Id=2924, Disposition=0x0, Tag=0xFFFFFFFF
2d21h: //2924/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
2d21h: cc_api_get_xcode_stream : 4369
2d21h: //2924/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x51D, Source Interface=0x46FAB490, Source Call Id=2924,
   Destination Call Id=2923, Disposition=0x0, Tag=0x0
2d21h: //2923/69DB20CF8580/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x51D, Destination Call Id=2924)
2d21h: //2924/69DB20CF8580/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x51D, Destination Call Id=2923)
2d21h: //2923/69DB20CF8580/CCAPI/cc_api_caps_ind:
   Destination Interface=0x46FAB490, Destination Call Id=2924, Source Call Id=2923,
2d21h: //2923/69DB20CF8580/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x51D, Call Id1=2923, Call Id2=2924
2d21h: ISDN BR1/1/0 Q931: TX -> PROGRESS pd = 8  callref = 0x90
        Progress Ind i = 0x8181 - Call not end-to-end ISDN, may have in-band info
2d21h: //2924/69DB20CF8580/CCAPI/cc_api_call_alert:
   Interface=0x46FAB490, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
2d21h: //2924/69DB20CF8580/CCAPI/cc_api_call_notify:
   Data Bitmask=0x5, Interface=0x46FAB490, Call Id=2924
2d21h: //2923/69DB20CF8580/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, AlertSent=TRUE)
2d21h: ISDN BR1/1/0 Q931: TX -> ALERTING pd = 8  callref = 0x90
        Progress Ind i = 0x8188 - In-band info or appropriate now available
2d21h: //2924/69DB20CF8580/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
   CallInfo(ssCTreRoutingNotSupported=FALSE)
2d21h: //2924/69DB20CF8580/CCAPI/cc_api_get_ccm_detected:
   CallInfo(ccm detected=TRUE)
2d21h: //2923/69DB20CF8580/CCAPI/ccCallNotify:
   Data Bitmask=0x5, Call Id=2923
2d21h: //2924/69DB20CF8580/CCAPI/cc_api_caps_ind:
   Destination Interface=0x47319490, Destination Call Id=2923, Source Call Id=2924,
   Caps(Codec=0x4, Fax Rate=0x2, Vad=0x2,
   Modem=0x0, Codec Bytes=20, Signal Type=2)
2d21h: //2924/69DB20CF8580/CCAPI/cc_api_caps_ack:
   Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
   Modem=OFF(0x0), Codec Bytes=20, Signal Type=2, Seq Num Start=2485)
2d21h: //2923/69DB20CF8580/CCAPI/cc_api_caps_ack:
2d21h: //2923/69DB20CF8580/CCAPI/cc_api_voice_mode_event:
   Call Id=2923
   Call Entry(Context=0x490F402C)
2d21h: //2924/69DB20CF8580/CCAPI/cc_api_call_connected:
   Interface=0x46FAB490, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
2d21h: //2923/69DB20CF8580/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x0
   Call Entry(Connected=TRUE, Responsed=TRUE)
2d21h: ISDN BR1/1/0 Q931: TX -> CONNECT pd = 8  callref = 0x90
        Channel ID i = 0x89
                Exclusive, B1
2d21h: ISDN BR1/1/0 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x10
*Oct 26 08:56:49: %ISDN-6-CONNECT: Interface BRI1/1/0:1 is now connected to 607345209 N/A
C2821-DTMSEVPR2#
C2821-DTMSEVPR2#
C2821-DTMSEVPR2#
C2821-DTMSEVPR2#
C2821-DTMSEVPR2#
2d21h: //2925/6B32C3078581/CCAPI/cc_handle_inter_digit_timer:
   Generate inter-digit timeout CC_EV_CALL_DIGIT_END event
2d21h: ISDN BR1/1/0 Q931: RX <- DISCONNECT pd = 8  callref = 0x10
        Cause i = 0x8090 - Normal call clearing
        Progress Ind i = 0x8288 - In-band info or appropriate now available
        Display i = 'LIBERACION NORMAL'
*Oct 26 08:56:54: %ISDN-6-CONNECT: Interface BRI1/1/0:1 is now connected to 607345209 N/A
*Oct 26 08:56:54: %ISDN-6-DISCONNECT: Interface BRI1/1/0:1  disconnected from 607345209 , call lasted 4 seconds
2d21h: //2923/69DB20CF8580/CCAPI/cc_api_call_disc_prog_ind:
   Cause Value=16, Progress Indication=INBAND(8), Interface=0x47319490
   Event(Progress Indication=0x0), Call Entry(Responsed=TRUE)
2d21h: //2923/69DB20CF8580/CCAPI/ccConferenceDestroy:
   Conference Id=0x51D, Tag=0x0
2d21h: //2923/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=2924, Disposition=0x0, Tag=0x0
2d21h: //2924/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
2d21h: //2923/69DB20CF8580/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
2d21h: //2923/69DB20CF8580/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
2d21h: //2924/69DB20CF8580/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
2d21h: //2924/69DB20CF8580/CCAPI/cc_api_get_transfer_info:
2d21h: //2924/69DB20CF8580/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46FAB490, Tag=0x0, Call Id=2924,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
2d21h: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
2d21h: :cc_free_feature_vsa freeing 46E25498
2d21h:  vsacount in free is 3
2d21h: //2923/69DB20CF8580/CCAPI/cc_api_call_disc_cause_update:
   Cause Value=16
   Call Entry(Disconnect Cause=16)
2d21h: //2923/69DB20CF8580/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x47319490, Tag=0x0, Call Id=2923,
2d21h: :cc_free_feature_vsa freeing 46E258D0
2d21h:  vsacount in free is 2
2d21h: ISDN BR1/1/0 Q931: TX -> RELEASE pd = 8  callref = 0x90
2d21h: ISDN BR1/1/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x10
2d21h: ISDN BR0/3/1 Q931: RX <- DISCONNECT pd = 8  callref = 0x29
MDCX 11171834 BRI/S0/SU3/P1/1@C2821-DTMSEVPR2.arconet.net MGCP 0.1
I: 67
X: 1
M: recvonly
R: D/[0-9ABCD*#]
Q: process,loop
   Nominator=0x800, Params=0x493ECCA8, Call Id=2926
200 11171834 OK
2d21h: ISDN BR0/3/1 Q931: TX -> RELEASE pd = 8  callref = 0xA9
2d21h: ISDN BR0/3/1 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x29
DLCX 11171836 BRI/S0/SU3/P1/1@C2821-DTMSEVPR2.arconet.net MGCP 0.1
I: 67
X: 1
S:
   (callID=0xB6D, digit_event=0x0, enable=FALSE, consume=FALSE)
   (vdbPtr=0x46B67B64, callID=0xB6D, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
2d21h: //2926/6B32C3078581/CCAPI/ccGetCallStatistics:
   Call Stats=0x47FDFB08, Call Id=2926
2d21h: //2925/6B32C3078581/CCAPI/ccConferenceDestroy:
   Conference Id=0x51C, Tag=0x0
2d21h: //2925/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=2926, Disposition=0x0, Tag=0x0
2d21h: //2926/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
2d21h: //2925/6B32C3078581/CCAPI/ccCallDisconnect:
2d21h: //2925/6B32C3078581/CCAPI/cc_api_get_transfer_info:
2d21h: //2926/6B32C3078581/CCAPI/ccCallDisconnect:
2d21h: //2926/6B32C3078581/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46A564B4, Tag=0x0, Call Id=2926,
2d21h: :cc_free_feature_vsa freeing 46E25A80
2d21h:  vsacount in free is 1
2d21h: //2925/6B32C3078581/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46B67B64, Tag=0x0, Call Id=2925,
2d21h: :cc_free_feature_vsa freeing 46E25060
2d21h:  vsacount in free is 0show voice call stat
No active calls found
C2821-DTMSEVPR2#
250 11171836 OK
P: PS=213, OS=6390, PR=213, OR=6361, PL=0, JI=6, LA=0
NTFY 449153098 *@C2821-DTMSEVPR2.arconet.net MGCP 0.1
X: 0
O:
200 449153098
2d21h: ISDN BR0/1/1 Q931: TX -> RESTART pd = 8  callref = 0x00
        Channel ID i = 0x89
                Exclusive, B1
        Restart Indicator i = 0x80
2d21h: ISDN BR0/1/1 Q931: RX <- RESTART_ACK pd = 8  callref = 0x80
        Channel ID i = 0x89
                Exclusive, B1
2d21h: ISDN BR0/1/1 Q931: TX -> STATUS pd = 8  callref = 0x00
        Cause i = 0x82C1 - Bearer capability not implemented
        Call State i = 0x00
2d21h: ISDN BR0/3/0 Q931: TX -> RESTART pd = 8  callref = 0x00
        Channel ID i = 0x89
                Exclusive, B1
2d21h: ISDN BR0/3/0 Q931: RX <- RESTART_ACK pd = 8  callref = 0x80
        Channel ID i = 0x89
                Exclusive, B1
2d21h: ISDN BR0/3/0 Q931: TX -> STATUS pd = 8  callref = 0x00
        Call State i = 0x00
NTFY 449153099 *@C2821-DTMSEVPR2.arconet.net MGCP 0.1
X: 0
O:
200 449153099
2d21h: ISDN BR0/2/1 Q931: TX -> RESTART pd = 8  callref = 0x00
        Channel ID i = 0x89
                Exclusive, B1
2d21h: ISDN BR0/2/1 Q931: RX <- RESTART_ACK pd = 8  callref = 0x80
        Channel ID i = 0x89
                Exclusive, B1
2d21h: ISDN BR0/2/1 Q931: TX -> STATUS pd = 8  callref = 0x00
        Call State i = 0x00
NTFY 449153100 *@C2821-DTMSEVPR2.arconet.net MGCP 0.1
X: 0
O:
200 449153100
NTFY 449153101 *@C2821-DTMSEVPR2.arconet.net MGCP 0.1
X: 0
O:
200 449153101
NTFY 449153102 *@C2821-DTMSEVPR2.arconet.net MGCP 0.1
X: 0
O:
200 449153102
NTFY 449153103 *@C2821-DTMSEVPR2.arconet.net MGCP 0.1
X: 0
O:
200 449153103
        Channel ID i = 0x8A
                Exclusive, B2
        Channel ID i = 0x8A
                Exclusive, B2
        Call State i = 0x00
        Channel ID i = 0x8A
                Exclusive, B2
        Channel ID i = 0x8A
                Exclusive, B2
        Call State i = 0x00
NTFY 449153104 *@C2821-DTMSEVPR2.arconet.net MGCP 0.1
X: 0
O:
200 449153104
NTFY 449153105 *@C2821-DTMSEVPR2.arconet.net MGCP 0.1
X: 0
O:
200 449153105
NTFY 449153106 *@C2821-DTMSEVPR2.arconet.net MGCP 0.1
X: 0
O:
200 449153106
2d21h: ISDN BR0/3/0 Q931: RX <- SETUP pd = 8  callref = 0x21
        Sending Complete
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
        Channel ID i = 0x89
                Exclusive, B1
        Progress Ind i = 0x8283 - Origination address is non-ISDN
        Calling Party Number i = 0x0183, '954584455'
CRCX 11171885 BRI/S0/SU3/P0/1@C2821-DTMSEVPR2.arconet.net MGCP 0.1
C: D0000000013fede0000000F580000021
M: recvonly
   Interface=0x472FA6C4, Interface Type=6, Destination=, Mode=0x9,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=D0000000013fede0000000F580000021)
2d21h: :FEATURE_VSA attributes are: feature_name:0,feature_time:1189236840,feature_id:2927
2d21h: //2927/C1127DAE8582/CCAPI/ccIFCallSetupRequestPrivate:
2d21h: //2927/C1127DAE8582/CCAPI/ccCallSetContext:
   Context=0x47DE04D8
2d21h: :FEATURE_VSA attributes are: feature_name:0,feature_time:1189239432,feature_id:2928
2d21h: //2928/C1127DAE8582/CCAPI/ccIFCallSetupRequestPrivate:
2d21h: //2928/C1127DAE8582/CCAPI/ccCallSetContext:
   Context=0x47DDFC98
2d21h: //2928/C1127DAE8582/CCAPI/cc_api_call_connected:
   Connection Handle=0
2d21h: //2927/C1127DAE8582/CCAPI/cc_api_call_proceeding:
   Interface=0x472FA6C4, Progress Indication=NULL(0)
2d21h: //2927/C1127DAE8582/CCAPI/cc_api_call_connected:
   Interface=0x472FA6C4, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
   Connection Handle=0
2d21h: //2927/C1127DAE8582/CCAPI/ccCallModify:
   Nominator=0x1000, Params=0x493ED940, Call Id=2927
2d21h: //2927/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0xB6F, digit_event=0x1, enable=TRUE, consume=FALSE)
2d21h: //2927/C1127DAE8582/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=2927
2d21h: //2927/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x472FA6C4, callID=0xB6F, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
2d21h: //2927/C1127DAE8582/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x472FA6C4, Call Id=2927
2d21h: //2927/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x493EDAE4, callID1=0xB6F, callID2=0xB70, tag=0x0)
2d21h: //2927/C1127DAE8582/CCAPI/ccConferenceCreate:
   Conference Id=0x493EDAE4, Call Id1=2927, Call Id2=2928, Tag=0x0
2d21h: //2927/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x51E, Source Interface=0x472FA6C4, Source Call Id=2927,
   Destination Call Id=2928, Disposition=0x0, Tag=0xFFFFFFFF
2d21h: //2928/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x51E, Source Interface=0x46A564B4, Source Call Id=2928,
   Destination Call Id=2927, Disposition=0x0, Tag=0x0
2d21h: //2927/C1127DAE8582/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x51E, Destination Call Id=2928)
2d21h: //2928/C1127DAE8582/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x51E, Destination Call Id=2927)
2d21h: //2927/C1127DAE8582/CCAPI/cc_api_caps_ind:
   Destination Interface=0x46A564B4, Destination Call Id=2928, Source Call Id=2927,
2d21h: //2928/C1127DAE8582/CCAPI/cc_api_caps_ind:
   Destination Interface=0x472FA6C4, Destination Call Id=2927, Source Call Id=2928,
2d21h: //2928/C1127DAE8582/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=30, Signal Type=2, Seq Num Start=9723)
2d21h: //2927/C1127DAE8582/CCAPI/cc_api_caps_ack:
2d21h: //2927/C1127DAE8582/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x472FA6C4, Call Id=2927
2d21h: //2927/C1127DAE8582/CCAPI/cc_api_voice_mode_event:
   Call Id=2927
   Call Entry(Context=0x47DE04D8)
2d21h: //2927/C1127DAE8582/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x51E, Call Id1=2927, Call Id2=2928
200 11171885 OK
I: 68
v=0
c=IN IP4 192.24.5.1
m=audio 18934 RTP/AVP 18 100
a=X-sqn:0
2d21h: ISDN BR0/3/0 Q931: TX -> CALL_PROC pd = 8  callref = 0xA1
        Channel ID i = 0x89
                Exclusive, B1
RQNT 11171886 BRI/S0/SU3/P0/1@C2821-DTMSEVPR2.arconet.net MGCP 0.1
X: 1
R: D/[0-9ABCD*#]
S: G/rt
Q: process,loop
2d21h: //2927/C1127DAE8582/CCAPI/ccSetDigitTimeouts:
2d21h: //2927/C1127DAE8582/CCAPI/ccRestartDigitTimeoutMsec:
   Digit Timeout=0, Call Id=2927
   Nominator=0x1000, Params=0x493ED320, Call Id=2927
2d21h: //2927/C1127DAE8582/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=2927
200 11171886 OK
MDCX 11171887 BRI/S0/SU3/P0/1@C2821-DTMSEVPR2.arconet.net MGCP 0.1
I: 68
X: 1
M: sendrecv
R: D/[0-9ABCD*#]
S:
Q: process,loop
v=0
o=- 104 0 IN EPN BRI/S0/SU3/P0/1@C2821-DTMSEVPR2.arconet.net
s=Cisco SDP 0
t=0 0
m=audio 26738 RTP/AVP 18
2d21h: //2927/C1127DAE8582/CCAPI/ccCallModifyExtended:
   Nominator=0x493ED678, Params=0x493ECB18, Call Id=2927
2d21h: //2928/C1127DAE8582/CCAPI/ccCallModify:
   Nominator=0x18E30, Params=0x493ECCA8, Call Id=2928
2d21h: //2928/C1127DAE8582/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x46A564B4, Call Id=2928
200 11171887 OK
2d21h: ISDN BR0/3/0 Q931: TX -> ALERTING pd = 8  callref = 0xA1
2d21h: ISDN BR0/3/0 Q931: TX -> CONNECT pd = 8  callref = 0xA1
2d21h: ISDN BR0/3/0 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x21
        Channel ID i = 0x89
                Exclusive, B1
        Channel ID i = 0x89
                Exclusive, B1
        Call State i = 0x00
2d21h: ISDN BR0/2/1 Q931: RX <- SETUP pd = 8  callref = 0x31
        Sending Complete
                Standard = CCITT
        Channel ID i = 0x89
                Exclusive, B1
        Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
        Calling Party Number i = 0x0183, '954391461'
CRCX 11171891 BRI/S0/SU2/P1/1@C2821-DTMSEVPR2.arconet.net MGCP 0.1
C: D0000000013fede2000000F580000031
M: recvonly
   Interface=0x46B585D0, Interface Type=6, Destination=, Mode=0x9,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=D0000000013fede2000000F580000031)
2d21h: :FEATURE_VSA attributes are: feature_name:0,feature_time:1189239000,feature_id:2929
2d21h: //2929/C34D2CC48583/CCAPI/ccIFCallSetupRequestPrivate:
2d21h: //2929/C34D2CC48583/CCAPI/ccCallSetContext:
   Context=0x47DE0638
2d21h: :FEATURE_VSA attributes are: feature_name:0,feature_time:1189237920,feature_id:2930
2d21h: //2930/C34D2CC48583/CCAPI/ccIFCallSetupRequestPrivate:
2d21h: //2930/C34D2CC48583/CCAPI/ccCallSetContext:
   Context=0x47DDFEA8
2d21h: //2930/C34D2CC48583/CCAPI/cc_api_call_connected:
   Connection Handle=0
2d21h: //2929/C34D2CC48583/CCAPI/cc_api_call_proceeding:
   Interface=0x46B585D0, Progress Indication=NULL(0)
2d21h: //2929/C34D2CC48583/CCAPI/cc_api_call_connected:
   Interface=0x46B585D0, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
   Connection Handle=0
2d21h: //2929/C34D2CC48583/CCAPI/ccCallModify:
   Nominator=0x1000, Params=0x493ED940, Call Id=2929
2d21h: //2929/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0xB71, digit_event=0x1, enable=TRUE, consume=FALSE)
2d21h: //2929/C34D2CC48583/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=2929
2d21h: //2929/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x46B585D0, callID=0xB71, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
2d21h: //2929/C34D2CC48583/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x46B585D0, Call Id=2929
2d21h: //2929/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x493EDAE4, callID1=0xB71, callID2=0xB72, tag=0x0)
2d21h: //2929/C34D2CC48583/CCAPI/ccConferenceCreate:
   Conference Id=0x493EDAE4, Call Id1=2929, Call Id2=2930, Tag=0x0
2d21h: //2929/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x51F, Source Interface=0x46B585D0, Source Call Id=2929,
   Destination Call Id=2930, Disposition=0x0, Tag=0xFFFFFFFF
2d21h: //2930/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x51F, Source Interface=0x46A564B4, Source Call Id=2930,
   Destination Call Id=2929, Disposition=0x0, Tag=0x0
2d21h: //2929/C34D2CC48583/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x51F, Destination Call Id=2930)
2d21h: //2930/C34D2CC48583/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x51F, Destination Call Id=2929)
2d21h: //2929/C34D2CC48583/CCAPI/cc_api_caps_ind:
   Destination Interface=0x46A564B4, Destination Call Id=2930, Source Call Id=2929,
2d21h: //2930/C34D2CC48583/CCAPI/cc_api_caps_ind:
   Destination Interface=0x46B585D0, Destination Call Id=2929, Source Call Id=2930,
2d21h: //2930/C34D2CC48583/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=30, Signal Type=2, Seq Num Start=9229)
2d21h: //2929/C34D2CC48583/CCAPI/cc_api_caps_ack:
2d21h: //2929/C34D2CC48583/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x46B585D0, Call Id=2929
2d21h: //2929/C34D2CC48583/CCAPI/cc_api_voice_mode_event:
   Call Id=2929
   Call Entry(Context=0x47DE0638)
2d21h: //2929/C34D2CC48583/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x51F, Call Id1=2929, Call Id2=2930
200 11171891 OK
I: 69
v=0
c=IN IP4 192.24.5.1
m=audio 18956 RTP/AVP 18 100
a=X-sqn:0
2d21h: ISDN BR0/2/1 Q931: TX -> CALL_PROC pd = 8  callref = 0xB1
        Channel ID i = 0x89
                Exclusive, B1
RQNT 11171892 BRI/S0/SU2/P1/1@C2821-DTMSEVPR2.arconet.net MGCP 0.1
X: 1
R: D/[0-9ABCD*#]
S: G/rt
Q: process,loop
2d21h: //2929/C34D2CC48583/CCAPI/ccSetDigitTimeouts:
2d21h: //2929/C34D2CC48583/CCAPI/ccRestartDigitTimeoutMsec:
   Digit Timeout=0, Call Id=2929
   Nominator=0x1000, Params=0x493ED320, Call Id=2929
2d21h: //2929/C34D2CC48583/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=2929
200 11171892 OK
MDCX 11171893 BRI/S0/SU2/P1/1@C2821-DTMSEVPR2.arconet.net MGCP 0.1
I: 69
X: 1
M: sendrecv
R: D/[0-9ABCD*#]
S:
Q: process,loop
v=0
o=- 105 0 IN EPN BRI/S0/SU2/P1/1@C2821-DTMSEVPR2.arconet.net
s=Cisco SDP 0
t=0 0
m=audio 26740 RTP/AVP 18
2d21h: //2929/C34D2CC48583/CCAPI/ccCallModifyExtended:
   Nominator=0x493ED678, Params=0x493ECB18, Call Id=2929
2d21h: //2930/C34D2CC48583/CCAPI/ccCallModify:
   Nominator=0x18E30, Params=0x493ECCA8, Call Id=2930
2d21h: //2930/C34D2CC48583/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x46A564B4, Call Id=2930
200 11171893 OK
2d21h: ISDN BR0/2/1 Q931: TX -> ALERTING pd = 8  callref = 0xB1
2d21h: ISDN BR0/2/1 Q931: TX -> CONNECT pd = 8  callref = 0xB1
2d21h: //2927/C1127DAE8582/CCAPI/cc_handle_inter_digit_timer:
2d21h: ISDN BR0/2/1 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x31
2d21h: //2929/C34D2CC48583/CCAPI/cc_handle_inter_digit_timer:
        Channel ID i = 0x89
                Exclusive, B1
2d21h: ISDN BR0/3/0 Q931: RX <- DISCONNECT pd = 8  callref = 0x21
        Cause i = 0x829F - Normal, unspecified
        Display i = 'NORMAL'
MDCX 11171897 BRI/S0/SU3/P0/1@C2821-DTMSEVPR2.arconet.net MGCP 0.1
I: 68
X: 1
M: recvonly
R: D/[0-9ABCD*#]
Q: process,loop
   Nominator=0x800, Params=0x493ECCA8, Call Id=2928
200 11171897 OK
2d21h: ISDN BR0/3/0 Q931: TX -> RELEASE pd = 8  callref = 0xA1
2d21h: ISDN BR0/3/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x21
DLCX 11171898 BRI/S0/SU3/P0/1@C2821-DTMSEVPR2.arconet.net MGCP 0.1
I: 68
X: 1
S:
   (callID=0xB6F, digit_event=0x0, enable=FALSE, consume=FALSE)
   (vdbPtr=0x472FA6C4, callID=0xB6F, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
2d21h: //2928/C1127DAE8582/CCAPI/ccGetCallStatistics:
   Call Stats=0x47FE07C8, Call Id=2928
2d21h: //2927/C1127DAE8582/CCAPI/ccConferenceDestroy:
   Conference Id=0x51E, Tag=0x0
2d21h: //2927/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=2928, Disposition=0x0, Tag=0x0
2d21h: //2928/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
2d21h: //2927/C1127DAE8582/CCAPI/ccCallDisconnect:
2d21h: //2927/C1127DAE8582/CCAPI/cc_api_get_transfer_info:
2d21h: //2928/C1127DAE8582/CCAPI/ccCallDisconnect:
2d21h: //2928/C1127DAE8582/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46A564B4, Tag=0x0, Call Id=2928,
2d21h: //2927/C1127DAE8582/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x472FA6C4, Tag=0x0, Call Id=2927,
250 11171898 OK
P: PS=352, OS=10560, PR=352, OR=10531, PL=0, JI=6, LA=0
        Channel ID i = 0x89
                Exclusive, B1
        Call State i = 0x00
C2821-DTMSEVPR2#
C2821-DTMSEVPR2#
C2821-DTMSEVPR2#un all
All possible debugging has been turned off
C2821-DTMSEVPR2#
2d21h: //2929/C34D2CC48583/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x46A564B4, Destination Mask=0x3, Destination Call Id=2930,
   Source Call Id=2929, Digit=1, DigitBeginFlags=0x1,
   Rtp Timestamp=0x6D35F74A, Rtp Expiration=0x0
2d21h: //2929/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 1 to dstCallId 0xB72
2d21h: //2929/C34D2CC48583/CCAPI/cc_api_call_digit_end:
   Source Call Id=2929, Digit=1, Duration=115,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
   Call Entry(Handoff Depth=0)
2d21h: //2929/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
NTFY 449153107 BRI/S0/SU2/P1/1@C2821-DTMSEVPR2.arconet.net MGCP 0.1
N: ca@192.25.98.10:2427
X: 1
O: D/1
200 449153107
RQNT 11171899 BRI/S0/SU2/P1/1@C2821-DTMSEVPR2.arconet.net MGCP 0.1
X: 1
R: D/[0-9ABCD*#]
Q: process,loop
   Nominator=0x1000, Params=0x493ED320, Call Id=2929term
200 11171899 OK
no mon
C2821-DTMSEVPR2#show mgcp
C2821-DTMSEVPR2#show mgcp en
C2821-DTMSEVPR2#show mgcp endpoint
aaln/S0/SU0/0@C2821-DTMSEVPR2
BRI/S0/SU1/P0/1@C2821-DTMSEVPR2
BRI/S0/SU1/P0/2@C2821-DTMSEVPR2
BRI/S0/SU1/P1/1@C2821-DTMSEVPR2
BRI/S0/SU1/P1/2@C2821-DTMSEVPR2
BRI/S0/SU2/P0/1@C2821-DTMSEVPR2
BRI/S0/SU2/P0/2@C2821-DTMSEVPR2
BRI/S0/SU2/P1/2@C2821-DTMSEVPR2
BRI/S0/SU3/P0/2@C2821-DTMSEVPR2
BRI/S0/SU3/P1/2@C2821-DTMSEVPR2
BRI/S1/SU0/P0/1@C2821-DTMSEVPR2
BRI/S1/SU0/P0/2@C2821-DTMSEVPR2
C2821-DTMSEVPR2#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
C2821-DTMSEVPR2(config)#inter bri
C2821-DTMSEVPR2(config)#inter bri 1/1/0
C2821-DTMSEVPR2(config-if)#shut
C2821-DTMSEVPR2(config-if)#isdn
C2821-DTMSEVPR2(config-if)#isdn bin
C2821-DTMSEVPR2(config-if)#isdn bind-l3
C2821-DTMSEVPR2(config-if)#isdn bind-l3 mg
C2821-DTMSEVPR2(config-if)#isdn bind-l3 ccm
C2821-DTMSEVPR2(config-if)#isdn bind-l3 ccm-manager ser
C2821-DTMSEVPR2(config-if)#isdn bind-l3 ccm-manager service mgc
C2821-DTMSEVPR2(config-if)#isdn bind-l3 ccm-manager service mgcp
C2821-DTMSEVPR2(config-if)#no shut
C2821-DTMSEVPR2(config-if)#exit
C2821-DTMSEVPR2(config)#exit
C2821-DTMSEVPR2#
Before the incoming call on BRI1/1/0 ( ANI '607345209' DNIS '955658800')
goes into Alerting state, there is another incoming call on BRI0/3/1 with
same DNIS but a diff. ANI 956182122...why is telco doing that?
Debugs don't have sequence num and timestamps enabled so not sure
what is going on h323 leg...
Both call eventually connect but is the telco shooting another call due to
some delay in the first call setup but now from a diff calling number ?
Can u get more detailed debugs?
configure this first:
service time deb date msec
service sequence
logging buffer 5000000 deb
no logg con
Issue clear log and capture following debugs for one such call in the logging
buffer and then dump it in a text file (issue term len 0  first)
deb h225 asn
deb h245 asn
deb isdn q931
deb mgcp pack
The call now comes in and just gives me dial tone if I switch to h323.
dial-peer voice 9 pots
incoming called-number 955658...
direct-inward-dial
port 1/1/0
destination-pattern 955658...
020089: *Oct 26 17:09:30.639: MGCP Packet received from 192.25.98.10:2427--->
200 449154959
020090: *Oct 26 17:09:32.315: ISDN BR1/1/0 Q931: RX <- SETUP pd = 8  callref = 0x30
        Sending Complete
                Standard = CCITT
        Channel ID i = 0x89
                Exclusive, B1
020091: *Oct 26 17:09:32.319: //-1/A28BE14F8898/CCAPI/cc_api_display_ie_subfields:
C2821-DTMSEVPR2#:
   cisco-username=
   cisco-ani=607345209
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=955658800
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
020092: *Oct 26 17:09:32.319: //-1/A28BE14F8898/CCAPI/cc_api_call_setup_ind_common:
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=20, Progress Indication=NULL(0), Calling IE Present=TRUE,
020093: *Oct 26 17:09:32.319: //-1/A28BE14F8898/CCAPI/ccCheckClipClir:
020094: *Oct 26 17:09:32.319: //-1/A28BE14F8898/CCAPI/ccCheckClipClir:
020095: *Oct 26 17:09:32.319: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020096: *Oct 26 17:09:32.319: :cc_get_feature_vsa malloc success
020097: *Oct 26 17:09:32.319: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020098: *Oct 26 17:09:32.319:  cc_get_feature_vsa count is 1
020099: *Oct 26 17:09:32.319: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020100: *Oct 26 17:09:32.319: :FEATURE_VSA attributes are: feature_name:0,feature_time:1189236624,feature_id:4503
020101: *Oct 26 17:09:32.319: //4503/A28BE14F8898/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
020102: *Oct 26 17:09:32.319: //4503/A28BE14F8898/CCAPI/cc_process_call_setup_ind:
   Event=0x46B057A8
020103: *Oct 26 17:09:32.323: //4503/A28BE14F8898/CCAPI/ccCallSetContext:
   Context=0x490EF7D4
020104: *Oct 26 17:09:32.323: //4503/A28BE14F8898/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 4503 with tag 20 to app "_ManagedAppProcess_Default"
020105: *Oct 26 17:09:32.331: //4503/A28BE14F8898/CCAPI/ccCallSetupAck:
   Call Id=4503
020106: *Oct 26 17:09:32.331: //4503/A28BE14F8898/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
020107: *Oct 26 17:09:32.331: //4503/A28BE14F8898/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=4503
020108: *Oct 26 17:09:32.331: //4503/A28BE14F8898/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
020109: *Oct 26 17:09:32.331: //4503/A28BE14F8898/CCAPI/ccSetDigitTimeouts:
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
020110: *Oct 26 17:09:32.331: //4503/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x1197, digit_event=0x1, enable=TRUE, consume=FALSE)
020111: *Oct 26 17:09:32.331: //4503/A28BE14F8898/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=4503
020112: *Oct 26 17:09:32.331: //4503/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x47319490, callID=0x1197, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
020113: *Oct 26 17:09:32.331: //4503/A28BE14F8898/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x47319490, Call Id=4503
020114: *Oct 26 17:09:32.331: //4503/A28BE14F8898/CCAPI/cc_api_call_report_digits_done:
020115: *Oct 26 17:09:32.335: ISDN BR1/1/0 Q931: TX -> CALL_PROC pd = 8  callref = 0xB0
        Channel ID i = 0x89
                Exclusive, B1
020116: *Oct 26 17:09:32.407: ISDN BR1/1/0 Q931: TX -> CONNECT pd = 8  callref = 0xB0
        Channel ID i = 0x89
                Exclusive, B1
020117: *Oct 26 17:09:32.571: ISDN BR1/1/0 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x30
020118: *Oct 26 18:09:32: %ISDN-6-CONNECT: Interface BRI1/1/0:1 is now connected to 607345209 N/A
C2821-DTMSEVPR2#
C2821-DTMSEVPR2#
C2821-DTMSEVPR2#
020119: *Oct 26 17:09:37.655: ISDN BR1/1/0 Q931: RX <- DISCONNECT pd = 8  callref = 0x30
020120: *Oct 26 18:09:37: %ISDN-6-CONNECT: Interface BRI1/1/0:1 is now connected to 607345209 N/A
020121: *Oct 26 18:09:37: %ISDN-6-DISCONNECT: Interface BRI1/1/0:1  disconnected from 607345209 , call lasted 5 seconds
020122: *Oct 26 17:09:37.659: //4503/A28BE14F8898/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x47319490, Call Id=4503
020123: *Oct 26 17:09:37.659: //4503/A28BE14F8898/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
020124: *Oct 26 17:09:37.659: //4503/A28BE14F8898/CCAPI/ccCallDisconnect:
020125: *Oct 26 17:09:37.659: //4503/A28BE14F8898/CCAPI/ccCallDisconnect:
020126: *Oct 26 17:09:37.659: //4503/A28BE14F8898/CCAPI/cc_api_get_transfer_info:
020127: *Oct 26 17:09:37.667: ISDN BR1/1/0 Q931: TX -> RELEASE pd = 8  callref = 0xB0
020128: *Oct 26 17:09:37.671: //4503/A28BE14F8898/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x47319490, Tag=0x0, Call Id=4503,
020129: *Oct 26 17:09:37.671: //4503/A28BE14F8898/CCAPI/cc_api_call_disconnect_done:
020130: *Oct 26 17:09:37.671: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
020131: *Oct 26 17:09:37.671: :cc_free_feature_vsa freeing 46E24F88
020132: *Oct 26 17:09:37.671: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
   un all
020133: *Oct 26 17:09:37.671:  vsacount in free is 0
020134: *Oct 26 17:09:37.835: ISDN BR1/1/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x30
that's cuz u are hitting dialpeer 20  on the inbound which is lacking
direct-inward-dial CLI.
Fixed that. I went ahead and configured all ports for h323 and tried the call with the debugs you requested I still get no voice or ring back when calling in and I don´t know why its hitting dial-peer 20 when I have more specific dial peers configured which should send the call on its way to the cucm.
I was thinking of just deleting all dial-peers and starting from scratch to see if that makes any diference.
C2821-DTMSEVPR2#
C2821-DTMSEVPR2#deb mgcp pack
020178: *Oct 27 07:41:11.990: ISDN BR0/2/1 Q931: RX <- SETUP pd = 8  callref = 0x61
        Sending Complete
                Standard = CCITT
        Channel ID i = 0x89
                Exclusive, B1
020179: *Oct 27 07:41:11.994: //-1/6794E14C88C3/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=607345209
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=955658800
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
terminal monitor pi=-1
   cisco-rdnsi=-1
020180: *Oct 27 07:41:11.994: //-1/6794E14C88C3/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x46B585D0, Call Info(
020181: *Oct 27 07:41:11.994: //-1/6794E14C88C3/CCAPI/ccCheckClipClir:
020182: *Oct 27 07:41:11.994: //-1/6794E14C88C3/CCAPI/ccCheckClipClir:
020183: *Oct 27 07:41:11.994: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020184: *Oct 27 07:41:11.994: :cc_get_feature_vsa malloc success
020185: *Oct 27 07:41:11.994: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020186: *Oct 27 07:41:11.994:  cc_get_feature_vsa count is 1
020187: *Oct 27 07:41:11.994: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020188: *Oct 27 07:41:11.994: :FEATURE_VSA attributes are: feature_name:0,feature_time:1189237704,feature_id:4588
020189: *Oct 27 07:41:11.994: //4588/6794E14C88C3/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
020190: *Oct 27 07:41:11.998: //4588/6794E14C88C3/CCAPI/cc_process_call_setup_ind:
   Event=0x46B07CE8
020191: *Oct 27 07:41:11.998: //4588/6794E14C88C3/CCAPI/ccCallSetContext:
   Context=0x490EDAE4
020192: *Oct 27 07:41:11.998: //4588/6794E14C88C3/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 4588 with tag 20 to app "_ManagedAppProcess_Default"
020193: *Oct 27 07:41:12.002: //4588/6794E14C88C3/CCAPI/ccCallProceeding:
020194: *Oct 27 07:41:12.006: //4588/6794E14C88C3/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=955, Params=0x490EAFCC, Progress Indication=NULL(0)
020195: *Oct 27 07:41:12.006: //4588/6794E14C88C3/CCAPI/ccCheckClipClir:
020196: *Oct 27 07:41:12.006: //4588/6794E14C88C3/CCAPI/ccCheckClipClir:
020197: *Oct 27 07:41:12.006: //4588/6794E14C88C3/CCAPI/ccCallSetupRequest:
020198: *Oct 27 07:41:12.006: //4588/6794E14C88C3/CCAPI/ccCallSetupRequest:
   Guid=6794E14C-E0D4-11DF-88C3-001E13CE2E20, Outgoing Dial-peer=955
020199: *Oct 27 07:41:12.006: //4588/6794E14C88C3/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=607345209
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=955658800
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
020200: *Oct 27 07:41:12.006: //4588/6794E14C88C3/CCAPI/ccIFCallSetupRequestPrivate:
020201: *Oct 27 07:41:12.006: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020202: *Oct 27 07:41:12.006: :cc_get_feature_vsa malloc success
020203: *Oct 27 07:41:12.006: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020204: *Oct 27 07:41:12.006:  cc_get_feature_vsa count is 2
020205: *Oct 27 07:41:12.006: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020206: *Oct 27 07:41:12.006: :FEATURE_VSA attributes are: feature_name:0,feature_time:1189235760,feature_id:4589
020207: *Oct 27 07:41:12.006: //4589/6794E14C88C3/CCAPI/ccIFCallSetupRequestPrivate:
020208: *Oct 27 07:41:12.006: //4589/6794E14C88C3/CCAPI/ccCallSetContext:
   Context=0x490EAF7C
020209: *Oct 27 07:41:12.006: //4588/6794E14C88C3/CCAPI/ccSaveDialpeerTag:
020210: *Oct 27 07:41:12.014: ISDN BR0/2/1 Q931: TX -> CALL_PROC pd = 8  callref = 0xE1
        Channel ID i = 0x89
                Exclusive, B1
020211: *Oct 27 07:41:12.022: H245 FS OLC OUTGOING PDU ::=
value OpenLogicalChannel ::=
      forwardLogicalChannelNumber 1
      forwardLogicalChannelParameters
        dataType audioData : g711Ulaw64k : 20
        multiplexParameters h2250LogicalChannelParameters :
          sessionID 1
          mediaControlChannel unicastAddress : iPAddress :
            network 'C0180501'H
            tsapIdentifier 18825
          silenceSuppression TRUE
020212: *Oct 27 07:41:12.026: H245 FS OLC OUTGOING ENCODE BUFFER::= 0000000C6013800B05000100C0180501498980
020213: *Oct 27 07:41:12.026:
020214: *Oct 27 07:41:12.026: H245 FS OLC OUTGOING PDU ::=
        dataType nullData : NULL
        multiplexParameters none : NULL
      reverseLogicalChannelParameters
          sessionID 1
          mediaChannel unicastAddress : iPAddress :
            network 'C0180501'H
            tsapIdentifier 18824
            network 'C0180501'H
020215: *Oct 27 07:41:12.026: H245 FS OLC OUTGOING ENCODE BUFFER::= 400000060401004C6013801215000100C0180501498800C0180501498980
020216: *Oct 27 07:41:12.026:
020217: *Oct 27 07:41:12.026: H245 FS OLC OUTGOING PDU ::=
      forwardLogicalChannelNumber 2
        dataType audioData : g729 : 2
          sessionID 1
            network 'C0180501'H
020218: *Oct 27 07:41:12.026: H245 FS OLC OUTGOING ENCODE BUFFER::= 0000010D4001800B05000100C0180501498980
020219: *Oct 27 07:41:12.026:
020220: *Oct 27 07:41:12.026: H245 FS OLC OUTGOING PDU ::=
          sessionID 1
            network 'C0180501'H
            network 'C0180501'H
020221: *Oct 27 07:41:12.030: H245 FS OLC OUTGOING ENCODE BUFFER::= 400001060401004D4001801215000100C0180501498800C0180501498980
020222: *Oct 27 07:41:12.030:
020223: *Oct 27 07:41:12.030: H225 NONSTD OUTGOING PDU ::=
value H323_UU_NonStdInfo ::=
      version 1
      protoParam qsigNonStdInfo :
        iei -95
        rawMesg 'A104038090A31801896C0B018336303733343532...'H
020224: *Oct 27 07:41:12.030: H225 NONSTD OUTGOING ENCODE BUFFER::= 6001010001A180D8A104038090A31801896C0B0183363037333435323039700AA13935353635383830301CB49E810003677464000000A949414D2C0D0A50524E2C6973646E2A2C2C2C0D0A5553492C726174652C632C732C632C310D0A5553492C6C6179312C616C61770D0A544D522C30300D0A43504E2C30342C2C312C3935353635383830300D0A43474E2C30302C2C312C792C342C3630373334353230390D0A4350432C30390D0A4643492C2C2C2C2C2C2C792C0D0A4743492C36373934653134636530643431316466383863333030316531336365326532300D0A0D0A
020225: *Oct 27 07:41:12.030:
020226: *Oct 27 07:41:12.030: H225.0 OUTGOING PDU ::=
value H323_UserInformation ::=
      h323-uu-pdu
        h323-message-body setup :
          protocolIdentifier { 0 0 8 2250 0 4 }
          sourceAddress
            h323-ID : {"C2821-DTMSEVPR2"}
          sourceInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
          activeMC FALSE
          conferenceID '6794E14CE0D411DF88C3001E13CE2E20'H
          conferenceGoal create : NULL
          callType pointToPoint : NULL
          sourceCallSignalAddress ipAddress :
            ip 'C0180501'H
            port 20338
          callIdentifier
            guid '67957D74E0D411DF99D7983863021ADA'H
          fastStart
            '0000000C6013800B05000100C0180501498980'H,
            '400000060401004C6013801215000100C0180501...'H,
            '0000010D4001800B05000100C0180501498980'H,
            '400001060401004D4001801215000100C0180501...'H
          mediaWaitForConnect FALSE
          canOverlapSend FALSE
          multipleCalls TRUE
          maintainConnection TRUE
          symmetricOperationRequired NULL
        h245Tunneling TRUE
        nonStandardControl
            nonStandardIdentifier h221NonStandard :
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '6001010001A180D8A104038090A31801896C0B01...'H
        tunnelledSignallingMessage
          tunnelledProtocolID
            id tunnelledProtocolAlternateID :
              protocolType "gtd"
          messageContent
            '49414D2C0D0A50524E2C6973646E2A2C2C2C0D0A...'H
          tunnellingRequired NULL
020227: *Oct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
020228: *Oct 27 07:41:12.038:
020229: *Oct 27 07:41:12.162: H225.0 INCOMING ENCODE BUFFER::= 2180060008914A000522C0B50000120F436973636F43616C6C4D616E6167657200310110C0110067957D74E0D411DF99D7983863021ADA0100010010A001000F0140B5000012088164000400010300
020230: *Oct 27 07:41:12.162:
020231: *Oct 27 07:41:12.162: H225.0 INCOMING PDU ::=
      h323-uu-pdu
        h323-message-body callProceeding :
          protocolIdentifier { 0 0 8 2250 0 5 }
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              productId '436973636F43616C6C4D616E61676572'H
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
          callIdentifier
          multipleCalls FALSE
          maintainConnection FALSE
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '8164000400010300'H
020232: *Oct 27 07:41:12.166: H225 NONSTD INCOMING ENCODE BUFFER::= 8164000400010300
020233: *Oct 27 07:41:12.166:
020234: *Oct 27 07:41:12.166: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        interclusterVersion 3
        enterpriseID {}
020235: *Oct 27 07:41:12.166: //4589/6794E14C88C3/CCAPI/cc_api_set_called_ccm_detected:
020236: *Oct 27 07:41:12.166: //4589/6794E14C88C3/CCAPI/cc_api_call_proceeding:
020237: *Oct 27 07:41:14.226: ISDN BR1/1/0 Q931: RX <- SETUP pd = 8  callref = 0x4E
        Sending Complete
                Standard = CCITT
        Channel ID i = 0x89
                Exclusive, B1
020238: *Oct 27 07:41:14.234: //-1/68EAAF0C88C4/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=956182122
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=955658800
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
020239: *Oct 27 07:41:14.234: //-1/68EAAF0C88C4/CCAPI/cc_api_call_setup_ind_common:
   Calling Number=956182122,(Calling Name=)(TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
020240: *Oct 27 07:41:14.234: //-1/68EAAF0C88C4/CCAPI/ccCheckClipClir:
   In: Calling Number=956182122(TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
020241: *Oct 27 07:41:14.234: //-1/68EAAF0C88C4/CCAPI/ccCheckClipClir:
   Out: Calling Number=956182122(TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
020242: *Oct 27 07:41:14.234: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020243: *Oct 27 07:41:14.234: :cc_get_feature_vsa malloc success
020244: *Oct 27 07:41:14.234: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020245: *Oct 27 07:41:14.234:  cc_get_feature_vsa count is 3
020246: *Oct 27 07:41:14.234: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020247: *Oct 27 07:41:14.234: :FEATURE_VSA attributes are: feature_name:0,feature_time:1189236192,feature_id:4590
020248: *Oct 27 07:41:14.234: //4590/68EAAF0C88C4/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=956182122(TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
020249: *Oct 27 07:41:14.234: //4590/68EAAF0C88C4/CCAPI/cc_process_call_setup_ind:
   Event=0x46B07CE8
020250: *Oct 27 07:41:14.234: //4590/68EAAF0C88C4/CCAPI/ccCallSetContext:
   Context=0x490F402C
020251: *Oct 27 07:41:14.234: //4590/68EAAF0C88C4/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 4590 with tag 20 to app "_ManagedAppProcess_Default"
020252: *Oct 27 07:41:14.242: //4590/68EAAF0C88C4/CCAPI/ccCallProceeding:
020253: *Oct 27 07:41:14.242: //4590/68EAAF0C88C4/CCAPI/ccCallSetupRequest:
020254: *Oct 27 07:41:14.242: //4590/68EAAF0C88C4/CCAPI/ccCheckClipClir:
020255: *Oct 27 07:41:14.242: //4590/68EAAF0C88C4/CCAPI/ccCheckClipClir:
020256: *Oct 27 07:41:14.242: //4590/68EAAF0C88C4/CCAPI/ccCallSetupRequest:
020257: *Oct 27 07:41:14.242: //4590/68EAAF0C88C4/CCAPI/ccCallSetupRequest:
   Guid=68EAAF0C-E0D4-11DF-88C4-001E13CE2E20, Outgoing Dial-peer=955
020258: *Oct 27 07:41:14.242: //4590/68EAAF0C88C4/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=956182122
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=955658800
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
020259: *Oct 27 07:41:14.246: //4590/68EAAF0C88C4/CCAPI/ccIFCallSetupRequestPrivate:
   Call Params(Calling Number=956182122,(Calling Name=)(TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
020260: *Oct 27 07:41:14.246: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020261: *Oct 27 07:41:14.246: :cc_get_feature_vsa malloc success
020262: *Oct 27 07:41:14.246: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020263: *Oct 27 07:41:14.246:  cc_get_feature_vsa count is 4
020264: *Oct 27 07:41:14.246: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020265: *Oct 27 07:41:14.246: :FEATURE_VSA attributes are: feature_name:0,feature_time:1189239432,feature_id:4591
020266: *Oct 27 07:41:14.246: //4591/68EAAF0C88C4/CCAPI/ccIFCallSetupRequestPrivate:
020267: *Oct 27 07:41:14.246: //4591/68EAAF0C88C4/CCAPI/ccCallSetContext:
   Context=0x490F14C4
020268: *Oct 27 07:41:14.246: //4590/68EAAF0C88C4/CCAPI/ccSaveDialpeerTag:
020269: *Oct 27 07:41:14.254: ISDN BR1/1/0 Q931: TX -> CALL_PROC pd = 8  callref = 0xCE
        Channel ID i = 0x89
                Exclusive, B1
020270: *Oct 27 07:41:14.262: H245 FS OLC OUTGOING PDU ::=
          sessionID 1
            network 'C0180501'H
            tsapIdentifier 19283
020271: *Oct 27 07:41:14.262: H245 FS OLC OUTGOING ENCODE BUFFER::= 0000000C6013800B05000100C01805014B5380
020272: *Oct 27 07:41:14.262:
020273: *Oct 27 07:41:14.262: H245 FS OLC OUTGOING PDU ::=
          sessionID 1
            network 'C0180501'H
            tsapIdentifier 19282
            network 'C0180501'H
020274: *Oct 27 07:41:14.266: H245 FS OLC OUTGOING ENCODE BUFFER::= 400000060401004C6013801215000100C01805014B5200C01805014B5380
020275: *Oct 27 07:41:14.266:
020276: *Oct 27 07:41:14.266: H245 FS OLC OUTGOING PDU ::=
          sessionID 1
            network 'C0180501'H
020277: *Oct 27 07:41:14.266: H245 FS OLC OUTGOING ENCODE BUFFER::= 0000010D4001800B05000100C01805014B5380
020278: *Oct 27 07:41:14.266:
020279: *Oct 27 07:41:14.266: H245 FS OLC OUTGOING PDU ::=
          sessionID 1
            network 'C0180501'H
            network 'C0180501'H
020280: *Oct 27 07:41:14.266: H245 FS OLC OUTGOING ENCODE BUFFER::= 400001060401004D4001801215000100C01805014B5200C01805014B5380
020281: *Oct 27 07:41:14.266:
020282: *Oct 27 07:41:14.266: H225 NONSTD OUTGOING PDU ::=
      version 1
        iei -95
        rawMesg 'A104038090A31801896C0B018139353631383231...'H
020283: *Oct 27 07:41:14.270: H225 NONSTD OUTGOING ENCODE BUFFER::= 6001010001A180D8A104038090A31801896C0B0181393536313832313232700AA13935353635383830301CB49E810003677464000000A949414D2C0D0A50524E2C6973646E2A2C2C2C0D0A5553492C726174652C632C732C632C310D0A5553492C6C6179312C616C61770D0A544D522C30300D0A43504E2C30342C2C312C3935353635383830300D0A43474E2C30302C2C312C792C322C3935363138323132320D0A4350432C30390D0A4643492C2C2C2C2C2C2C792C0D0A4743492C36386561616630636530643431316466383863343030316531336365326532300D0A0D0A
020284: *Oct 27 07:41:14.270:
020285: *Oct 27 07:41:14.270: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
          sourceAddress
          sourceInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
          activeMC FALSE
          conferenceID '68EAAF0CE0D411DF88C4001E13CE2E20'H
            ip 'C0180501'H
            port 50575
          callIdentifier
            guid '68EB4B34E0D411DF99DC983863021ADA'H
          fastStart
            '0000000C6013800B05000100C01805014B5380'H,
            '0000010D4001800B05000100C01805014B5380'H,
          multipleCalls TRUE
        h245Tunneling TRUE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
          tunnelledProtocolID
              protocolType "gtd"
          messageContent
020286: *Oct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
020292: *Oct 27 07:41:14.398:
020293: *Oct 27 07:41:14.398: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
020294: *Oct 27 07:41:14.402: //4591/68EAAF0C88C4/CCAPI/cc_api_set_called_ccm_detected:
020295: *Oct 27 07:41:14.402: //4591/68EAAF0C88C4/CCAPI/cc_api_call_proceeding:
020296: *Oct 27 07:41:15.170: H225.0 INCOMING ENCODE BUFFER::= 28003880060008914A000522C0B50000120F436973636F43616C6C4D616E6167657200310067957D74E0D411DF99D7983863021ADA05800100010010A001000F0140B5000012088164000400010300
020297: *Oct 27 07:41:15.174:
020298: *Oct 27 07:41:15.174: H225.0 INCOMING PDU ::=
      h323-uu-pdu
        h323-message-body progress :
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            Destination Interface=0x46FAB490, Destination Call Id=4589, Source Call Id=4588,
020317: *Oct 27 07:41:15.178: //4588/6794E14C88C3/CCAPI/cc_api_caps_ind:
020318: *Oct 27 07:41:15.178: //4588/6794E14C88C3/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x848, Call Id1=4588, Call Id2=4589
020319: *Oct 27 07:41:15.182: ISDN BR0/2/1 Q931: TX -> PROGRESS pd = 8  callref = 0xE1
020320: *Oct 27 07:41:16.590: ISDN BR0/3/1 Q931: RX <- SETUP pd = 8  callref = 0x67
        Sending Complete
                Standard = CCITT
        Channel ID i = 0x89
                Exclusive, B1
020321: *Oct 27 07:41:16.594: //-1/6A52C9D888C5/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=956182122
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=955658800
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
020322: *Oct 27 07:41:16.594: //-1/6A52C9D888C5/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x46B67B64, Call Info(
020323: *Oct 27 07:41:16.594: //-1/6A52C9D888C5/CCAPI/ccCheckClipClir:
020324: *Oct 27 07:41:16.594: //-1/6A52C9D888C5/CCAPI/ccCheckClipClir:
020325: *Oct 27 07:41:16.594: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020326: *Oct 27 07:41:16.594: :cc_get_feature_vsa malloc success
020327: *Oct 27 07:41:16.594: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020328: *Oct 27 07:41:16.594:  cc_get_feature_vsa count is 5
020329: *Oct 27 07:41:16.594: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020330: *Oct 27 07:41:16.594: :FEATURE_VSA attributes are: feature_name:0,feature_time:1189239000,feature_id:4592
020331: *Oct 27 07:41:16.594: //4592/6A52C9D888C5/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
020332: *Oct 27 07:41:16.594: //4592/6A52C9D888C5/CCAPI/cc_process_call_setup_ind:
   Event=0x46B07CE8
020333: *Oct 27 07:41:16.598: //4592/6A52C9D888C5/CCAPI/ccCallSetContext:
   Context=0x490F6B94
020334: *Oct 27 07:41:16.598: //4592/6A52C9D888C5/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 4592 with tag 20 to app "_ManagedAppProcess_Default"
020335: *Oct 27 07:41:16.602: //4592/6A52C9D888C5/CCAPI/ccCallProceeding:
020336: *Oct 27 07:41:16.602: //4592/6A52C9D888C5/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=955, Params=0x490E92DC, Progress Indication=NULL(0)
020337: *Oct 27 07:41:16.602: //4592/6A52C9D888C5/CCAPI/ccCheckClipClir:
020338: *Oct 27 07:41:16.602: //4592/6A52C9D888C5/CCAPI/ccCheckClipClir:
020339: *Oct 27 07:41:16.602: //4592/6A52C9D888C5/CCAPI/ccCallSetupRequest:
020340: *Oct 27 07:41:16.602: //4592/6A52C9D888C5/CCAPI/ccCallSetupRequest:
   Guid=6A52C9D8-E0D4-11DF-88C5-001E13CE2E20, Outgoing Dial-peer=955
020341: *Oct 27 07:41:16.602: //4592/6A52C9D888C5/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=956182122
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=955658800
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
020342: *Oct 27 07:41:16.606: //4592/6A52C9D888C5/CCAPI/ccIFCallSetupRequestPrivate:
020343: *Oct 27 07:41:16.606: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020344: *Oct 27 07:41:16.606: :cc_get_feature_vsa malloc success
020345: *Oct 27 07:41:16.606: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020346: *Oct 27 07:41:16.606:  cc_get_feature_vsa count is 6
020347: *Oct 27 07:41:16.606: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020348: *Oct 27 07:41:16.606: :FEATURE_VSA attributes are: feature_name:0,feature_time:1189237920,feature_id:4593
020349: *Oct 27 07:41:16.606: //4593/6A52C9D888C5/CCAPI/ccIFCallSetupRequestPrivate:
020350: *Oct 27 07:41:16.606: //4593/6A52C9D888C5/CCAPI/ccCallSetContext:
   Context=0x490E928C
020351: *Oct 27 07:41:16.606: //4592/6A52C9D888C5/CCAPI/ccSaveDialpeerTag:
020403: *Oct 27 07:41:17.522: MGCP Packet sent to 192.25.98.10:2427--->
NTFY 449158436 *@C2821-DTMSEVPR2.arconet.net MGCP 0.1
X: 0
O:
020404: *Oct 27 07:41:17.534: MGCP Packet received from 192.25.98.10:2427--->
200 449158436
020405: *Oct 27 07:41:17.770: H225.0 INCOMING ENCODE BUFFER::= 28003940060008914A000522C0B50000120F436973636F43616C6C4D616E61676572003100C019620AAD9A0067957D74E0D411DF99D7983863021ADA10A001000F0140B5000012088164000400010300
020406: *Oct 27 07:41:17.770:
020407: *Oct 27 07:41:17.770: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
          h245Address ipAddress :
            ip 'C019620A'H
            port 44442
          callIdentifier
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
020408: *Oct 27 07:41:17.774: H225 NONSTD INCOMING ENCODE BUFFER::= 8164000400010300
020409: *Oct 27 07:41:17.774:
020410: *Oct 27 07:41:17.774: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
020411: *Oct 27 07:41:17.778: //4589/6794E14C88C3/CCAPI/cc_api_call_cut_progress:
   Interface=0x46FAB490, Progress Indication=DESTINATION IS NON ISDN(2), Signal Indication=SIGNAL RINGBACK(1),
   Cause Value=0
020412: *Oct 27 07:41:17.778: //4589/6794E14C88C3/CCAPI/cc_api_call_cut_progress:
020413: *Oct 27 07:41:17.778: //4588/6794E14C88C3/CCAPI/ccCallProgIndProgress:
020414: *Oct 27 07:41:17.778: ISDN BR0/2/1 Q931: TX -> PROGRESS pd = 8  callref = 0xE1
        Progress Ind i = 0x8182 - Destination address is non-ISDN
020415: *Oct 27 07:41:17.790: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= request : terminalCapabilitySet :
      sequenceNumber 1
      protocolIdentifier { 0 0 8 245 0 7 }
      multiplexCapability h2250Capability :
        maximumAudioDelayJitter 20
        receiveMultipointCapability
          multicastCapability FALSE
          multiUniCastConference FALSE
          mediaDistributionCapability
              centralizedControl FALSE
              distributedControl FALSE
020467: *Oct 27 07:41:17.866: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
020468: *Oct 27 07:41:17.866: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
020469: *Oct 27 07:41:18.874: ISDN BR0/3/0 Q931: RX <- SETUP pd = 8  callref = 0x0A
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x89
                Exclusive, B1
        Calling Party Number i = 0x0181, '956182122'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0xA1, '955658800'
                Plan:ISDN, Type:National
020470: *Oct 27 07:41:18.882: //-1/6BAFE8A388C6/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=956182122
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=955658800
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
020471: *Oct 27 07:41:18.882: //-1/6BAFE8A388C6/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x472FA6C4, Call Info(
   Called Number=955658800(TON=National, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
020472: *Oct 27 07:41:18.882: //-1/6BAFE8A388C6/CCAPI/ccCheckClipClir:
020473: *Oct 27 07:41:18.882: //-1/6BAFE8A388C6/CCAPI/ccCheckClipClir:
020474: *Oct 27 07:41:18.882: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020475: *Oct 27 07:41:18.882: :cc_get_feature_vsa malloc success
020476: *Oct 27 07:41:18.882: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020477: *Oct 27 07:41:18.882:  cc_get_feature_vsa count is 7
020478: *Oct 27 07:41:18.882: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020479: *Oct 27 07:41:18.882: :FEATURE_VSA attributes are: feature_name:0,feature_time:1189236624,feature_id:4594
020480: *Oct 27 07:41:18.882: //4594/6BAFE8A388C6/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Called Number=955658800(TON=National, NPI=ISDN))
020481: *Oct 27 07:41:18.882: //4594/6BAFE8A388C6/CCAPI/cc_process_call_setup_ind:
   Event=0x46B07CE8
020482: *Oct 27 07:41:18.886: //4594/6BAFE8A388C6/CCAPI/ccCallSetContext:
   Context=0x490F31B4
020483: *Oct 27 07:41:18.886: //4594/6BAFE8A388C6/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 4594 with tag 20 to app "_ManagedAppProcess_Default"8164000400010300
020524: *Oct 27 07:41:19.054:
020525: *Oct 27 07:41:19.054: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
020526: *Oct 27 07:41:19.054: //4595/6BAFE8A388C6/CCAPI/cc_api_set_called_ccm_detected:
   CallInfo(called ccm detected=TRUE ccmVersion 3)
020527: *Oct 27 07:41:19.054: //4595/6BAFE8A388C6/CCAPI/cc_api_call_proceeding:
   Interface=0x46FAB490, Progress Indication=NULL(0)
020528: *Oct 27 07:41:19.774: H225.0 INCOMING ENCODE BUFFER::= 28003880060008914A000522C0B50000120F436973636F43616C6C4D616E616765720031006A536698E0D411DF99E1983863021ADA05800100010010A001000F0140B5000012088164000400010300
020529: *Oct 27 07:41:19.774:
020530: *Oct 27 07:41:19.774: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
          callIdentifier
            guid '6A536698E0D411DF99E1983863021ADA'H
          multipleCalls FALSE
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
020531: *Oct 27 07:41:19.778: H225 NONSTD INCOMING ENCODE BUFFER::= 8164000400010300
020532: *Oct 27 07:41:19.778:
020533: *Oct 27 07:41:19.778: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
020534: *Oct 27 07:41:19.778: //4593/6A52C9D888C5/CCAPI/cc_api_call_cut_progress:
   Cause Value=0
020535: *Oct 27 07:41:19.778: //4593/6A52C9D888C5/CCAPI/cc_api_call_cut_progress:
020536: *Oct 27 07:41:19.778: //4592/6A52C9D888C5/CCAPI/ccCallCutProgress:
020537: *Oct 27 07:41:19.778: //4592/6A52C9D888C5/CCAPI/ccCallCutProgress:
020538: *Oct 27 07:41:19.778: //4592/6A52C9D888C5/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=4592
020539: *Oct 27 07:41:19.778: //4592/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x491B1AC8, callID1=0x11F0, callID2=0x11F1, tag=0x0)
020540: *Oct 27 07:41:19.778: //4592/6A52C9D888C5/CCAPI/ccConferenceCreate:
   Conference Id=0x491B1AC8, Call Id1=4592, Call Id2=4593, Tag=0x0
020541: *Oct 27 07:41:19.778: //4592/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x84A, Source Interface=0x46B67B64, Source Call Id=4592,
   Destination Call Id=4593, Disposition=0x0, Tag=0xFFFFFFFF
020542: *Oct 27 07:41:19.778: //4593/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
020543: *Oct 27 07:41:19.778: cc_api_get_xcode_stream : 4369
020544: *Oct 27 07:41:19.778: //4593/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x84A, Source Interface=0x46FAB490, Source Call Id=4593,
   Destination Call Id=4592, Disposition=0x0, Tag=0x0
020614: *Oct 27 07:41:20.222: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
020615: *Oct 27 07:41:20.222: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
020616: *Oct 27 07:41:20.766: H225.0 INCOMING ENCODE BUFFER::= 28003940060008914A000522C0B50000120F436973636F43616C6C4D616E61676572003100C018050149880067957D74E0D411DF99D7983863021ADA10A001000F0140B5000012088164000400010300
020617: *Oct 27 07:41:20.766:
020618: *Oct 27 07:41:20.766: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
            ip 'C0180501'H
            port 18824
          callIdentifier
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
020619: *Oct 27 07:41:20.770: H225 NONSTD INCOMING ENCODE BUFFER::= 8164000400010300
020620: *Oct 27 07:41:20.770:
020621: *Oct 27 07:41:20.770: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
020622: *Oct 27 07:41:20.774: //4589/6794E14C88C3/CCAPI/cc_api_call_cut_progress:
   Cause Value=0
020623: *Oct 27 07:41:20.774: //4589/6794E14C88C3/CCAPI/cc_api_call_cut_progress:
020624: *Oct 27 07:41:20.774: //4588/6794E14C88C3/CCAPI/ccCallProgIndProgress:
020625: *Oct 27 07:41:20.774: ISDN BR0/2/1 Q931: TX -> PROGRESS pd = 8  callref = 0xE1
020626: *Oct 27 07:41:21.114: ISDN BR0/2/1 Q931: RX <- SETUP pd = 8  callref = 0x1D
        Sending Complete
                Standard = CCITT
        Channel ID i = 0x8A
                Exclusive, B2
020627: *Oct 27 07:41:21.118: //-1/6D05B6FC88C7/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=956182122
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=955658800
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
020628: *Oct 27 07:41:21.122: //-1/6D05B6FC88C7/CCAPI/cc_api_call_setup_ind_common:
020629: *Oct 27 07:41:21.122: //-1/6D05B6FC88C7/CCAPI/ccCheckClipClir:
020630: *Oct 27 07:41:21.122: //-1/6D05B6FC88C7/CCAPI/ccCheckClipClir:
020631: *Oct 27 07:41:21.122: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020632: *Oct 27 07:41:21.122: :cc_get_feature_vsa malloc success
020633: *Oct 27 07:41:21.122: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020634: *Oct 27 07:41:21.122:  cc_get_feature_vsa count is 9
020635: *Oct 27 07:41:21.122: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020636: *Oct 27 07:41:21.122: :FEATURE_VSA attributes are: feature_name:0,feature_time:1189236408,feature_id:4596
020637: *Oct 27 07:41:21.122: //4596/6D05B6FC88C7/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
020638: *Oct 27 07:41:21.122: //4596/6D05B6FC88C7/CCAPI/cc_process_call_setup_ind:
   Event=0x46B07CE8
020639: *Oct 27 07:41:21.122: //4596/6D05B6FC88C7/CCAPI/ccCallSetContext:
   Context=0x490F233C
020640: *Oct 27 07:41:21.122: //4596/6D05B6FC88C7/CCAPI/cc_process_call_setup_ind:
   8164000400010300
020681: *Oct 27 07:41:21.330:
020682: *Oct 27 07:41:21.330: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
020683: *Oct 27 07:41:21.330: //4597/6D05B6FC88C7/CCAPI/cc_api_set_called_ccm_detected:
020684: *Oct 27 07:41:21.330: //4597/6D05B6FC88C7/CCAPI/cc_api_call_proceeding:
020685: *Oct 27 07:41:22.058: H225.0 INCOMING ENCODE BUFFER::= 28003880060008914A000522C0B50000120F436973636F43616C6C4D616E616765720031006BB084CBE0D411DF99E6983863021ADA05800100010010A001000F0140B5000012088164000400010300
020686: *Oct 27 07:41:22.058:
020687: *Oct 27 07:41:22.058: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
          callIdentifier
            guid '6BB084CBE0D411DF99E6983863021ADA'H
          multipleCalls FALSE
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
020688: *Oct 27 07:41:22.062: H225 NONSTD INCOMING ENCODE BUFFER::= 8164000400010300
020689: *Oct 27 07:41:22.062:
020690: *Oct 27 07:41:22.062: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
020691: *Oct 27 07:41:22.062: //4595/6BAFE8A388C6/CCAPI/cc_api_call_cut_progress:
   Interface=0x46FAB490, Progress Indication=NOT END TO END ISDN(1), Signal Indication=SIGNAL RINGBACK(1),
   Cause Value=0
020692: *Oct 27 07:41:22.062: //4595/6BAFE8A388C6/CCAPI/cc_api_call_cut_progress:
020693: *Oct 27 07:41:22.062: //4594/6BAFE8A388C6/CCAPI/ccCallCutProgress:
   Progress Indication=NOT END TO END ISDN(1), Signal Indication=SIGNAL RINGBACK(1), Cause Value=0
   Voice Call Send Alert=FALSE, Call Entry(AlertSent=FALSE)
020694: *Oct 27 07:41:22.062: //4594/6BAFE8A388C6/CCAPI/ccCallCutProgress:
020695: *Oct 27 07:41:22.062: //4594/6BAFE8A388C6/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=4594
020696: *Oct 27 07:41:22.062: //4594/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x491B1BA0, callID1=0x11F2, callID2=0x11F3, tag=0x0)
020697: *Oct 27 07:41:22.062: //4594/6BAFE8A388C6/CCAPI/ccConferenceCreate:
   Conference Id=0x491B1BA0, Call Id1=4594, Call Id2=4595, Tag=0x0
020698: *Oct 27 07:41:22.062: //4594/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x84B, Source Interface=0x472FA6C4, Source Call Id=4594,
   Destination Call Id=4595, Disposition=0x0, Tag=0xFFFFFFFF
020699: *Oct 27 07:41:22.062: //4595/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
020700: *Oct 27 07:41:22.062: cc_api_get_xcode_stream : 4369
020701: *Oct 27 07:41:22.062: //4595/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x84B, Source Interface=0x46FAB490, Source Call Id=4595,
   Destination Call Id=4594, Disposition=0x0, Tag=0x0
020702: *Oct 27 07:41:22.062: //4594/6BAFE8A388C6/CCAPI/cc_generic_bridge_done:
020703: *Oct 27 07:41:22.062: //4594/6BAFE8A388C6/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x84B, Destination Call Id=4595)
020704: *Oct 27 07:41:22.062: //4595/6BAFE8A388C6/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x84B, Destination Call Id=4594)
020705: *Oct 27 07:41:22.062: //4594/6BAFE8A388C6/CCAPI/cc_api_caps_ind:
   Destination Interface=0x46FAB490, Destination Call Id=4595, Source Call Id=4594,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
020706: *Oct 27 07:41:22.062: //4594/6BAFE8A388C6/CCAPI/cc_api_caps_ind:
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=250(ms), Fax Nom=300(ms))
020707: *Oct 27 07:41:22.066: //4594/6BAFE8A388C6/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x84B, Call Id1=4594, Call Id2=4595
020708: *Oct 27 07:41:22.066: ISDN BR0/3/0 Q931: TX -> PROGRESS pd = 8  callref = 0x8A
        Progress Ind i = 0x8181 - Call not end-to-end ISDN, may have in-band info
020709: *Oct 27 07:41:22.590: H225.0 INCOMING ENCODE BUFFER::= 28003940060008914A000522C0B50000120F436973636F43616C6C4D616E61676572003100C019620AADA0006A536698E0D411DF99E1983863021ADA10A001000F0140B5000012088164000400010300
020710: *Oct 27 07:41:22.594:
020711: *Oct 27 07:41:22.594: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
            ip 'C019620A'H
            port 44448
          callIdentifier
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
020712: *Oct 27 07:41:22.598: H225 NONSTD INCOMING ENCODE BUFFER::= 8164000400010300
020713: *Oct 27 07:41:22.598:
020714: *Oct 27 07:41:22.598: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
020715: *Oct 27 07:41:22.598: //4593/6A52C9D888C5/CCAPI/cc_api_call_cut_progress:
   Cause Value=0
020716: *Oct 27 07:41:22.598: //4593/6A52C9D888C5/CCAPI/cc_api_call_cut_progress:
   Call Entry(Responsed=TRUE)
020717: *Oct 27 07:41:22.598: //4592/6A52C9D888C5/CCAPI/ccCallProgIndProgress:
020718: *Oct 27 07:41:22.602: ISDN BR0/3/1 Q931: TX -> PROGRESS pd = 8  callref = 0xE7
020719: *Oct 27 07:41:22.610: H245 MSC OUTGOING PDU ::=
      sequenceNumber 1
              centralizedAudio FALSE
              distributedAudio FALSE
              centralizedVideo FALSE
              distributedVideo FALSE
        transmitMultipointCapability
        receiveAndTransmitMultipointCapability
        mcCapability
          centralizedConferenceMC FALSE
          decentralizedConferenceMC FALSE
        rtcpVideoControlCapability FALSE
        mediaPacketizationCapability
          h261aVideoPacketization FALSE
        logicalChannelSwitchingCapability FALSE
        t120DynamicPortCapability FALSE
      capabilityTable
          capabilityTableEntryNumber 34
          capability receiveRTPAudioTelephonyEventCapability :
            dynamicRTPPayloadType 101
            audioTelephoneEvent "0-16"
          capabilityTableEntryNumber 25
          capability receiveAndTransmitDataApplicationCapability :
            application nonStandard :
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              data '52747044746D6652656C6179'H
            maxBitRate 0
          capabilityTableEntryNumber 31
          capability receiveUserInputCapability : hookflash : NULL
          capabilityTableEntryNumber 30
          capability receiveUserInputCapability : dtmf : NULL
          capabilityTableEntryNumber 27
          capability receiveUserInputCapability : basicString :
020842: *Oct 27 07:41:23.574: //4588/6794E14C88C3/CCAPI/ccCallProgIndProgress:
020843: *Oct 27 07:41:23.574: ISDN BR0/2/1 Q931: TX -> PROGRESS pd = 8  callref = 0xE1
020844: *Oct 27 07:41:23.638: H225.0 INCOMING ENCODE BUFFER::= 2180060008914A000522C0B50000120F436973636F43616C6C4D616E6167657200310110C011006E6C9978E0D411DF99F0983863021ADA0100010010A001000F0140B5000012088164000400010300
020845: *Oct 27 07:41:23.638:
020846: *Oct 27 07:41:23.638: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
          callIdentifier
            guid '6E6C9978E0D411DF99F0983863021ADA'H
          multipleCalls FALSE
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
020847: *Oct 27 07:41:23.642: H225 NONSTD INCOMING ENCODE BUFFER::= 8164000400010300
020848: *Oct 27 07:41:23.642:
020849: *Oct 27 07:41:23.642: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
020850: *Oct 27 07:41:23.642: //4599/6E6C997888C8/CCAPI/cc_api_set_called_ccm_detected:
020851: *Oct 27 07:41:23.642: //4599/6E6C997888C8/CCAPI/cc_api_call_proceeding:
020852: *Oct 27 07:41:24.334: H225.0 INCOMING ENCODE BUFFER::= 28003880060008914A000522C0B50000120F436973636F43616C6C4D616E616765720031006D05B6FCE0D411DF99EB983863021ADA05800100010010A001000F0140B5000012088164000400010300
020853: *Oct 27 07:41:24.334:
020854: *Oct 27 07:41:24.334: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
          callIdentifier
            guid '6D05B6FCE0D411DF99EB983863021ADA'H
          multipleCalls FALSE
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
020855: *Oct 27 07:41:24.338: H225 NONSTD INCOMING ENCODE BUFFER::= 8164000400010300
020856: *Oct 27 07:41:24.338:
020857: *Oct 27 07:41:24.338: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
020858: *Oct 27 07:41:24.338: //4597/6D05B6FC88C7/CCAPI/cc_api_call_cut_progress:
   Cause Value=0
020859: *Oct 27 07:41:24.338: //4597/6D05B6FC88C7/CCAPI/cc_api_call_cut_progress:
020860: *Oct 27 07:41:24.338: //4596/6D05B6FC88C7/CCAPI/ccCallCutProgress:
020861: *Oct 27 07:41:24.338: //4596/6D05B6FC88C7/CCAPI/ccCallCutProgress:
020862: *Oct 27 07:41:24.338: //4596/6D05B6FC88C7/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=4596
020863: *Oct 27 07:41:24.338: //4596/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x491B1D08, callID1=0x11F4, callID2=0x11F5, tag=0x0)
020864: *Oct 27 07:41:24.338: //4596/6D05B6FC88C7/CCAPI/ccConferenceCreate:
   Conference Id=0x491B1D08, Call Id1=4596, Call Id2=4597, Tag=0x0
020865: *Oct 27 07:41:24.338: //4596/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x84C, Source Interface=0x46B585D0, Source Call Id=4596,
   Destination Call Id=4597, Disposition=0x0, Tag=0xFFFFFFFF
020866: *Oct 27 07:41:24.342: //4597/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
020867: *Oct 27 07:41:24.342: cc_api_get_xcode_stream : 4369
020868: *Oct 27 07:41:24.342: //4597/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x84C, Source Interface=0x46FAB490, Source Call Id=4597,
   Destination Call Id=4596, Disposition=0x0, Tag=0x0
020869: *Oct 27 07:41:24.342: //4596/6D05B6FC88C7/CCAPI/cc_generic_bridge_done:
020870: *Oct 27 07:41:24.342: //4596/6D05B6FC88C7/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x84C, Destination Call Id=4597)
020871: *Oct 27 07:41:24.342: //4597/6D05B6FC88C7/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x84C, Destination Call Id=4596)
020872: *Oct 27 07:41:24.342: //4596/6D05B6FC88C7/CCAPI/cc_api_caps_ind:
   Destination Interface=0x46FAB490, Destination Call Id=4597, Source Call Id=4596,
020873: *Oct 27 07:41:24.342: //4596/6D05B6FC88C7/CCAPI/cc_api_caps_ind:
020874: *Oct 27 07:41:24.342: //4596/6D05B6FC88C7/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x84C, Call Id1=4596, Call Id2=4597
020875: *Oct 27 07:41:24.342: ISDN BR0/2/1 Q931: TX -> PROGRESS pd = 8  callref = 0x9D
020876: *Oct 27 07:41:24.698: H225.0 INCOMING ENCODE BUFFER::= 28003940060008914A000522C0B50000120F436973636F43616C6C4D616E61676572003100C019620AADA2006BB084CBE0D411DF99E6983863021ADA10A001000F0140B5000012088164000400010300
020877: *Oct 27 07:41:24.698:
020878: *Oct 27 07:41:24.698: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
            ip 'C019620A'H
            port 44450
          callIdentifier
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
020879: *Oct 27 07:41:24.702: H225 NONSTD INCOMING ENCODE BUFFER::= 8164000400010300
020880: *Oct 27 07:41:24.702:
020881: *Oct 27 07:41:24.702: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
020882: *Oct 27 07:41:24.702: //4595/6BAFE8A388C6/CCAPI/cc_api_call_cut_progress:
   Cause Value=0
020883: *Oct 27 07:41:24.706: //4595/6BAFE8A388C6/CCAPI/cc_api_call_cut_progress:
020884: *Oct 27 07:41:24.706: //4594/6BAFE8A388C6/CCAPI/ccCallProgIndProgress:
020885: *Oct 27 07:41:24.710: ISDN BR0/3/0 Q931: TX -> PROGRESS pd = 8  callref = 0x8A
020886: *Oct 27 07:41:24.718: H245 MSC OUTGOING PDU ::=
      sequenceNumber 1
        mcCapability
      capabilityTable
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            maxBitRate 0
          capability receiveUserInputCapability : basicString : NULL
          capabilityTableEntryNumber 6
          capability receiveAudioCapability : g729AnnexA : 2
          capabilityTableEntryNumber 5
          capability receiveAudioCapability : g729 : 2
          capability receiveAudioCapability : g711Ulaw64k : 20
      capabilityDescriptors
          capabilityDescriptorNumber 1
          simultaneousCapabilities
              3,
              5,
              6
              34,
              30,
              27,
              25
              31
020887: *Oct 27 07:41:24.726: H245 MSC OUTGOING ENCODE BUFFER::= 027001060008817500078013800014000100000100000100000CC001000100078000218A061404302D31368000184810B50000120C52747044746D6652656C6179000080001E83015080001D83014080001A83011080000522C00180000422800180000220C0130080010202000200040005030021001D001A001800001E
020888: *Oct 27 07:41:24.726:
020889: *Oct 27 07:41:24.730: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= request : masterSlaveDetermination :
      terminalType 60
      statusDeterminationNumber 6542
020890: *Oct 27 07:41:24.730: H245 MSC OUTGOING ENCODE BUFFER::= 01003C40198E
020891: *Oct 27 07:41:24.730:
020892: *Oct 27 07:41:24.746: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 71
020893: *Oct 27 07:41:24.746: H245 MSC INCOMING ENCODE BUFFER::= 0270010600088175000A801380003C000100000100000100000CC0010001000380000022801580000185014080000285011080002B85015000800002000000010001000200002B
020894: *Oct 27 07:41:24.746:
020895: *Oct 27 07:41:24.746: H245 MSC INCOMING PDU ::=
020948: *Oct 27 07:41:25.422: //4592/6A52C9D888C5/CCAPI/ccCallProgIndProgress:
020949: *Oct 27 07:41:25.422: ISDN BR0/3/1 Q931: TX -> PROGRESS pd = 8  callref = 0xE7
020950: *Oct 27 07:41:25.746: H225.0 INCOMING ENCODE BUFFER::= 28003940060008914A000522C0B50000120F436973636F43616C6C4D616E61676572003100C01805014B520068EB4B34E0D411DF99DC983863021ADA10A001000F0140B5000012088164000400010300
020951: *Oct 27 07:41:25.746:
020952: *Oct 27 07:41:25.746: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
            ip 'C0180501'H
            port 19282
          callIdentifier
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
020953: *Oct 27 07:41:25.750: H225 NONSTD INCOMING ENCODE BUFFER::= 8164000400010300
020954: *Oct 27 07:41:25.750:
020955: *Oct 27 07:41:25.750: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
020956: *Oct 27 07:41:25.750: //4591/68EAAF0C88C4/CCAPI/cc_api_call_cut_progress:
   Cause Value=0
020957: *Oct 27 07:41:25.750: //4591/68EAAF0C88C4/CCAPI/cc_api_call_cut_progress:
020958: *Oct 27 07:41:25.754: //4590/68EAAF0C88C4/CCAPI/ccCallProgIndProgress:
020959: *Oct 27 07:41:25.754: ISDN BR1/1/0 Q931: TX -> PROGRESS pd = 8  callref = 0xCE
020960: *Oct 27 07:41:25.786: ISDN BR0/3/1 Q931: RX <- SETUP pd = 8  callref = 0x1A
        Sending Complete
                Standard = CCITT
        Channel ID i = 0x8A
                Exclusive, B2
020961: *Oct 27 07:41:25.790: //-1/6FCE9A1C88C9/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=956182122
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=955658800
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
020962: *Oct 27 07:41:25.794: //-1/6FCE9A1C88C9/CCAPI/cc_api_call_setup_ind_common:
020963: *Oct 27 07:41:25.794: //-1/6FCE9A1C88C9/CCAPI/ccCheckClipClir:
020964: *Oct 27 07:41:25.794: //-1/6FCE9A1C88C9/CCAPI/ccCheckClipClir:
020965: *Oct 27 07:41:25.794: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020966: *Oct 27 07:41:25.794: :cc_get_feature_vsa malloc success
020967: *Oct 27 07:41:25.794: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020968: *Oct 27 07:41:25.794:  cc_get_feature_vsa count is 13
020969: *Oct 27 07:41:25.794: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020970: *Oct 27 07:41:25.794: :FEATURE_VSA attributes are: feature_name:0,feature_time:1189238784,feature_id:4600
020971: *Oct 27 07:41:25.794: //4600/6FCE9A1C88C9/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
020972: *Oct 27 07:41:25.794: //4600/6FCE9A1C88C9/CCAPI/cc_process_call_setup_ind:
   Event=0x46B07CE8
020973: *Oct 27 07:41:25.798: //4600/6FCE9A1C88C9/CCAPI/ccCallSetContext:
   Context=0x490EA104
020974: *Oct 27 07:41:25.798: //4600/6FCE9A1C88C9/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 4600 with tag 20 to app "_ManagedAppProcess_Default"
020975: *Oct 27 07:41:25.802: //4600/6FCE9A1C88C9/CCAPI/ccCallProceeding:
020976: *Oct 27 07:41:25.806: //4600/6FCE9A1C88C9/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=955, Params=0x490F974C, Progress Indication=NULL(0)
020977: *Oct 27 07:41:25.806: //4600/6FCE9A1C88C9/CCAPI/ccCheckClipClir:
020978: *Oct 27 07:41:25.806: //4600/6FCE9A1C88C9/CCAPI/ccCheckClipClir:
020979: *Oct 27 07:41:25.806: //4600/6FCE9A1C88C9/CCAPI/ccCallSetupRequest:
   Destination Pattern=955658..., Called Number=955658800, Digit Strip=FALSE
020980: *Oct 27 07:41:25.806: //4600/6FCE9A1C88C9/CCAPI/ccCallSetupRequest:
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=6FCE9A1C-E0D4-11DF-88C9-001E13CE2E20, Outgoing Dial-peer=955
020981: *Oct 27 07:41:25.806: //4600/6FCE9A1C88C9/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=956182122
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=955658800
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
020982: *Oct 27 07:41:25.806: //4600/6FCE9A1C88C9/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x46FAB490, Interface Type=1, Destination=, Mode=0x0,
   Called Number=955658800(TON=National, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=955, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
020983: *Oct 27 07:41:25.806: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
020984: *Oct 27 07:41:25.806: :cc_get_feature_vsa malloc success
021027: *Oct 27 07:41:26.110: //4588/6794E14C88C3/CCAPI/ccCallProgIndProgress:
021028: *Oct 27 07:41:26.114: ISDN BR0/2/1 Q931: TX -> PROGRESS pd = 8  callref = 0xE1
021029: *Oct 27 07:41:26.650: H225.0 INCOMING ENCODE BUFFER::= 28003880060008914A000522C0B50000120F436973636F43616C6C4D616E616765720031006E6C9978E0D411DF99F0983863021ADA05800100010010A001000F0140B5000012088164000400010300
021030: *Oct 27 07:41:26.650:
021031: *Oct 27 07:41:26.650: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
          callIdentifier
          multipleCalls FALSE
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
021032: *Oct 27 07:41:26.654: H225 NONSTD INCOMING ENCODE BUFFER::= 8164000400010300
021033: *Oct 27 07:41:26.654:
021034: *Oct 27 07:41:26.654: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
021035: *Oct 27 07:41:26.654: //4599/6E6C997888C8/CCAPI/cc_api_call_cut_progress:
   Cause Value=0
021036: *Oct 27 07:41:26.654: //4599/6E6C997888C8/CCAPI/cc_api_call_cut_progress:
021037: *Oct 27 07:41:26.658: //4598/6E6C997888C8/CCAPI/ccCallCutProgress:
021038: *Oct 27 07:41:26.658: //4598/6E6C997888C8/CCAPI/ccCallCutProgress:
021039: *Oct 27 07:41:26.658: //4598/6E6C997888C8/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=4598
021040: *Oct 27 07:41:26.658: //4598/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x491B1C30, callID1=0x11F6, callID2=0x11F7, tag=0x0)
021041: *Oct 27 07:41:26.658: //4598/6E6C997888C8/CCAPI/ccConferenceCreate:
   Conference Id=0x491B1C30, Call Id1=4598, Call Id2=4599, Tag=0x0
021042: *Oct 27 07:41:26.658: //4598/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x84D, Source Interface=0x47319490, Source Call Id=4598,
   Destination Call Id=4599, Disposition=0x0, Tag=0xFFFFFFFF
021043: *Oct 27 07:41:26.658: //4599/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
021044: *Oct 27 07:41:26.658: cc_api_get_xcode_stream : 4369
021045: *Oct 27 07:41:26.658: //4599/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x84D, Source Interface=0x46FAB490, Source Call Id=4599,
   Destination Call Id=4598, Disposition=0x0, Tag=0x0
021046: *Oct 27 07:41:26.658: //4598/6E6C997888C8/CCAPI/cc_generic_bridge_done:
021047: *Oct 27 07:41:26.658: //4598/6E6C997888C8/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x84D, Destination Call Id=4599)
021048: *Oct 27 07:41:26.658: //4599/6E6C997888C8/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x84D, Destination Call Id=4598)
021049: *Oct 27 07:41:26.658: //4598/6E6C997888C8/CCAPI/cc_api_caps_ind:
   Destination Interface=0x46FAB490, Destination Call Id=4599, Source Call Id=4598,
021050: *Oct 27 07:41:26.658: //4598/6E6C997888C8/CCAPI/cc_api_caps_ind:
021051: *Oct 27 07:41:26.658: //4598/6E6C997888C8/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x84D, Call Id1=4598, Call Id2=4599
021052: *Oct 27 07:41:26.662: ISDN BR1/1/0 Q931: TX -> PROGRESS pd = 8  callref = 0x8E
021053: *Oct 27 07:41:27.010: H225.0 INCOMING ENCODE BUFFER::= 28003940060008914A000522C0B50000120F436973636F43616C6C4D616E61676572003100C019620AADA3006D05B6FCE0D411DF99EB983863021ADA10A001000F0140B5000012088164000400010300
021054: *Oct 27 07:41:27.010:
021055: *Oct 27 07:41:27.010: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
            ip 'C019620A'H
            port 44451
          callIdentifier
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
021056: *Oct 27 07:41:27.014: H225 NONSTD INCOMING ENCODE BUFFER::= 8164000400010300
021057: *Oct 27 07:41:27.014:
021058: *Oct 27 07:41:27.014: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
021059: *Oct 27 07:41:27.014: //4597/6D05B6FC88C7/CCAPI/cc_api_call_cut_progress:
   Cause Value=0
021060: *Oct 27 07:41:27.014: //4597/6D05B6FC88C7/CCAPI/cc_api_call_cut_progress:
021061: *Oct 27 07:41:27.014: //4596/6D05B6FC88C7/CCAPI/ccCallProgIndProgress:
021062: *Oct 27 07:41:27.018: ISDN BR0/2/1 Q931: TX -> PROGRESS pd = 8  callref = 0x9D
021063: *Oct 27 07:41:27.026: H245 MSC OUTGOING PDU ::=
      sequenceNumber 1
        mcCapability
      capabilityTable
021125: *Oct 27 07:41:27.634: //4594/6BAFE8A388C6/CCAPI/ccCallProgIndProgress:
021126: *Oct 27 07:41:27.634: ISDN BR0/3/0 Q931: TX -> PROGRESS pd = 8  callref = 0x8A
021127: *Oct 27 07:41:28.006: H225.0 INCOMING ENCODE BUFFER::= 28003940060008914A000522C0B50000120F436973636F43616C6C4D616E61676572003100C018050148A0006A536698E0D411DF99E1983863021ADA10A001000F0140B5000012088164000400010300
021128: *Oct 27 07:41:28.006:
021129: *Oct 27 07:41:28.006: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
            ip 'C0180501'H
            port 18592
          callIdentifier
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
021130: *Oct 27 07:41:28.010: H225 NONSTD INCOMING ENCODE BUFFER::= 8164000400010300
021131: *Oct 27 07:41:28.010:
021132: *Oct 27 07:41:28.010: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
021133: *Oct 27 07:41:28.010: //4593/6A52C9D888C5/CCAPI/cc_api_call_cut_progress:
   Cause Value=0
021134: *Oct 27 07:41:28.010: //4593/6A52C9D888C5/CCAPI/cc_api_call_cut_progress:
021135: *Oct 27 07:41:28.010: //4592/6A52C9D888C5/CCAPI/ccCallProgIndProgress:
021136: *Oct 27 07:41:28.014: ISDN BR0/3/1 Q931: TX -> PROGRESS pd = 8  callref = 0xE7
021137: *Oct 27 07:41:28.066: ISDN BR0/3/0 Q931: RX <- SETUP pd = 8  callref = 0x09
        Sending Complete
                Standard = CCITT
        Channel ID i = 0x8A
                Exclusive, B2
021138: *Oct 27 07:41:28.070: //-1/7129E5DC88CA/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=956182122
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=955658800
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
021139: *Oct 27 07:41:28.070: //-1/7129E5DC88CA/CCAPI/cc_api_call_setup_ind_common:
021140: *Oct 27 07:41:28.070: //-1/7129E5DC88CA/CCAPI/ccCheckClipClir:
021141: *Oct 27 07:41:28.070: //-1/7129E5DC88CA/CCAPI/ccCheckClipClir:
021142: *Oct 27 07:41:28.074: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
021143: *Oct 27 07:41:28.074: :cc_get_feature_vsa malloc success
021144: *Oct 27 07:41:28.074: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
021145: *Oct 27 07:41:28.074:  cc_get_feature_vsa count is 15
021146: *Oct 27 07:41:28.074: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
021147: *Oct 27 07:41:28.074: :FEATURE_VSA attributes are: feature_name:0,feature_time:1189237488,feature_id:4602
021148: *Oct 27 07:41:28.074: //4602/7129E5DC88CA/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
021149: *Oct 27 07:41:28.074: //4602/7129E5DC88CA/CCAPI/cc_process_call_setup_ind:
   Event=0x46B07CE8
021150: *Oct 27 07:41:28.074: //4602/7129E5DC88CA/CCAPI/ccCallSetContext:
   Context=0x490F4EA4
021151: *Oct 27 07:41:28.078: //4602/7129E5DC88CA/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 4602 with tag 20 to app "_ManagedAppProcess_Default"
021152: *Oct 27 07:41:28.082: //4602/7129E5DC88CA/CCAPI/ccCallProceeding:
021153: *Oct 27 07:41:28.082: //4602/7129E5DC88CA/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=955, Params=0x490EBE44, Progress Indication=NULL(0)
021154: *Oct 27 07:41:28.086: //4602/7129E5DC88CA/CCAPI/ccCheckClipClir:
021155: *Oct 27 07:41:28.086: //4602/7129E5DC88CA/CCAPI/ccCheckClipClir:
021156: *Oct 27 07:41:28.086: //4602/7129E5DC88CA/CCAPI/ccCallSetupRequest:
021157: *Oct 27 07:41:28.086: //4602/7129E5DC88CA/CCAPI/ccCallSetupRequest:
   Guid=7129E5DC-E0D4-11DF-88CA-001E13CE2E20, Outgoing Dial-peer=955
021158: *Oct 27 07:41:28.086: //4602/7129E5DC88CA/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=956182122
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=955658800
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
021159: *Oct 27 07:41:28.086: //4602/7129E5DC88CA/CCAPI/ccIFCallSetupRequestPrivate:
021160: *Oct 27 07:41:28.086: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
021161: *Oct 27 07:41:28.086: :cc_get_feature_vsa malloc success
021162: *Oct 27 07:41:28.086: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
021163: *Oct 27 07:41:28.086:  cc_get_feature_vsa count is 16
021164: *Oct 27 07:41:28.086: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
021165: *Oct 27 07:41:28.086: :FEATURE_VSA attributes are: feature_name:0,feature_time:1189237272,feature_id:4603
021166: *Oct 27 07:41:28.086: //4603/7129E5DC88CA/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
021167: *Oct 27 07:41:28.086: //4603/7129E5DC88CA/CCAPI/ccCallSetContext:
   Context=0x490EBDF4
021168: *Oct 27 07:41:28.086: //4602/7129E5DC88CA/CCAPI/ccSaveDialpeerTag:
021169: *Oct 27 07:41:28.098: ISDN BR0/3/0 Q931: TX -> CALL_PROC pd = 8  callref = 0x89
        Channel ID i = 0x8A
                Exclusive, B2
021170: *Oct 27 07:41:28.102: H245 FS OLC OUTGOING PDU ::=
          sessionID 1
            network 'C0180501'H
            tsapIdentifier 16791
021171: *Oct 27 07:41:28.106: H245 FS OLC OUTGOING ENCODE BUFFER::= 0000000C6013800B05000100C0180501419780
021172: *Oct 27 07:41:28.106:
021173: *Oct 27 07:41:28.106: H245 FS OLC OUTGOING PDU ::=
          sessionID 1
            network 'C0180501'H
            tsapIdentifier
021204: *Oct 27 07:41:28.350: //4590/68EAAF0C88C4/CCAPI/ccCallProgIndProgress:
021205: *Oct 27 07:41:28.350: ISDN BR1/1/0 Q931: TX -> PROGRESS pd = 8  callref = 0xCE
021206: *Oct 27 07:41:28.678: H225.0 INCOMING ENCODE BUFFER::= 28003940060008914A000522C0B50000120F436973636F43616C6C4D616E61676572003100C018050149880067957D74E0D411DF99D7983863021ADA10A001000F0140B5000012088164000400010300
021207: *Oct 27 07:41:28.678:
021208: *Oct 27 07:41:28.678: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
            ip 'C0180501'H
            port 18824
          callIdentifier
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
021209: *Oct 27 07:41:28.682: H225 NONSTD INCOMING ENCODE BUFFER::= 8164000400010300
021210: *Oct 27 07:41:28.682:
021211: *Oct 27 07:41:28.682: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
021212: *Oct 27 07:41:28.682: //4589/6794E14C88C3/CCAPI/cc_api_call_cut_progress:
   Cause Value=0
021213: *Oct 27 07:41:28.682: //4589/6794E14C88C3/CCAPI/cc_api_call_cut_progress:
021214: *Oct 27 07:41:28.686: //4588/6794E14C88C3/CCAPI/ccCallProgIndProgress:
021215: *Oct 27 07:41:28.686: ISDN BR0/2/1 Q931: TX -> PROGRESS pd = 8  callref = 0xE1
021216: *Oct 27 07:41:28.966: H225.0 INCOMING ENCODE BUFFER::= 28003880060008914A000522C0B50000120F436973636F43616C6C4D616E616765720031006FCE9A1CE0D411DF99F5983863021ADA05800100010010A001000F0140B5000012088164000400010300
021217: *Oct 27 07:41:28.966:
021218: *Oct 27 07:41:28.966: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
          callIdentifier
            guid '6FCE9A1CE0D411DF99F5983863021ADA'H
          multipleCalls FALSE
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
021219: *Oct 27 07:41:28.970: H225 NONSTD INCOMING ENCODE BUFFER::= 8164000400010300
021220: *Oct 27 07:41:28.970:
021221: *Oct 27 07:41:28.970: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
021222: *Oct 27 07:41:28.970: //4601/6FCE9A1C88C9/CCAPI/cc_api_call_cut_progress:
   Cause Value=0
021223: *Oct 27 07:41:28.970: //4601/6FCE9A1C88C9/CCAPI/cc_api_call_cut_progress:
021224: *Oct 27 07:41:28.970: //4600/6FCE9A1C88C9/CCAPI/ccCallCutProgress:
021225: *Oct 27 07:41:28.970: //4600/6FCE9A1C88C9/CCAPI/ccCallCutProgress:
021226: *Oct 27 07:41:28.970: //4600/6FCE9A1C88C9/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=4600
021227: *Oct 27 07:41:28.970: //4600/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x491B1A80, callID1=0x11F8, callID2=0x11F9, tag=0x0)
021228: *Oct 27 07:41:28.970: //4600/6FCE9A1C88C9/CCAPI/ccConferenceCreate:
   Conference Id=0x491B1A80, Call Id1=4600, Call Id2=4601, Tag=0x0
021229: *Oct 27 07:41:28.970: //4600/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x84E, Source Interface=0x46B67B64, Source Call Id=4600,
   Destination Call Id=4601, Disposition=0x0, Tag=0xFFFFFFFF
021230: *Oct 27 07:41:28.970: //4601/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
021231: *Oct 27 07:41:28.970: cc_api_get_xcode_stream : 4369
021232: *Oct 27 07:41:28.974: //4601/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x84E, Source Interface=0x46FAB490, Source Call Id=4601,
   Destination Call Id=4600, Disposition=0x0, Tag=0x0
021233: *Oct 27 07:41:28.974: //4600/6FCE9A1C88C9/CCAPI/cc_generic_bridge_done:
021234: *Oct 27 07:41:28.974: //4600/6FCE9A1C88C9/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x84E, Destination Call Id=4601)
021235: *Oct 27 07:41:28.974: //4601/6FCE9A1C88C9/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x84E, Destination Call Id=4600)
021236: *Oct 27 07:41:28.974: //4600/6FCE9A1C88C9/CCAPI/cc_api_caps_ind:
   Destination Interface=0x46FAB490, Destination Call Id=4601, Source Call Id=4600,
021237: *Oct 27 07:41:28.974: //4600/6FCE9A1C88C9/CCAPI/cc_api_caps_ind:
021238: *Oct 27 07:41:28.974: //4600/6FCE9A1C88C9/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x84E, Call Id1=4600, Call Id2=4601
021239: *Oct 27 07:41:28.974: ISDN BR0/3/1 Q931: TX -> PROGRESS pd = 8  callref = 0x9A
021240: *Oct 27 07:41:29.342: H225.0 INCOMING ENCODE BUFFER::= 28003940060008914A000522C0B50000120F436973636F43616C6C4D616E61676572003100C019620AADB8006E6C9978E0D411DF99F0983863021ADA10A001000F0140B5000012088164000400010300
021241: *Oct 27 07:41:29.342:
021242: *Oct 27 07:41:29.342: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
            ip 'C019620A'H
            port 44472
          callIdentifier
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
021243: *Oct 27 07:41:29.346: H225 NONSTD INCOMING ENCODE BUFFER::= 8164000400010300
021244: *Oct 27 07:41:29.346:
021245: *Oct 27 07:41:29.346: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
021246: *Oct 27 07:41:29.346: //4599/6E6C997888C8/CCAPI/cc_api_call_cut_progress:
   Cause Value=0
021247: *Oct 27 07:41:29.346: //4599/6E6C997888C8/CCAPI/cc_api_call_cut_progress:
021248: *Oct 27 07:41:29.350: //4598/6E6C997888C8/CCAPI/ccCallProgIndProgress:
021249: *Oct 27 07:41:29.350: ISDN BR1/1/0 Q931: TX -> PROGRESS pd = 8  callref = 0x8E
021250: *Oct 27 07:41:29.362: H245 MSC OUTGOING PDU ::=
021302: *Oct 27 07:41:29.430: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
021303: *Oct 27 07:41:29.434: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
021304: *Oct 27 07:41:29.974: H225.0 INCOMING ENCODE BUFFER::= 28003940060008914A000522C0B50000120F436973636F43616C6C4D616E61676572003100C01805014720006D05B6FCE0D411DF99EB983863021ADA10A001000F0140B5000012088164000400010300
021305: *Oct 27 07:41:29.974:
021306: *Oct 27 07:41:29.978: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
            ip 'C0180501'H
            port 18208
          callIdentifier
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
021307: *Oct 27 07:41:29.982: H225 NONSTD INCOMING ENCODE BUFFER::= 8164000400010300
021308: *Oct 27 07:41:29.982:
021309: *Oct 27 07:41:29.982: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
021310: *Oct 27 07:41:29.982: //4597/6D05B6FC88C7/CCAPI/cc_api_call_cut_progress:
   Cause Value=0
021311: *Oct 27 07:41:29.982: //4597/6D05B6FC88C7/CCAPI/cc_api_call_cut_progress:
021312: *Oct 27 07:41:29.982: //4596/6D05B6FC88C7/CCAPI/ccCallProgIndProgress:
021313: *Oct 27 07:41:29.986: ISDN BR0/2/1 Q931: TX -> PROGRESS pd = 8  callref = 0x9D
021314: *Oct 27 07:41:30.298: H225.0 INCOMING ENCODE BUFFER::= 28003940060008914A000522C0B50000120F436973636F43616C6C4D616E61676572003100C018050149FA006BB084CBE0D411DF99E6983863021ADA10A001000F0140B5000012088164000400010300
021315: *Oct 27 07:41:30.298:
021316: *Oct 27 07:41:30.298: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
            ip 'C0180501'H
            port 18938
          callIdentifier
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
021317: *Oct 27 07:41:30.302: H225 NONSTD INCOMING ENCODE BUFFER::= 8164000400010300
021318: *Oct 27 07:41:30.302:
021319: *Oct 27 07:41:30.302: H225 NONSTD INCOMING PDU ::=
value H323_UU_NonStdInfo ::=
      callMgrParam
        enterpriseID {}
021320: *Oct 27 07:41:30.302: //4595/6BAFE8A388C6/CCAPI/cc_api_call_cut_progress:
   Cause Value=0
021321: *Oct 27 07:41:30.302: //4595/6BAFE8A388C6/CCAPI/cc_api_call_cut_progress:
021322: *Oct 27 07:41:30.302: //4594/6BAFE8A388C6/CCAPI/ccCallProgIndProgress:
021323: *Oct 27 07:41:30.306: ISDN BR0/3/0 Q931: TX -> PROGRESS pd = 8  callref = 0x8A
021324: *Oct 27 07:41:30.646: H225.0 INCOMING ENCODE BUFFER::= 28003940060008914A000522C0B50000120F436973636F43616C6C4D616E61676572003100C018050148A0006A536698E0D411DF99E1983863021ADA10A001000F0140B5000012088164000400010300
021325: *Oct 27 07:41:30.646:
021326: *Oct 27 07:41:30.646: H225.0 INCOMING PDU ::=
value H323_UserInformation ::=
      h323-uu-pdu
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
            ip 'C0180501'H
            port 18592
          callIdentifier
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
021327: *Oct 27 07:41:30.650: H225 NONSTD INCOMING ENCODE BUFFER::= 8164000400010300
021328: *Oct 27 07:41:30.650:
021329: *Oct 27 07:41:30.650: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
021330: *Oct 27 07:41:30.650: //4593/6A52C9D888C5/CCAPI/cc_api_call_cut_progress:
   Cause Value=0
021331: *Oct 27 07:41:30.650: //4593/6A52C9D888C5/CCAPI/cc_api_call_cut_progress:
021332: *Oct 27 07:41:30.650: //4592/6A52C9D888C5/CCAPI/ccCallProgIndProgress:
021333: *Oct 27 07:41:30.654: ISDN BR0/3/1 Q931: TX -> PROGRESS pd = 8  callref = 0xE7
021334: *Oct 27 07:41:30.726: H225.0 INCOMING ENCODE BUFFER::= 28003940060008914A000522C0B50000120F436973636F43616C6C4D616E61676572003100C019620AADB900712A829CE0D411DF99FA983863021ADA10A001000F0140B5000012088164000400010300
021335: *Oct 27 07:41:30.726:
021336: *Oct 27 07:41:30.726: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
            ip 'C019620A'H
            port 44473
          callIdentifier
            guid '712A829CE0D411DF99FA983863021ADA'H
        h245Tunneling FALSE
        nonStandardControl
            nonStandardIdentifier h221NonStandard :
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
021337: *Oct 27 07:41:30.730: H225 NONSTD INCOMING ENCODE BUFFER::= 8164000400010300
021338: *Oct 27 07:41:30.730:
021339: *Oct 27 07:41:30.730: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
021340: *Oct 27 07:41:30.730: //4603/7129E5DC88CA/CCAPI/cc_api_call_cut_progress:
   Interface=0x46FAB490, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1),
   Cause Value=17
021341: *Oct 27 07:41:30.730: //4603/7129E5DC88CA/CCAPI/cc_api_call_cut_progress:
021342: *Oct 27 07:41:30.734: //4602/7129E5DC88CA/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1), Cause Value=17
021343: *Oct 27 07:41:30.734: //4602/7129E5DC88CA/CCAPI/ccCallCutProgress:
021344: *Oct 27 07:41:30.734: //4602/7129E5DC88CA/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=4602
021345: *Oct 27 07:41:30.734: //4602/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x491B1DE0, callID1=0x11FA, callID2=0x11FB, tag=0x0)
021346: *Oct 27 07:41:30.734: //4602/7129E5DC88CA/CCAPI/ccConferenceCreate:
   Conference Id=0x491B1DE0, Call Id1=4602, Call Id2=4603, Tag=0x0
021347: *Oct 27 07:41:30.734: //4602/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x84F, Source Interface=0x472FA6C4, Source Call Id=4602,
   Destination Call Id=4603, Disposition=0x0, Tag=0xFFFFFFFF
021348: *Oct 27 07:41:30.734: //4603/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
021349: *Oct 27 07:41:30.734: cc_api_get_xcode_stream : 4369
021350: *Oct 27 07:41:30.734: //4603/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x84F, Source Interface=0x46FAB490, Source Call Id=4603,
   Destination Call Id=4602, Disposition=0x0, Tag=0x0
021351: *Oct 27 07:41:30.734: //4602/7129E5DC88CA/CCAPI/cc_generic_bridge_done:
021352: *Oct 27 07:41:30.734: //4602/7129E5DC88CA/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x84F, Destination Call Id=4603)
021353: *Oct 27 07:41:30.734: //4603/7129E5DC88CA/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x84F, Destination Call Id=4602)
021354: *Oct 27 07:41:30.734: //4602/7129E5DC88CA/CCAPI/cc_api_caps_ind:
   Destination Interface=0x46FAB490, Destination Call Id=4603, Source Call Id=4602,
021355: *Oct 27 07:41:30.734: //4602/7129E5DC88CA/CCAPI/cc_api_caps_ind:
021356: *Oct 27 07:41:30.734: //4602/7129E5DC88CA/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x84F, Call Id1=4602, Call Id2=4603
021357: *Oct 27 07:41:30.738: ISDN BR0/3/0 Q931: TX -> PROGRESS pd = 8  callref = 0x89
        Cause i = 0x8191 - User busy
        Progress Ind i = 0x8188 - In-band info or appropriate now available
021358: *Oct 27 07:41:30.746: H245 MSC OUTGOING PDU ::=
      sequenceNumber 1
        mcCapability
      capabilityTable
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            maxBitRate 0
              3,
              5,
              6
              34,
              30,
              27,
              25
              31
021359: *Oct 27 07:41:30.754: H245 MSC OUTGOING ENCODE BUFFER::= 027001060008817500078013800014000100000100000100000CC001000100078000218A061404302D31368000184810B50000120C52747044746D6652656C6179000080001E83015080001D83014080001A83011080000522C00180000422800180000220C0130080010202000200040005030021001D001A001800001E
021360: *Oct 27 07:41:30.754:
021361: *Oct 27 07:41:30.754: H245 MSC OUTGOING PDU ::=
      terminalType 60
      statusDeterminationNumber 2340
021362: *Oct 27 07:41:30.758: H245 MSC OUTGOING ENCODE BUFFER::= 01003C400924
021363: *Oct 27 07:41:30.758:
021364: *Oct 27 07:41:30.770: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 71
021365: *Oct 27 07:41:30.770: H245 MSC INCOMING ENCODE BUFFER::= 0270010600088175000A801380003C000100000100000100000CC0010001000380000022801580000185014080000285011080002B85015000800002000000010001000200002B
021366: *Oct 27 07:41:30.770:
021367: *Oct 27 07:41:30.770: H245 MSC INCOMING PDU ::=
      sequenceNumber 1
      protocolIdentifier { 0 0 8 245 0 10 }
        maximumAudioDelayJitter 60
        mcCapability
      capabilityTable
          capabilityTableEntryNumber 1
          capability receiveAudioCapability : g729 : 22
          capability receiveAndTransmitUserInputCapability : dtmf : NULL
          capability receiveAndTransmitUserInputCapability : basicString : NULL
          capabilityTableEntryNumber 44
          capability receiveAndTransmitUserInputCapability : hookflash : NULL
          capabilityDescriptorNumber 0
021368: *Oct 27 07:41:30.778: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
021369: *Oct 27 07:41:30.778: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
021370: *Oct 27 07:41:30.778: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= response : terminalCapabilitySetAck :
      sequenceNumber 1
021371: *Oct 27 07:41:30.778: H245 MSC OUTGOING ENCODE BUFFER::= 218001
021372: *Oct 27 07:41:30.782:
021373: *Oct 27 07:41:30.782: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 3
021374: *Oct 27 07:41:30.782: H245 MSC INCOMING ENCODE BUFFER::= 218001
021375: *Oct 27 07:41:30.782:
021376: *Oct 27 07:41:30.782: H245 MSC INCOMING PDU ::=
      sequenceNumber 1
021377: *Oct 27 07:41:30.782: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
021378: *Oct 27 07:41:30.782: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
021379: *Oct 27 07:41:30.794: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 2
021380: *Oct 27 07:41:30.794: H245 MSC INCOMING ENCODE BUFFER::= 2080
021381: *Oct 27 07:41:30.794:
021382: *Oct 27 07:41:30.794: H245 MSC INCOMING PDU ::=
value MultimediaSystemControlMessage ::= response : masterSlaveDeterminationAck :
      decision master : NULL
021383: *Oct 27 07:41:30.794: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
021494: *Oct 27 07:41:31.322: //4588/6794E14C88C3/CCAPI/ccCallProgIndProgress:
021495: *Oct 27 07:41:31.326: ISDN BR0/2/1 Q931: TX -> PROGRESS pd = 8  callref = 0xE1
021496: *Oct 27 07:41:31.778: H225.0 INCOMING ENCODE BUFFER::= 28003940060008914A000522C0B50000120F436973636F43616C6C4D616E61676572003100C018050144FC006E6C9978E0D411DF99F0983863021ADA10A001000F0140B5000012088164000400010300
021497: *Oct 27 07:41:31.778:
021498: *Oct 27 07:41:31.778: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          protocolIdentifier { 0 0 8 2250 0 5 }
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              productId '436973636F43616C6C4D616E61676572'H
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
            ip 'C0180501'H
            port 17660
          callIdentifier
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '8164000400010300'H
021499: *Oct 27 07:41:31.782: H225 NONSTD INCOMING ENCODE BUFFER::= 8164000400010300
021500: *Oct 27 07:41:31.782:
021501: *Oct 27 07:41:31.786: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        interclusterVersion 3
        enterpriseID {}
021502: *Oct 27 07:41:31.786: //4599/6E6C997888C8/CCAPI/cc_api_call_cut_progress:
   Cause Value=17
021503: *Oct 27 07:41:31.786: //4599/6E6C997888C8/CCAPI/cc_api_call_cut_progress:
021504: *Oct 27 07:41:31.786: //4598/6E6C997888C8/CCAPI/ccCallProgIndProgress:
021505: *Oct 27 07:41:31.786: ISDN BR1/1/0 Q931: TX -> PROGRESS pd = 8  callref = 0x8E
021506: *Oct 27 07:41:32.150: H225.0 INCOMING ENCODE BUFFER::= 28003940060008914A000522C0B50000120F436973636F43616C6C4D616E61676572003100C01805014720006D05B6FCE0D411DF99EB983863021ADA10A001000F0140B5000012088164000400010300
021507: *Oct 27 07:41:32.150:
021508: *Oct 27 07:41:32.150: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
            ip 'C0180501'H
            port 18208
          callIdentifier
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
021509: *Oct 27 07:41:32.154: H225 NONSTD INCOMING ENCODE BUFFER::= 8164000400010300
021510: *Oct 27 07:41:32.154:
021511: *Oct 27 07:41:32.154: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
021512: *Oct 27 07:41:32.154: //4597/6D05B6FC88C7/CCAPI/cc_api_call_cut_progress:
   Cause Value=17
021513: *Oct 27 07:41:32.154: //4597/6D05B6FC88C7/CCAPI/cc_api_call_cut_progress:
021514: *Oct 27 07:41:32.154: //4596/6D05B6FC88C7/CCAPI/ccCallProgIndProgress:
021515: *Oct 27 07:41:32.158: ISDN BR0/2/1 Q931: TX -> PROGRESS pd = 8  callref = 0x9D
021516: *Oct 27 07:41:32.482: H225.0 INCOMING ENCODE BUFFER::= 28003940060008914A000522C0B50000120F436973636F43616C6C4D616E61676572003100C018050149FA006BB084CBE0D411DF99E6983863021ADA10A001000F0140B5000012088164000400010300
021517: *Oct 27 07:41:32.482:
021518: *Oct 27 07:41:32.482: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
            ip 'C0180501'H
            port 18938
          callIdentifier
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
021519: *Oct 27 07:41:32.486: H225 NONSTD INCOMING ENCODE BUFFER::= 8164000400010300
021520: *Oct 27 07:41:32.486:
021521: *Oct 27 07:41:32.486: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
021522: *Oct 27 07:41:32.486: //4595/6BAFE8A388C6/CCAPI/cc_api_call_cut_progress:
   Cause Value=17
021523: *Oct 27 07:41:32.486: //4595/6BAFE8A388C6/CCAPI/cc_api_call_cut_progress:
021524: *Oct 27 07:41:32.486: //4594/6BAFE8A388C6/CCAPI/ccCallProgIndProgress:
021525: *Oct 27 07:41:32.490: ISDN BR0/3/0 Q931: TX -> PROGRESS pd = 8  callref = 0x8A
021526: *Oct 27 07:41:32.522: MGCP Packet sent to 192.25.98.10:2427--->
NTFY 449158437 *@C2821-DTMSEVPR2.arconet.net MGCP 0.1
X: 0
O:
021527: *Oct 27 07:41:32.534: MGCP Packet received from 192.25.98.10:2427--->
200 449158437
021528: *Oct 27 07:41:32.830: H225.0 INCOMING ENCODE BUFFER::= 28003940060008914A000522C0B50000120F436973636F43616C6C4D616E61676572003100C018050148A0006A536698E0D411DF99E1983863021ADA10A001000F0140B5000012088164000400010300
021529: *Oct 27 07:41:32.830:
021530: *Oct 27 07:41:32.830: H225.0 INCOMING PDU ::=
      h323-uu-pdu
        h323-message-body progress :
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
            ip 'C0180501'H
            port 18592
          callIdentifier
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
021531: *Oct 27 07:41:32.834: H225 NONSTD INCOMING ENCODE BUFFER::= 8164000400010300
021532: *Oct 27 07:41:32.838:
021533: *Oct 27 07:41:32.838: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
021534: *Oct 27 07:41:32.838: //4593/6A52C9D888C5/CCAPI/cc_api_call_cut_progress:
   Cause Value=17
021535: *Oct 27 07:41:32.838: //4593/6A52C9D888C5/CCAPI/cc_api_call_cut_progress:
021536: *Oct 27 07:41:32.838: //4592/6A52C9D888C5/CCAPI/ccCallProgIndProgress:
021537: *Oct 27 07:41:32.838: ISDN BR0/3/1 Q931: TX -> PROGRESS pd = 8  callref = 0xE7
021538: *Oct 27 07:41:33.186: H225.0 INCOMING ENCODE BUFFER::= 28003940060008914A000522C0B50000120F436973636F43616C6C4D616E61676572003100C01805014B520068EB4B34E0D411DF99DC983863021ADA10A001000F0140B5000012088164000400010300
021539: *Oct 27 07:41:33.186:
021540: *Oct 27 07:41:33.190: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
            ip 'C0180501'H
            port 19282
          callIdentifier
            guid '68EB4B34E0D411DF99DC983863021ADA'H
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
021541: *Oct 27 07:41:33.194: H225 NONSTD INCOMING ENCODE BUFFER::= 8164000400010300
021542: *Oct 27 07:41:33.194:
021543: *Oct 27 07:41:33.194: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
021544: *Oct 27 07:41:33.194: //4591/68EAAF0C88C4/CCAPI/cc_api_call_cut_progress:
   Cause Value=17
021545: *Oct 27 07:41:33.194: //4591/68EAAF0C88C4/CCAPI/cc_api_call_cut_progress:
021546: *Oct 27 07:41:33.194: //4590/68EAAF0C88C4/CCAPI/ccCallProgIndProgress:
021547: *Oct 27 07:41:33.194: ISDN BR1/1/0 Q931: TX -> PROGRESS pd = 8  callref = 0xCE
021548: *Oct 27 07:41:33.538: H225.0 INCOMING ENCODE BUFFER::= 28003940060008914A000522C0B50000120F436973636F43616C6C4D616E61676572003100C018050149880067957D74E0D411DF99D7983863021ADA10A001000F0140B5000012088164000400010300
021549: *Oct 27 07:41:33.538:
021550: *Oct 27 07:41:33.538: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
            ip 'C0180501'H
            port 18824
          callIdentifier
            guid '67957D74E0D411DF99D7983863021ADA'H
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
021551: *Oct 27 07:41:33.542: H225 NONSTD INCOMING ENCODE BUFFER::= 8164000400010300
021552: *Oct 27 07:41:33.542:
021553: *Oct 27 07:41:33.542: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
021554: *Oct 27 07:41:33.542: //4589/6794E14C88C3/CCAPI/cc_api_call_cut_progress:
   Cause Value=17
021555: *Oct 27 07:41:33.542: //4589/6794E14C88C3/CCAPI/cc_api_call_cut_progress:
021556: *Oct 27 07:41:33.542: //4588/6794E14C88C3/CCAPI/ccCallProgIndProgress:
021557: *Oct 27 07:41:33.546: ISDN BR0/2/1 Q931: TX -> PROGRESS pd = 8  callref = 0xE1
C2821-DTMSEVPR2#
C2821-DTMSEVPR2#
C2821-DTMSEVPR2#show voice call stat
CallID     CID  ccVdb      Port             DSP/Ch  Called #   Codec    Dial-peers
0x11EC     1AA2 0x46B585D0 0/2/1.1          0/1:1   955658800  g729r8    20/955
0x11EE     1AA3 0x47319490 1/1/0.1          1/1:1   955658800  g729r8    20/955
0x11F0     1AA4 0x46B67B64 0/3/1.1          0/1:2   955658800  g729r8    20/955
0x11F2     1AA5 0x472FA6C4 0/3/0.1          0/1:3   955658800  g729r8    20/955
0x11F4     1AA6 0x46B585D0 0/2/1.2          0/1:4   955658800  g729r8    20/955
0x11F6     1AA7 0x47319490 1/1/0.2          1/1:2   955658800  g729r8    20/955
0x11F8     1AA8 0x46B67B64 0/3/1.2          0/1:5   955658800  g729r8    20/955
0x11FA     1AA9 0x472FA6C4 0/3/0.2          0/1:6   955658800  g729r8    20/955
8 active calls found
C2821-DTMSEVPR2#
021558: *Oct 27 07:41:41.670: ISDN BR0/1/1 Q931: TX -> RESTART pd = 8  callref = 0x00
        Channel ID i = 0x89
                Exclusive, B1
        Restart Indicator i = 0x80
021559: *Oct 27 07:41:41.850: ISDN BR0/1/1 Q931: RX <- RESTART_ACK pd = 8  callref = 0x80
        Channel ID i = 0x89
                Exclusive, B1
021560: *Oct 27 07:41:41.862: ISDN BR0/1/1 Q931: TX -> STATUS pd = 8  callref = 0x00
        Cause i = 0x82C1 - Bearer capability not implemented
        Call State i = 0x00
021561: *Oct 27 07:41:45.802: ISDN BR0/2/1 Q931: RX <- DISCONNECT pd = 8  callref = 0x61
        Cause i = 0x8090 - Normal call clearing
        Progress Ind i = 0x8288 - In-band info or appropriate now available
        Display i = 'LIBERACION NORMAL'
021562: *Oct 27 07:41:45.806: //4588/6794E14C88C3/CCAPI/cc_api_call_disc_prog_ind:
   Cause Value=16, Progress Indication=INBAND(8), Interface=0x46B585D0
021563: *Oct 27 07:41:45.806: //4588/6794E14C88C3/CCAPI/cc_api_call_disc_prog_ind:
   Event(Progress Indication=0x0), Call Entry(Responsed=TRUE)
021564: *Oct 27 07:41:45.806: //4588/6794E14C88C3/CCAPI/ccConferenceDestroy:
   Conference Id=0x848, Tag=0x0
021565: *Oct 27 07:41:45.806: //4588/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x848, Source Interface=0x46B585D0, Source Call Id=4588,
   Destination Call Id=4589, Disposition=0x0, Tag=0x0
021566: *Oct 27 07:41:45.806: //4589/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x848, Source Interface=0x46FAB490, Source Call Id=4589,
   Destination Call Id=4588, Disposition=0x0, Tag=0x0
021567: *Oct 27 07:41:45.806: //4588/6794E14C88C3/CCAPI/cc_generic_bridge_done:
021568: *Oct 27 07:41:45.806: //4589/6794E14C88C3/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
021569: *Oct 27 07:41:45.806: //4589/6794E14C88C3/CCAPI/ccCallDisconnect:
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
021570: *Oct 27 07:41:45.806: //4589/6794E14C88C3/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
021571: *Oct 27 07:41:45.810: //4588/6794E14C88C3/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
021572: *Oct 27 07:41:45.810: //4588/6794E14C88C3/CCAPI/ccCallDisconnect:
021573: *Oct 27 07:41:45.810: //4588/6794E14C88C3/CCAPI/cc_api_get_transfer_info:
021574: *Oct 27 07:41:45.810: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
        h323-message-body releaseComplete :
          protocolIdentifier { 0 0 8 2250 0 4 }
          callIdentifier
        h245Tunneling FALSE
021575: *Oct 27 07:41:45.810: H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A00041100110067957D74E0D411DF99D7983863021ADA10800100
021576: *Oct 27 07:41:45.810:
021577: *Oct 27 07:41:45.814: //4589/6794E14C88C3/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46FAB490, Tag=0x0, Call Id=4589,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
021578: *Oct 27 07:41:45.814: //4589/6794E14C88C3/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
021579: *Oct 27 07:41:45.814: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021580: *Oct 27 07:41:45.814: :cc_free_feature_vsa freeing 46E24C28
021581: *Oct 27 07:41:45.814: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021582: *Oct 27 07:41:45.814:  vsacount in free is 15
021583: *Oct 27 07:41:45.814: //4588/6794E14C88C3/CCAPI/cc_api_call_disc_cause_update:
   Cause Value=16
021584: *Oct 27 07:41:45.814: //4588/6794E14C88C3/CCAPI/cc_api_call_disc_cause_update:
   Call Entry(Disconnect Cause=16)
021585: *Oct 27 07:41:45.826: //4588/6794E14C88C3/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46B585D0, Tag=0x0, Call Id=4588,
021586: *Oct 27 07:41:45.826: //4588/6794E14C88C3/CCAPI/cc_api_call_disconnect_done:
021587: *Oct 27 07:41:45.826: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021588: *Oct 27 07:41:45.826: :cc_free_feature_vsa freeing 46E253C0
021589: *Oct 27 07:41:45.826: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021590: *Oct 27 07:41:45.826:  vsacount in free is 14
021591: *Oct 27 07:41:45.830: ISDN BR0/2/1 Q931: TX -> RELEASE pd = 8  callref = 0xE1
021592: *Oct 27 07:41:45.974: ISDN BR0/2/1 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x61
021593: *Oct 27 07:41:46.166: ISDN BR1/1/0 Q931: RX <- DISCONNECT pd = 8  callref = 0x4E
021594: *Oct 27 07:41:46.170: //4590/68EAAF0C88C4/CCAPI/cc_api_call_disc_prog_ind:
   Cause Value=16, Progress Indication=INBAND(8), Interface=0x47319490
021595: *Oct 27 07:41:46.170: //4590/68EAAF0C88C4/CCAPI/cc_api_call_disc_prog_ind:
021596: *Oct 27 07:41:46.170: //4590/68EAAF0C88C4/CCAPI/ccConferenceDestroy:
   Conference Id=0x849, Tag=0x0
021597: *Oct 27 07:41:46.170: //4590/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x849, Source Interface=0x47319490, Source Call Id=4590,
   Destination Call Id=4591, Disposition=0x0, Tag=0x0
021598: *Oct 27 07:41:46.170: //4591/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x849, Source Interface=0x46FAB490, Source Call Id=4591,
   Destination Call Id=4590, Disposition=0x0, Tag=0x0
021599: *Oct 27 07:41:46.170: //4590/68EAAF0C88C4/CCAPI/cc_generic_bridge_done:
021600: *Oct 27 07:41:46.174: //4591/68EAAF0C88C4/CCAPI/ccCallDisconnect:
021601: *Oct 27 07:41:46.174: //4591/68EAAF0C88C4/CCAPI/ccCallDisconnect:
021602: *Oct 27 07:41:46.174: //4591/68EAAF0C88C4/CCAPI/cc_api_get_transfer_info:
021603: *Oct 27 07:41:46.174: //4590/68EAAF0C88C4/CCAPI/ccCallDisconnect:
021604: *Oct 27 07:41:46.174: //4590/68EAAF0C88C4/CCAPI/ccCallDisconnect:
021605: *Oct 27 07:41:46.174: //4590/68EAAF0C88C4/CCAPI/cc_api_get_transfer_info:
021606: *Oct 27 07:41:46.174: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
021607: *Oct 27 07:41:46.174: H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A00041100110068EB4B34E0D411DF99DC983863021ADA10800100
021608: *Oct 27 07:41:46.174:
021609: *Oct 27 07:41:46.178: //4591/68EAAF0C88C4/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46FAB490, Tag=0x0, Call Id=4591,
021610: *Oct 27 07:41:46.178: //4591/68EAAF0C88C4/CCAPI/cc_api_call_disconnect_done:
021611: *Oct 27 07:41:46.178: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021612: *Oct 27 07:41:46.178: :cc_free_feature_vsa freeing 46E25A80
021613: *Oct 27 07:41:46.178: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021614: *Oct 27 07:41:46.178:  vsacount in free is 13
021615: *Oct 27 07:41:46.178: //4590/68EAAF0C88C4/CCAPI/cc_api_call_disc_cause_update:
   Cause Value=16
021616: *Oct 27 07:41:46.178: //4590/68EAAF0C88C4/CCAPI/cc_api_call_disc_cause_update:
021617: *Oct 27 07:41:46.190: //4590/68EAAF0C88C4/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x47319490, Tag=0x0, Call Id=4590,
021618: *Oct 27 07:41:46.190: //4590/68EAAF0C88C4/CCAPI/cc_api_call_disconnect_done:
021619: *Oct 27 07:41:46.190: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021620: *Oct 27 07:41:46.190: :cc_free_feature_vsa freeing 46E24DD8
021621: *Oct 27 07:41:46.190: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021622: *Oct 27 07:41:46.190:  vsacount in free is 12
021623: *Oct 27 07:41:46.194: ISDN BR1/1/0 Q931: TX -> RELEASE pd = 8  callref = 0xCE
021624: *Oct 27 07:41:46.330: ISDN BR1/1/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x4E
021625: *Oct 27 07:41:46.582: ISDN BR0/3/1 Q931: RX <- DISCONNECT pd = 8  callref = 0x67
021626: *Oct 27 07:41:46.582: //4592/6A52C9D888C5/CCAPI/cc_api_call_disc_prog_ind:
   Cause Value=16, Progress Indication=INBAND(8), Interface=0x46B67B64
021627: *Oct 27 07:41:46.582: //4592/6A52C9D888C5/CCAPI/cc_api_call_disc_prog_ind:
021628: *Oct 27 07:41:46.586: //4592/6A52C9D888C5/CCAPI/ccConferenceDestroy:
   Conference Id=0x84A, Tag=0x0
021629: *Oct 27 07:41:46.586: //4592/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x84A, Source Interface=0x46B67B64, Source Call Id=4592,
   Destination Call Id=4593, Disposition=0x0, Tag=0x0
021630: *Oct 27 07:41:46.586: //4593/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x84A, Source Interface=0x46FAB490, Source Call Id=4593,
   Destination Call Id=4592, Disposition=0x0, Tag=0x0
021631: *Oct 27 07:41:46.586: //4592/6A52C9D888C5/CCAPI/cc_generic_bridge_done:
021632: *Oct 27 07:41:46.586: //4593/6A52C9D888C5/CCAPI/ccCallDisconnect:
021633: *Oct 27 07:41:46.586: //4593/6A52C9D888C5/CCAPI/ccCallDisconnect:
021634: *Oct 27 07:41:46.586: //4593/6A52C9D888C5/CCAPI/cc_api_get_transfer_info:
021635: *Oct 27 07:41:46.586: //4592/6A52C9D888C5/CCAPI/ccCallDisconnect:
021636: *Oct 27 07:41:46.586: //4592/6A52C9D888C5/CCAPI/ccCallDisconnect:
021637: *Oct
C2821-DTMSEVPR2#
C2821-DTMSEVPR2#27 07:41:46.586: //4592/6A52C9D888C5/CCAPI/cc_api_get_transfer_info:
021638: *Oct 27 07:41:46.586: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
          callIdentifier
            guid '6A536698E0D411DF99E1983863021ADA'H
        h245Tunneling FALSE
021639: *Oct 27 07:41:46.590: H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A0004110011006A536698E0D411DF99E1983863021ADA10800100
021640: *Oct 27 07:41:46.590:
021641: *Oct 27 07:41:46.590: //4593/6A52C9D888C5/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46FAB490, Tag=0x0, Call Id=4593,
021642: *Oct 27 07:41:46.590: //4593/6A52C9D888C5/CCAPI/cc_api_call_disconnect_done:
021643: *Oct 27 07:41:46.590: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021644: *Oct 27 07:41:46.590: :cc_free_feature_vsa freeing 46E25498
021645: *Oct 27 07:41:46.590: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021646: *Oct 27 07:41:46.590:  vsacount in free is 11
021647: *Oct 27 07:41:46.594: //4592/6A52C9D888C5/CCAPI/cc_api_call_disc_cause_update:
   Cause Value=16
021648: *Oct 27 07:41:46.594: //4592/6A52C9D888C5/CCAPI/cc_api_call_disc_cause_update:
021649: *Oct 27 07:41:46.606: //4592/6A52C9D888C5/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46B67B64, Tag=0x0, Call Id=4592,
021650: *Oct 27 07:41:46.606: //4592/6A52C9D888C5/CCAPI/cc_api_call_disconnect_done:
021651: *Oct 27 07:41:46.606: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021652: *Oct 27 07:41:46.606: :cc_free_feature_vsa freeing 46E258D0
021653: *Oct 27 07:41:46.606: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021654: *Oct 27 07:41:46.606:  vsacount in free is 10
021655: *Oct 27 07:41:46.606: ISDN BR0/3/1 Q931: TX -> RELEASE pd = 8  callref = 0xE7
021656: *Oct 27 07:41:46.738: ISDN BR0/3/1 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x67
021657: *Oct 27 07:41:47.010: ISDN BR0/3/0 Q931: RX <- DISCONNECT pd = 8  callref = 0x0A
021658: *Oct 27 07:41:47.014: //4594/6BAFE8A388C6/CCAPI/cc_api_call_disc_prog_ind:
   Cause Value=16, Progress Indication=INBAND(8), Interface=0x472FA6C4
021659: *Oct 27 07:41:47.014: //4594/6BAFE8A388C6/CCAPI/cc_api_call_disc_prog_ind:
021660: *Oct 27 07:41:47.014: //4594/6BAFE8A388C6/CCAPI/ccConferenceDestroy:
   Conference Id=0x84B, Tag=0x0
021661: *Oct 27 07:41:47.014: //4594/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=4595, Disposition=0x0, Tag=0x0
021662: *Oct 27 07:41:47.014: //4595/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
021663: *Oct 27 07:41:47.014: //4594/6BAFE8A388C6/CCAPI/cc_generic_bridge_done:
021664: *Oct 27 07:41:47.014: //4595/6BAFE8A388C6/CCAPI/ccCallDisconnect:
021665: *Oct 27 07:41:47.014: //4595/6BAFE8A388C6/CCAPI/ccCallDisconnect:
021666: *Oct 27 07:41:47.014: //4595/6BAFE8A388C6/CCAPI/cc_api_get_transfer_info:
021667: *Oct 27 07:41:47.018: //4594/6BAFE8A388C6/CCAPI/ccCallDisconnect:
021668: *Oct 27 07:41:47.018: //4594/6BAFE8A388C6/CCAPI/ccCallDisconnect:
021669: *Oct 27 07:41:47.018: //4594/6BAFE8A388C6/CCAPI/cc_api_get_transfer_info:
021670: *Oct 27 07:41:47.018: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
          callIdentifier
            guid '6BB084CBE0D411DF99E6983863021ADA'H
        h245Tunneling FALSE
021671: *Oct 27 07:41:47.018: H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A0004110011006BB084CBE0D411DF99E6983863021ADA10800100
021672: *Oct 27 07:41:47.018:
021673: *Oct 27 07:41:47.022: //4595/6BAFE8A388C6/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46FAB490, Tag=0x0, Call Id=4595,
021674: *Oct 27 07:41:47.022: //4595/6BAFE8A388C6/CCAPI/cc_api_call_disconnect_done:
021675: *Oct 27 07:41:47.022: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021676: *Oct 27 07:41:47.022: :cc_free_feature_vsa freeing 46E24B50
021677: *Oct 27 07:41:47.022: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021678: *Oct 27 07:41:47.022:  vsacount in free is 9
021679: *Oct 27 07:41:47.022: //4594/6BAFE8A388C6/CCAPI/cc_api_call_disc_cause_update:
   Cause Value=16
021680: *Oct 27 07:41:47.022: //4594/6BAFE8A388C6/CCAPI/cc_api_call_disc_cause_update:
021681: *Oct 27 07:41:47.034: //4594/6BAFE8A388C6/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x472FA6C4, Tag=0x0, Call Id=4594,
021682: *Oct 27 07:41:47.034: //4594/6BAFE8A388C6/CCAPI/cc_api_call_disconnect_done:
021683: *Oct 27 07:41:47.034: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021684: *Oct 27 07:41:47.034: :cc_free_feature_vsa freeing 46E24F88
021685: *Oct 27 07:41:47.034: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021686: *Oct 27 07:41:47.034:  vsacount in free is 8
021687: *Oct 27 07:41:47.038: ISDN BR0/3/0 Q931: TX -> RELEASE pd = 8  callref = 0x8A
021688: *Oct 27 07:41:47.174: ISDN BR0/3/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x0A
021689: *Oct 27 07:41:47.406: ISDN BR0/2/1 Q931: RX <- DISCONNECT pd = 8  callref = 0x1D
021690: *Oct 27 07:41:47.410: //4596/6D05B6FC88C7/CCAPI/cc_api_call_disc_prog_ind:
021691: *Oct 27 07:41:47.410: //4596/6D05B6FC88C7/CCAPI/cc_api_call_disc_prog_ind:
021692: *Oct 27 07:41:47.410: //4596/6D05B6FC88C7/CCAPI/ccConferenceDestroy:
   Conference Id=0x84C, Tag=0x0
021693: *Oct 27 07:41:47.410: //4596/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=4597, Disposition=0x0, Tag=0x0
021694: *Oct 27 07:41:47.410: //4597/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
021695: *Oct 27 07:41:47.410: //4596/6D05B6FC88C7/CCAPI/cc_generic_bridge_done:
021696: *Oct 27 07:41:47.414: //4597/6D05B6FC88C7/CCAPI/ccCallDisconnect:
021697: *Oct 27 07:41:47.414: //4597/6D05B6FC88C7/CCAPI/ccCallDisconnect:
021698: *Oct 27 07:41:47.414: //4597/6D05B6FC88C7/CCAPI/cc_api_get_transfer_info:
021699: *Oct 27 07:41:47.414: //4596/6D05B6FC88C7/CCAPI/ccCallDisconnect:
021700: *Oct 27 07:41:47.414: //4596/6D05B6FC88C7/CCAPI/ccCallDisconnect:
021701: *Oct 27 07:41:47.414: //4596/6D05B6FC88C7/CCAPI/cc_api_get_transfer_info:
021702: *Oct 27 07:41:47.414: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
021703: *Oct 27 07:41:47.414: H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A0004110011006D05B6FCE0D411DF99EB983863021ADA10800100
021704: *Oct 27 07:41:47.418:
021705: *Oct 27 07:41:47.418: //4597/6D05B6FC88C7/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46FAB490, Tag=0x0, Call Id=4597,
021706: *Oct 27 07:41:47.418: //4597/6D05B6FC88C7/CCAPI/cc_api_call_disconnect_done:
021707: *Oct 27 07:41:47.418: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021708: *Oct 27 07:41:47.418: :cc_free_feature_vsa freeing 46E25138
021709: *Oct 27 07:41:47.418: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021710: *Oct 27 07:41:47.418:  vsacount in free is 7
021711: *Oct 27 07:41:47.418: //4596/6D05B6FC88C7/CCAPI/cc_api_call_disc_cause_update:
   Cause Value=16
021712: *Oct 27 07:41:47.422: //4596/6D05B6FC88C7/CCAPI/cc_api_call_disc_cause_update:
021713: *Oct 27 07:41:47.430: //4596/6D05B6FC88C7/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46B585D0, Tag=0x0, Call Id=4596,
021714: *Oct 27 07:41:47.430: //4596/6D05B6FC88C7/CCAPI/cc_api_call_disconnect_done:
021715: *Oct 27 07:41:47.430: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021716: *Oct 27 07:41:47.430: :cc_free_feature_vsa freeing 46E24EB0
021717: *Oct 27 07:41:47.430: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021718: *Oct 27 07:41:47.430:  vsacount in free is 6
021719: *Oct 27 07:41:47.434: ISDN BR0/2/1 Q931: TX -> RELEASE pd = 8  callref = 0x9D
021720: *Oct 27 07:41:47.522: MGCP Packet sent to 192.25.98.10:2427--->
NTFY 449158438 *@C2821-DTMSEVPR2.arconet.net MGCP 0.1
X: 0
O:
021721: *Oct 27 07:41:47.534: MGCP Packet received from 192.25.98.10:2427--->
200 449158438
021722: *Oct 27 07:41:47.574: ISDN BR0/2/1 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x1D
021723: *Oct 27 07:41:47.838: ISDN BR1/1/0 Q931: RX <- DISCONNECT pd = 8  callref = 0x0E
021724: *Oct 27 07:41:47.842: //4598/6E6C997888C8/CCAPI/cc_api_call_disc_prog_ind:
021725: *Oct 27 07:41:47.842: //4598/6E6C997888C8/CCAPI/cc_api_call_disc_prog_ind:
021726: *Oct 27 07:41:47.842: //4598/6E6C997888C8/CCAPI/ccConferenceDestroy:
   Conference Id=0x84D, Tag=0x0
021727: *Oct 27 07:41:47.842: //4598/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=4599, Disposition=0x0, Tag=0x0
021728: *Oct 27 07:41:47.842: //4599/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
021729: *Oct 27 07:41:47.842: //4598/6E6C997888C8/CCAPI/cc_generic_bridge_done:
021730: *Oct 27 07:41:47.846: //4599/6E6C997888C8/CCAPI/ccCallDisconnect:
021731: *Oct 27 07:41:47.846: //4599/6E6C997888C8/CCAPI/ccCallDisconnect:
021732: *Oct 27 07:41:47.846: //4599/6E6C997888C8/CCAPI/cc_api_get_transfer_info:
021733: *Oct 27 07:41:47.846: //4598/6E6C997888C8/CCAPI/ccCallDisconnect:
021734: *Oct 27 07:41:47.846: //4598/6E6C997888C8/CCAPI/ccCallDisconnect:
021735: *Oct 27 07:41:47.846: //4598/6E6C997888C8/CCAPI/cc_api_get_transfer_info:
021736: *Oct 27 07:41:47.846: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
          callIdentifier
            guid '6E6C9978E0D411DF99F0983863021ADA'H
        h245Tunneling FALSE
021737: *Oct 27 07:41:47.850: H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A0004110011006E6C9978E0D411DF99F0983863021ADA10800100
021738: *Oct 27 07:41:47.850:
021739: *Oct 27 07:41:47.850: //4599/6E6C997888C8/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46FAB490, Tag=0x0, Call Id=4599,
021740: *Oct 27 07:41:47.850: //4599/6E6C997888C8/CCAPI/cc_api_call_disconnect_done:
021741: *Oct 27 07:41:47.850: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021742: *Oct 27 07:41:47.850: :cc_free_feature_vsa freeing 46E25570
021743: *Oct 27 07:41:47.850: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021744: *Oct 27 07:41:47.850:  vsacount in free is 5
021745: *Oct 27 07:41:47.854: //4598/6E6C997888C8/CCAPI/cc_api_call_disc_cause_update:
   Cause Value=16
021746: *Oct 27 07:41:47.854: //4598/6E6C997888C8/CCAPI/cc_api_call_disc_cause_update:
021747: *Oct 27 07:41:47.862: //4598/6E6C997888C8/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x47319490, Tag=0x0, Call Id=4598,
021748: *Oct 27 07:41:47.862: //4598/6E6C997888C8/CCAPI/cc_api_call_disconnect_done:
021749: *Oct 27 07:41:47.866: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021750: *Oct 27 07:41:47.866: :cc_free_feature_vsa freeing 46E25648
021751: *Oct 27 07:41:47.866: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021752: *Oct 27 07:41:47.866:  vsacount in free is 4
021753: *Oct 27 07:41:47.866: ISDN BR1/1/0 Q931: TX -> RELEASE pd = 8  callref = 0x8E
021754: *Oct 27 07:41:48.018: ISDN BR1/1/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x0E
021755: *Oct 27 07:41:48.234: ISDN BR0/3/1 Q931: RX <- DISCONNECT pd = 8  callref = 0x1A
021756: *Oct 27 07:41:48.238: //4600/6FCE9A1C88C9/CCAPI/cc_api_call_disc_prog_ind:
021757: *Oct 27 07:41:48.238: //4600/6FCE9A1C88C9/CCAPI/cc_api_call_disc_prog_ind:
021758: *Oct 27 07:41:48.238: //4600/6FCE9A1C88C9/CCAPI/ccConferenceDestroy:
   Conference Id=0x84E, Tag=0x0
021759: *Oct 27 07:41:48.238: //4600/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=4601, Disposition=0x0, Tag=0x0
021760: *Oct 27 07:41:48.238: //4601/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
021761: *Oct 27 07:41:48.238: //4600/6FCE9A1C88C9/CCAPI/cc_generic_bridge_done:
021762: *Oct 27 07:41:48.242: //4601/6FCE9A1C88C9/CCAPI/ccCallDisconnect:
021763: *Oct 27 07:41:48.242: //4601/6FCE9A1C88C9/CCAPI/ccCallDisconnect:
021764: *Oct 27 07:41:48.242: //4601/6FCE9A1C88C9/CCAPI/cc_api_get_transfer_info:
021765: *Oct 27 07:41:48.242: //4600/6FCE9A1C88C9/CCAPI/ccCallDisconnect:
021766: *Oct 27 07:41:48.242: //4600/6FCE9A1C88C9/CCAPI/ccCallDisconnect:
021767: *Oct 27 07:41:48.242: //4600/6FCE9A1C88C9/CCAPI/cc_api_get_transfer_info:
021768: *Oct 27 07:41:48.242: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
021769: *Oct 27 07:41:48.242: H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A0004110011006FCE9A1CE0D411DF99F5983863021ADA10800100
021770: *Oct 27 07:41:48.242:
021771: *Oct 27 07:41:48.246: //4601/6FCE9A1C88C9/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46FAB490, Tag=0x0, Call Id=4601,
021772: *Oct 27 07:41:48.246: //4601/6FCE9A1C88C9/CCAPI/cc_api_call_disconnect_done:
021773: *Oct 27 07:41:48.246: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021774: *Oct 27 07:41:48.246: :cc_free_feature_vsa freeing 46E25720
021775: *Oct 27 07:41:48.246: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021776: *Oct 27 07:41:48.246:  vsacount in free is 3
021777: *Oct 27 07:41:48.246: //4600/6FCE9A1C88C9/CCAPI/cc_api_call_disc_cause_update:
   Cause Value=16
021778: *Oct 27 07:41:48.246: //4600/6FCE9A1C88C9/CCAPI/cc_api_call_disc_cause_update:
021779: *Oct 27 07:41:48.258: //4600/6FCE9A1C88C9/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46B67B64, Tag=0x0, Call Id=4600,
021780: *Oct 27 07:41:48.258: //4600/6FCE9A1C88C9/CCAPI/cc_api_call_disconnect_done:
021781: *Oct 27 07:41:48.258: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021782: *Oct 27 07:41:48.258: :cc_free_feature_vsa freeing 46E257F8
021783: *Oct 27 07:41:48.258: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021784: *Oct 27 07:41:48.258:  vsacount in free is 2
021785: *Oct 27 07:41:48.262: ISDN BR0/3/1 Q931: TX -> RELEASE pd = 8  callref = 0x9A
021786: *Oct 27 07:41:48.390: ISDN BR0/3/1 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x1A
021787: *Oct 27 07:41:48.650: ISDN BR0/3/0 Q931: RX <- DISCONNECT pd = 8  callref = 0x09
021788: *Oct 27 07:41:48.650: //4602/7129E5DC88CA/CCAPI/cc_api_call_disc_prog_ind:
021789: *Oct 27 07:41:48.650: //4602/7129E5DC88CA/CCAPI/cc_api_call_disc_prog_ind:
021790: *Oct 27 07:41:48.650: //4602/7129E5DC88CA/CCAPI/ccConferenceDestroy:
   Conference Id=0x84F, Tag=0x0
021791: *Oct 27 07:41:48.654: //4602/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=4603, Disposition=0x0, Tag=0x0
021792: *Oct 27 07:41:48.654: //4603/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
021793: *Oct 27 07:41:48.654: //4602/7129E5DC88CA/CCAPI/cc_generic_bridge_done:
021794: *Oct 27 07:41:48.654: //4603/7129E5DC88CA/CCAPI/ccCallDisconnect:
02179
C2821-DTMSEVPR2#
C2821-DTMSEVPR2#
C2821-DTMSEVPR2#5: *Oct 27 07:41:48.654: //4603/7129E5DC88CA/CCAPI/ccCallDisconnect:
021796: *Oct 27 07:41:48.654: //4603/7129E5DC88CA/CCAPI/cc_api_get_transfer_info:
021797: *Oct 27 07:41:48.654: //4602/7129E5DC88CA/CCAPI/ccCallDisconnect:
021798: *Oct 27 07:41:48.654: //4602/7129E5DC88CA/CCAPI/ccCallDisconnect:
021799: *Oct 27 07:41:48.654: //4602/7129E5DC88CA/CCAPI/cc_api_get_transfer_info:
021800: *Oct 27 07:41:48.654: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
021801: *Oct 27 07:41:48.658: H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A000411001100712A829CE0D411DF99FA983863021ADA10800100
021802: *Oct 27 07:41:48.658:
021803: *Oct 27 07:41:48.658: //4603/7129E5DC88CA/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46FAB490, Tag=0x0, Call Id=4603,
021804: *Oct 27 07:41:48.658: //4603/7129E5DC88CA/CCAPI/cc_api_call_disconnect_done:
021805: *Oct 27 07:41:48.658: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021806: *Oct 27 07:41:48.658: :cc_free_feature_vsa freeing 46E25210
021807: *Oct 27 07:41:48.658: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021808: *Oct 27 07:41:48.658:  vsacount in free is 1
021809: *Oct 27 07:41:48.662: //4602/7129E5DC88CA/CCAPI/cc_api_call_disc_cause_update:
   Cause Value=16
021810: *Oct 27 07:41:48.662: //4602/7129E5DC88CA/CCAPI/cc_api_call_disc_cause_update:
021811: *Oct 27 07:41:48.670: //4602/7129E5DC88CA/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x472FA6C4, Tag=0x0, Call Id=4602,
021812: *Oct 27 07:41:48.670: //4602/7129E5DC88CA/CCAPI/cc_api_call_disconnect_done:
021813: *Oct 27 07:41:48.670: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021814: *Oct 27 07:41:48.670: :cc_free_feature_vsa freeing 46E252E8
021815: *Oct 27 07:41:48.670: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021816: *Oct 27 07:41:48.670:  vsacount in free is 0
021817: *Oct 27 07:41:48.674: ISDN BR0/3/0 Q931: TX -> RELEASE pd = 8  callref = 0x89
021818: *Oct 27 07:41:48.838: ISDN BR0/3/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x09
C2821-DTMSEVPR2#
C2821-DTMSEVPR2#
C2821-DTMSEVPR2#
C2821-DTMSEVPR2#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
C2821-DTMSEVPR2(config)#inter bri 1/1/0
C2821-DTMSEVPR2(config-if)#shut
C2821-DTMSEVPR2(config-if)#isdn bind-l3 ccm-manager service mgcp
C2821-DTMSEVPR2(config-if)#no shut
C2821-DTMSEVPR2(config-if)#inter bri 0/3/0
C2821-DTMSEVPR2(config-if)#inter bri 0/3/1
C2821-DTMSEVPR2(config-if)#inter bri 0/2/1
021819: *Oct 27 08:41:57: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR1/1/0, TEI 0 changed to down
021820: *Oct 27 07:41:57.898: ISDN BR1/1/0 Q931: L3_ShutDown: Shutting down ISDN Layer 3
021821: *Oct 27 08:41:57: %LINK-5-CHANGED: Interface BRI1/1/0, changed state to administratively down
021822: *Oct 27 08:41:57: %LINK-3-UPDOWN: Interface BRI1/1/0:1, changed state to down
021823: *Oct 27 08:41:57: %LINK-3-UPDOWN: Interface BRI1/1/0:2, changed state to down
021824: *Oct 27 07:41:57.950: BRI1/1/0 : Unexpected indication (4) in f3 code
021825: *Oct 27 08:41:57: %LINK-3-UPDOWN: Interface BRI1/1/0, changed state to up
021826: *Oct 27 07:41:57.986: MGCP Packet sent to 192.25.98.10:2427--->
RSIP 449158439 BRI/S1/SU1/P0/*@C2821-DTMSEVPR2.arconet.net MGCP 0.1
RM: restart
021827: *Oct 27 08:41:58: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/3/0, TEI 0 changed to down
021828: *Oct 27 07:41:58.010: MGCP Packet received from 192.25.98.10:2427--->
200 449158439
021829: *Oct 27 07:41:58.014: MGCP Packet received from 192.25.98.10:2427--->
AUEP 11211871 BRI/S1/SU1/P0/1@C2821-DTMSEVPR2.arconet.net MGCP 0.1
F: X, A, I
021830: *Oct 27 07:41:58.014: MGCP Packet sent to 192.25.98.10:2427--->
200 11211871
I:
X: 1
L: p:10-20, a:PCMU;PCMA;G.nX64, b:64, e:on, gc:1, s:on, t:10, r:g, nt:IN;ATM, v:T;G;D;L;H;R;ATM;SST;PRE
L: p:10-220, a:G.729;G.729a;G.729b, b:8, e:on, gc:1, s:on, t:10, r:g, nt:IN;ATM, v:T;G;D;L;H;R;ATM;SST;PRE
L: p:10-110, a:G.726-16;G.728, b:16, e:on, gc:1, s:on, t:10, r:g, nt:IN;ATM, v:T;G;D;L;H;R;ATM;SST;PRE
L: p:10-70, a:G.726-24, b:24, e:on, gc:1, s:on, t:10, r:g, nt:IN;ATM, v:T;G;D;L;H;R;ATM;SST;PRE
L: p:10-50, a:G.726-32, b:32, e:on, gc:1, s:on, t:10, r:g, nt:IN;ATM, v:T;G;D;L;H;R;ATM;SST;PRE
L: p:30-270, a:G.723.1-H;G.723;G.723.1a-H, b:6, e:on, gc:1, s:on, t:10, r:g, nt:IN;ATM, v:T;G;D;L;H;R;ATM;SST;PRE
L: p:30-330, a:G.723.1-L;G.723.1a-L, b:5, e:on, gc:1, s:on, t:10, r:g, nt:IN;ATM, v:T;G;D;L;H;R;ATM;SST;PRE
M: sendonly, recvonly, sendrecv, inactive, loopback, conttest, data, netwloop, netwtest
021831: *Oct 27 07:41:58.014: MGCP Packet received from 192.25.98.10:2427--->
AUEP 11211872 BRI/S1/SU1/P0/2@C2821-DTMSEVPR2.arconet.net MGCP 0.1
F: X, A, I
021832: *Oct 27 07:41:58.014: MGCP Packet sent to 192.25.98.10:2427--->
200 11211872
I:
X: 2
021833: *Oct 27 07:41:58.022: ISDN BR0/3/0 Q931: L3_ShutDown: Shutting down ISDN Layer 3
021834: *Oct 27 08:41:58: %LINK-5-CHANGED: Interface BRI0/3/0, changed state to administratively down
021835: *Oct 27 08:41:58: %LINK-3-UPDOWN: Interface BRI0/3/0:1, changed state to down
021836: *Oct 27 08:41:58: %LINK-3-UPDOWN: Interface BRI0/3/0:2, changed state to down
021837: *Oct 27 07:41:58.070: BRI0/3/0 : Unexpected indication (4) in f3 code
021838: *Oct 27 08:41:58: %LINK-3-UPDOWN: Interface BRI0/3/0, changed state to up
021839: *Oct 27 07:41:58.114: MGCP Packet sent to 192.25.98.10:2427--->
RSIP 449158440 BRI/S0/SU3/P0/*@C2821-DTMSEVPR2.arconet.net MGCP 0.1
RM: restart
021840: *Oct 27 08:41:58: %ISDN-6-LAYER2UP: Layer 2 for Interface BR1/1/0, TEI 0 changed to up
021841: *Oct 27 07:41:58.130: MGCP Packet received from 192.25.98.10:2427--->
200 449158440
021842: *Oct 27 07:41:58.130: MGCP Packet received from 192.25.98.10:2427--->
AUEP 11211873 BRI/S0/SU3/P0/1@C2821-DTMSEVPR2.arconet.net MGCP 0.1
F: X, A, I
021843: *Oct 27 07:41:58.130: MGCP Packet sent to 192.25.98.10:2427--->
200 11211873
I:
X: 1
021844: *Oct 27 07:41:58.134: MGCP Packet received from 192.25.98.10:2427--->
AUEP 11211874 BRI/S0/SU3/P0/2@C2821-DTMSEVPR2.arconet.net MGCP 0.1
F: X, A, I
021845: *Oct 27 07:41:58.134: MGCP Packet sent to 192.25.98.10:2427--->
200 11211874
I:
X: 2
021846: *Oct 27 08:41:58: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/3/1, TEI 0 changed to down
021847: *Oct 27 07:41:58.158: ISDN BR0/3/1 Q931: L3_ShutDown: Shutting down ISDN Layer 3
021848: *Oct 27 08:41:58: %LINK-3-UPDOWN: Interface BRI0/3/1:1, changed state to down
021849: *Oct 27 08:41:58: %LINK-3-UPDOWN: Interface BRI0/3/1:2, changed state to down
021850: *Oct 27 07:41:58.206: BRI0/3/1 : Unexpected indication (4) in f3 code
021851: *Oct 27 07:41:58.230: MGCP Packet sent to 192.25.98.10:2427--->
RSIP 449158441 BRI/S0/SU3/P1/*@C2821-DTMSEVPR2.arconet.net MGCP 0.1
RM: restart
021852: *Oct 27 07:41:58.246: MGCP Packet received from 192.25.98.10:2427--->
200 449158441
021853: *Oct 27 07:41:58.246: MGCP Packet received from 192.25.98.10:2427--->
AUEP 11211875 BRI/S0/SU3/P1/1@C2821-DTMSEVPR2.arconet.net MGCP 0.1
F: X, A, I
021854: *Oct 27 07:41:58.246: MGCP Packet sent to 192.25.98.10:2427--->
200 11211875
I:
X: 1
021855: *Oct 27 07:41:58.246: MGCP Packet received from 192.25.98.10:2427--->
AUEP 11211876 BRI/S0/SU3/P1/2@C2821-DTMSEVPR2.arconet.net MGCP 0.1
F: X, A, I
021856: *Oct 27 07:41:58.250: MGCP Packet sent to 192.25.98.10:2427--->
200 11211876
I:
X: 2
021857: *Oct 27 08:41:58: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/3/0, TEI 0 changed to up
021858: *Oct 27 08:41:58: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/2/1, TEI 0 changed to down
021859: *Oct 27 07:41:58.282: ISDN BR0/2/1 Q931: L3_ShutDown: Shutting down ISDN Layer 3
021860: *Oct 27 08:41:58: %LINK-5-CHANGED: Interface BRI0/2/1, changed state to administratively down
021861: *Oct 27 08:41:58: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/3/1, TEI 0 changed to up
021862: *Oct 27 08:41:59: %LINK-3-UPDOWN: Interface BRI0/2/1:1, changed state to down
021863: *Oct 27 08:41:59: %LINK-3-UPDOWN: Interface BRI0/2/1:2, changed state to down
021864: *Oct 27 07:41:59.026: BRI0/2/1 : Unexpected indication (4) in f3 code
021865: *Oct 27 08:41:59: %LINK-3-UPDOWN: Interface BRI0/2/1, changed state to up
021866: *Oct 27 07:41:59.066: MGCP Packet sent to 192.25.98.10:2427--->
RSIP 449158442 BRI/S0/SU2/P1/*@C2821-DTMSEVPR2.arconet.net MGCP 0.1
RM: restart
021867: *Oct 27 07:41:59.082: MGCP Packet received from 192.25.98.10:2427--->
200 449158442
021868: *Oct 27 07:41:59.086: MGCP Packet received from 192.25.98.10:2427--->
AUEP 11211877 BRI/S0/SU2/P1/1@C2821-DTMSEVPR2.arconet.net MGCP 0.1
F: X, A, I
021869: *Oct 27 07:41:59.086: MGCP Packet sent to 192.25.98.10:2427--->
200 11211877
I:
X: 1
021870: *Oct 27 07:41:59.086: MGCP Packet received from 192.25.98.10:2427--->
AUEP 11211878 BRI/S0/SU2/P1/2@C2821-DTMSEVPR2.arconet.net MGCP 0.1
F: X, A, I
021871: *Oct 27 07:41:59.086: MGCP Packet sent to 192.25.98.10:2427--->
200 11211878
I:
X: 2
021872: *Oct 27 08:41:59: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/2/1, TEI 0 changed to up
021873: *Oct 27 07:42:00.418: ISDN BR0/2/1 Q931: TX -> RESTART pd = 8  callref = 0x00
        Channel ID i = 0x89
                Exclusive, B1
021874: *Oct 27 07:42:00.578: ISDN BR0/2/1 Q931: RX <- RESTART_ACK pd = 8  callref = 0x80
        Channel ID i = 0x89
                Exclusive, B1
021875: *Oct 27 07:42:00.590: ISDN BR0/2/1 Q931: TX -> STATUS pd = 8  callref = 0x00
        Call State i = 0x00
021876: *Oct 27 07:42:00.766: ISDN BR0/2/1 Q931: RX <- STATUS pd = 8  callref = 0x80
        Cause i = 0x82E008 - Mandatory information element missing
        Call State i = 0x00
        Display i = 'FALTA ELEMENTO INFO. OBLIGATORIO'
C2821-DTMSEVPR2(config-if)#no shut^Z
021877: *Oct 27 08:42:08: %SYS-5-CONFIG_I: Configured from console by rearle on vty0 (192.25.99.201)
021878: *Oct 27 07:42:09.198: ISDN BR0/2/1 Q931: RX <- SETUP pd = 8  callref = 0x78
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x89
                Exclusive, B1
        Calling Party Number i = 0x0183, '607345209'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0xA1, '955658800'
                Plan:ISDN, Type:National
021879: *Oct 27 07:42:09.214: MGCP Packet received from 192.25.98.10:2427--->
CRCX 11211880 BRI/S0/SU2/P1/1@C2821-DTMSEVPR2.arconet.net MGCP 0.1
C: D000000001406b21000000F580000078
L: p:20, a:PCMU, s:off, t:00
M: recvonly
021880: *Oct 27 07:42:09.218: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x46B585D0, Interface Type=6, Destination=, Mode=0x9,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=D000000001406b21000000F580000078)
021881: *Oct 27 07:42:09.218: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
021882: *Oct 27 07:42:09.218: :cc_get_feature_vsa malloc success
021883: *Oct 27 07:42:09.218: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
021884: *Oct 27 07:42:09.218:  cc_get_feature_vsa count is 1
021885: *Oct 27 07:42:09.218: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
021886: *Oct 27 07:42:09.218: :FEATURE_VSA attributes are: feature_name:0,feature_time:1189237488,feature_id:4604
021887: *Oct 27 07:42:09.218: //4604/89B09BAB88CB/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
021888: *Oct 27 07:42:09.218: //4604/89B09BAB88CB/CCAPI/ccCallSetContext:
   Context=0x47DE0638
021889: *Oct 27 07:42:09.218: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x46A564B4, Interface Type=9, Destination=0.0.0.0, Mode=0x9,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=TRUE,
021890: *Oct 27 07:42:09.218: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
021891: *Oct 27 07:42:09.218: :cc_get_feature_vsa malloc success
021892: *Oct 27 07:42:09.218: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
021893: *Oct 27 07:42:09.218:  cc_get_feature_vsa count is 2
021894: *Oct 27 07:42:09.218: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
021895: *Oct 27 07:42:09.218: :FEATURE_VSA attributes are: feature_name:0,feature_time:1189237272,feature_id:4605
021896: *Oct 27 07:42:09.218: //4605/89B09BAB88CB/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
021897: *Oct 27 07:42:09.218: //4605/89B09BAB88CB/CCAPI/ccCallSetContext:
   Context=0x47DDFEA8
021898: *Oct 27 07:42:09.222: //4605/89B09BAB88CB/CCAPI/cc_api_call_connected:
   Interface=0x46A564B4, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
021899: *Oct 27 07:42:09.222: //4605/89B09BAB88CB/CCAPI/cc_api_call_connected:
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
021900: *Oct 27 07:42:09.222: //4604/89B09BAB88CB/CCAPI/cc_api_call_proceeding:
   Interface=0x46B585D0, Progress Indication=NULL(0)
021901: *Oct 27 07:42:09.234: //4604/89B09BAB88CB/CCAPI/cc_api_call_connected:
   Interface=0x46B585D0, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
   Connection Handle=0
021902: *Oct 27 07:42:09.234: //4604/89B09BAB88CB/CCAPI/cc_api_call_connected:
021903: *Oct 27 07:42:09.234: //4604/89B09BAB88CB/CCAPI/ccCallModify:
   Nominator=0x1000, Params=0x493ED940, Call Id=4604
021904: *Oct 27 07:42:09.234: //4604/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x11FC, digit_event=0x1, enable=TRUE, consume=FALSE)
021905: *Oct 27 07:42:09.234: //4604/89B09BAB88CB/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=4604
021906: *Oct 27 07:42:09.234: //4604/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x46B585D0, callID=0x11FC, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
021907: *Oct 27 07:42:09.234: //4604/89B09BAB88CB/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x46B585D0, Call Id=4604
021908: *Oct 27 07:42:09.234: //4604/89B09BAB88CB/CCAPI/cc_api_call_report_digits_done:
   Call Entry(Initial Digit Timeout=10000(ms), Inter Digit Timeout=10000(ms))
021909: *Oct 27 07:42:09.234: //4604/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x493EDAE4, callID1=0x11FC, callID2=0x11FD, tag=0x0)
021910: *Oct 27 07:42:09.234: //4604/89B09BAB88CB/CCAPI/ccConferenceCreate:
   Conference Id=0x493EDAE4, Call Id1=4604, Call Id2=4605, Tag=0x0
021911: *Oct 27 07:42:09.234: //4604/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x850, Source Interface=0x46B585D0, Source Call Id=4604,
   Destination Call Id=4605, Disposition=0x0, Tag=0xFFFFFFFF
021912: *Oct 27 07:42:09.234: //4605/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x850, Source Interface=0x46A564B4, Source Call Id=4605,
   Destination Call Id=4604, Disposition=0x0, Tag=0x0
021913: *Oct 27 07:42:09.234: //4604/89B09BAB88CB/CCAPI/cc_generic_bridge_done:
021914: *Oct 27 07:42:09.234: //4604/89B09BAB88CB/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x850, Destination Call Id=4605)
021915: *Oct 27 07:42:09.234: //4605/89B09BAB88CB/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x850, Destination Call Id=4604)
021916: *Oct 27 07:42:09.234: //4604/89B09BAB88CB/CCAPI/cc_api_caps_ind:
   Destination Interface=0x46A564B4, Destination Call Id=4605, Source Call Id=4604,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
021917: *Oct 27 07:42:09.234: //4604/89B09BAB88CB/CCAPI/cc_api_caps_ind:
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=200(ms), Fax Nom=300(ms))
021918: *Oct 27 07:42:09.234: //4605/89B09BAB88CB/CCAPI/cc_api_caps_ind:
   Destination Interface=0x46B585D0, Destination Call Id=4604, Source Call Id=4605,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
021919: *Oct 27 07:42:09.234: //4605/89B09BAB88CB/CCAPI/cc_api_caps_ind:
   Playout Max=250(ms), Fax Nom=300(ms))
021920: *Oct 27 07:42:09.234: //4605/89B09BAB88CB/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=3689)
021921: *Oct 27 07:42:09.238: //4604/89B09BAB88CB/CCAPI/cc_api_caps_ack:
021922: *Oct 27 07:42:09.238: //4604/89B09BAB88CB/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x46B585D0, Call Id=4604
021923: *Oct 27 07:42:09.238: //4604/89B09BAB88CB/CCAPI/cc_api_voice_mode_event:
   Call Id=4604
021924: *Oct 27 07:42:09.238: //4604/89B09BAB88CB/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x47DE0638)
021925: *Oct 27 07:42:09.238: //4604/89B09BAB88CB/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x850, Call Id1=4604, Call Id2=4605
021926: *Oct 27 07:42:09.242: MGCP Packet sent to 192.25.98.10:2427--->
200 11211880 OK
I: 376
v=0
c=IN IP4 192.24.5.1
m=audio 18868 RTP/AVP 0 100
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194,200-202
a=X-sqn:0
a=X-cap: 1 audio RTP/AVP 100
a=X-cpar: a=rtpmap:100 X-NSE/8000
a=X-cpar: a=fmtp:100 192-194,200-202
a=X-cap: 2 image udptl t38
021927: *Oct 27 07:42:09.258: ISDN BR0/2/1 Q931: TX -> CALL_PROC pd = 8  callref = 0xF8
        Channel ID i = 0x89
                Exclusive, B1
021928: *Oct 27 07:42:09.258: MGCP Packet received from 192.25.98.10:2427--->
RQNT 11211881 BRI/S0/SU2/P1/1@C2821-DTMSEVPR2.arconet.net MGCP 0.1
X: 1
R: D/[0-9ABCD*#]
S: G/rt
Q: process,loop
021929: *Oct 27 07:42:09.258: //4604/89B09BAB88CB/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms)
021930: *Oct 27 07:42:09.258: //4604/89B09BAB88CB/CCAPI/ccSetDigitTimeouts:
   Call Entry(Inter Digit Timeout=4000(ms), Initial Digit Timeout=4000(ms))
021931: *Oct 27 07:42:09.258: //4604/89B09BAB88CB/CCAPI/ccRestartDigitTimeoutMsec:
   Digit Timeout=0, Call Id=4604
021932: *Oct 27 07:42:09.258: //4604/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
021933: *Oct 27 07:42:09.258: //4604/89B09BAB88CB/CCAPI/ccCallReportDigits:
021934: *Oct 27 07:42:09.258: //4604/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
021935: *Oct 27 07:42:09.258: //4604/89B09BAB88CB/CCAPI/cc_api_call_report_digits_done:
021936: *Oct 27 07:42:09.258: //4604/89B09BAB88CB/CCAPI/cc_api_call_report_digits_done:
   Call Entry(Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms))
021937: *Oct 27 07:42:09.258: //4604/89B09BAB88CB/CCAPI/ccCallModify:
   Nominator=0x1000, Params=0x493ED320, Call Id=4604
021938: *Oct 27 07:42:09.258: //4604/89B09BAB88CB/CCAPI/cc_api_call_modify_done:
021939: *Oct 27 07:42:09.262: //4604/89B09BAB88CB/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Ring Back,
   Tone Direction=Network, Params=0x0, Call Id=4604
021940: *Oct 27 07:42:09.262: MGCP Packet sent to 192.25.98.10:2427--->
200 11211881 OK
021941: *Oct 27 07:42:09.274: MGCP Packet receishow voice call stat0:2427--->
MDCX 11211883 BRI/S0/SU2/P1/1@C2821-DTMSEVPR2.arconet.net MGCP 0.1
I: 376
X: 1
L: p:30, a:G.729, s:off, t:b8
M: recvonly
R: D/[0-9ABCD*#]
Q: process,loop
021942: *Oct 27 07:42:09.274: //4604/89B09BAB88CB/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
021943: *Oct 27 07:42:09.274: //4604/89B09BAB88CB/CCAPI/ccCallModifyExtended:
   Nominator=0x493ED678, Params=0x493ECB18, Call Id=4604
021944: *Oct 27 07:42:09.274: //4605/89B09BAB88CB/CCAPI/ccCallModify:
   Nominator=0x19830, Params=0x493ECCA8, Call Id=4605
021945: *Oct 27 07:42:09.274: //4604/89B09BAB88CB/CCAPI/cc_api_call_modify_done:
021946: *Oct 27 07:42:09.278: //4605/89B09BAB88CB/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x46A564B4, Call Id=4605
021947: *Oct 27 07:42:09.278: MGCP Packet sent to 192.25.98.10:2427--->
200 11211883 OK
v=0
c=IN IP4 192.24.5.1
m=audio 18868 RTP/AVP 18
a=X-sqn:0
021948: *Oct 27 07:42:09.294: MGCP Packet received from 192.25.98.10:2427--->
MDCX 11211884 BRI/S0/SU2/P1/1@C2821-DTMSEVPR2.arconet.net MGCP 0.1
I: 376
X: 1
M: sendrecv
R: D/[0-9ABCD*#]
S:
Q: process,loop
v=0
o=- 886 0 IN EPN BRI/S0/SU2/P1/1@C2821-DTMSEVPR2.arconet.net
s=Cisco SDP 0
t=0 0
m=audio 30036 RTP/AVP 18
c=IN IP4 192.25.98.8
021949: *Oct 27 07:42:09.294: //4604/89B09BAB88CB/CCAPI/ccCallModifyExtended:
021950: *Oct 27 07:42:09.294: //4605/89B09BAB88CB/CCAPI/ccCallModify:
   Nominator=0x18E30, Params=0x493ECCA8, Call Id=4605
021951: *Oct 27 07:42:09.298: //4604/89B09BAB88CB/CCAPI/cc_api_call_modify_done:
021952: *Oct 27 07:42:09.298: //4605/89B09BAB88CB/CCAPI/cc_api_call_modify_done:
021953: *Oct 27 07:42:09.298: MGCP Packet sent to 192.25.98.10:2427--->
200 11211884 OK
021954: *Oct 27 07:42:09.366: ISDN BR0/2/1 Q931: TX -> ALERTING pd = 8  callref = 0xF8
        Progress Ind i = 0x8088 - In-band info or appropriate now available
021955: *Oct 27 07:42:09.454: ISDN BR0/2/1 Q931: TX -> CONNECT pd = 8  callref = 0xF8
021956: *Oct 27 07:42:09.618: ISDN BR0/2/1 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x78
0x11FC     1AAA 0x46B585D0 0/2/1.0          0/1:1  *           g729r8    0/0
1 active call found
1 active call found
C2821-DTMSEVPR2#
021957: *Oct 27 07:42:13.258: //4604/89B09BAB88CB/CCAPI/cc_handle_inter_digit_timer:
   Generate inter-digit timeout CC_EV_CALL_DIGIT_END event
021958: *Oct 27 07:42:14.542: ISDN BR0/2/1 Q931: RX <- DISCONNECT pd = 8  callref = 0x78
021959: *Oct 27 07:42:14.554: MGCP Packet received from 192.25.98.10:2427--->
MDCX 11211885 BRI/S0/SU2/P1/1@C2821-DTMSEVPR2.arconet.net MGCP 0.1
I: 376
X: 1
M: recvonly
R: D/[0-9ABCD*#]
Q: process,loop
021960: *Oct 27 07:42:14.554: //4604/89B09BAB88CB/CCAPI/ccCallModifyExtended:
021961: *Oct 27 07:42:14.558: //4605/89B09BAB88CB/CCAPI/ccCallModify:
   Nominator=0x800, Params=0x493ECCA8, Call Id=4605
021962: *Oct 27 07:42:14.558: //4604/89B09BAB88CB/CCAPI/cc_api_call_modify_done:
021963: *Oct 27 07:42:14.558: //4605/89B09BAB88CB/CCAPI/cc_api_call_modify_done:
021964: *Oct 27 07:42:14.558: MGCP Packet sent to 192.25.98.10:2427--->
200 11211885 OK
021965: *Oct 27 07:42:14.574: ISDN BR0/2/1 Q931: TX -> RELEASE pd = 8  callref = 0xF8
021966: *Oct 27 07:42:14.714: ISDN BR0/2/1 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x78
021967: *Oct 27 07:42:14.726: MGCP Packet received from 192.25.98.10:2427--->
DLCX 11211886 BRI/S0/SU2/P1/1@C2821-DTMSEVPR2.arconet.net MGCP 0.1
I: 376
X: 1
S:
021968: *Oct 27 07:42:14.726: //4604/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x11FC, digit_event=0x0, enable=FALSE, consume=FALSE)
021969: *Oct 27 07:42:14.726: //4604/89B09BAB88CB/CCAPI/ccCallReportDigits:
021970: *Oct 27 07:42:14.726: //4604/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x46B585D0, callID=0x11FC, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
021971: *Oct 27 07:42:14.726: //4604/89B09BAB88CB/CCAPI/cc_api_call_report_digits_done:
021972: *Oct 27 07:42:14.726: //4604/89B09BAB88CB/CCAPI/cc_api_call_report_digits_done:
021973: *Oct 27 07:42:14.726: //4605/89B09BAB88CB/CCAPI/ccGetCallStatistics:
   Call Stats=0x47FE1488, Call Id=4605
021974: *Oct 27 07:42:14.730: //4604/89B09BAB88CB/CCAPI/ccConferenceDestroy:
   Conference Id=0x850, Tag=0x0
021975: *Oct 27 07:42:14.730: //4604/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=4605, Disposition=0x0, Tag=0x0
021976: *Oct 27 07:42:14.730: //4605/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
021977: *Oct 27 07:42:14.730: //4604/89B09BAB88CB/CCAPI/cc_generic_bridge_done:
021978: *Oct 27 07:42:14.730: //4604/89B09BAB88CB/CCAPI/ccCallDisconnect:
021979: *Oct 27 07:42:14.730: //4604/89B09BAB88CB/CCAPI/ccCallDisconnect:
021980: *Oct 27 07:42:14.730: //4604/89B09BAB88CB/CCAPI/cc_api_get_transfer_info:
021981: *Oct 27 07:42:14.730: //4605/89B09BAB88CB/CCAPI/ccCallDisconnect:
021982: *Oct 27 07:42:14.730: //4605/89B09BAB88CB/CCAPI/ccCallDisconnect:
021983: *Oct 27 07:42:14.730: //4605/89B09BAB88CB/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46A564B4, Tag=0x0, Call Id=4605,
021984: *Oct 27 07:42:14.730: //4605/89B09BAB88CB/CCAPI/cc_api_call_disconnect_done:
021985: *Oct 27 07:42:14.730: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021986: *Oct 27 07:42:14.730: :cc_free_feature_vsa freeing 46E25210
021987: *Oct 27 07:42:14.730: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021988: *Oct 27 07:42:14.730:  vsacount in free is 1
021989: *Oct 27 07:42:14.742: //4604/89B09BAB88CB/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46B585D0, Tag=0x0, Call Id=4604,
021990: *Oct 27 07:42:14.742: //4604/89B09BAB88CB/CCAPI/cc_api_call_disconnect_done:
021991: *Oct 27 07:42:14.746: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021992: *Oct 27 07:42:14.746: :cc_free_feature_vsa freeing 46E252E8
021993: *Oct 27 07:42:14.746: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
021994: *Oct 27 07:42:14.746:  vsacount in free is 0
021995: *Oct 27 07:42:14.746: MGCP Packet sent to 192.25.98.10:2427--->
250 11211886 OK
P: PS=174, OS=5220, PR=174, OR=5191, PL=0, JI=6, LA=0
I have one port that actually works with h323 without any problems at the moment. the called number is matched through the same dial peer 955 to 955658798 and goes through without any MGCP port picking up the call. Here is the debug of a good H323 call.
3d00h: ISDN BR1/1/1 Q931: RX <- SETUP pd = 8  callref = 0x79
        Sending Complete
                Standard = CCITT
        Channel ID i = 0x89
                Exclusive, B1
        Calling Party Number i = 0x2183, '607345209'
        Called Party Number i = 0xA1, '955658798'
3d00h: //-1/4FD0B8EB86F5/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=607345209
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=955658798
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
3d00h: //-1/4FD0B8EB86F5/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x46B96964, Call Info(
   Calling Number=607345209,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=955658798(TON=National, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=14, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
3d00h: //-1/4FD0B8EB86F5/CCAPI/ccCheckClipClir:
   In: Calling Number=607345209(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Out: Calling Number=607345209(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
3d00h: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3d00h: :cc_get_feature_vsa malloc success
3d00h:  cc_get_feature_vsa count is 9
3d00h: :FEATURE_VSA attributes are: feature_name:0,feature_time:1189238784,feature_id:3676
3d00h: //3676/4FD0B8EB86F5/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=607345209(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=955658798(TON=National, NPI=ISDN))
3d00h: //3676/4FD0B8EB86F5/CCAPI/cc_process_call_setup_ind:
   Event=0x46B07CE8
3d00h: //3676/4FD0B8EB86F5/CCAPI/ccCallSetContext:
   Context=0x490F96FC
   >>>>CCAPI handed cid 3676 with tag 14 to app "_ManagedAppProcess_Default"
3d00h: //3676/4FD0B8EB86F5/CCAPI/ccCallProceeding:
3d00h: //3676/4FD0B8EB86F5/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=955, Params=0x490F5D6C, Progress Indication=NULL(0)
3d00h: //3676/4FD0B8EB86F5/CCAPI/ccCheckClipClir:
   Destination Pattern=955658..., Called Number=955658798, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=4FD0B8EB-E025-11DF-86F5-001E13CE2E20, Outgoing Dial-peer=955
3d00h: //3676/4FD0B8EB86F5/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=607345209
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=955658798
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
3d00h: //3676/4FD0B8EB86F5/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x46FAB490, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=607345209,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=955658798(TON=National, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=955, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
3d00h:  cc_get_feature_vsa count is 10
3d00h: :FEATURE_VSA attributes are: feature_name:0,feature_time:1189238568,feature_id:3677
3d00h: //3677/4FD0B8EB86F5/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
3d00h: //3677/4FD0B8EB86F5/CCAPI/ccCallSetContext:
   Context=0x490F5D1C
3d00h: //3676/4FD0B8EB86F5/CCAPI/ccSaveDialpeerTag:
3d00h: ISDN BR1/1/1 Q931: TX -> CALL_PROC pd = 8  callref = 0xF9
        Channel ID i = 0x89
                Exclusive, B1
3d00h: //3677/4FD0B8EB86F5/CCAPI/cc_api_set_called_ccm_detected:
   CallInfo(called ccm detected=TRUE ccmVersion 3)
3d00h: //3677/4FD0B8EB86F5/CCAPI/cc_api_call_proceeding:
   Interface=0x46FAB490, Progress Indication=NULL(0)
3d00h: //3677/4FD0B8EB86F5/CCAPI/cc_api_set_delay_xport:
   CallInfo(delay xport=TRUE)
3d00h: //3677/4FD0B8EB86F5/CCAPI/cc_api_call_alert:
   Interface=0x46FAB490, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
3d00h: //3677/4FD0B8EB86F5/CCAPI/cc_api_call_notify:
   Data Bitmask=0x5, Interface=0x46FAB490, Call Id=3677
3d00h: //3676/4FD0B8EB86F5/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, AlertSent=TRUE)
3d00h: //3676/4FD0B8EB86F5/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=3676
3d00h: ISDN BR1/1/1 Q931: TX -> ALERTING pd = show debug
3d00h: //3677/4FD0B8EB86F5/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
   CallInfo(ssCTreRoutingNotSupported=FALSE)
3d00h: //3677/4FD0B8EB86F5/CCAPI/cc_api_get_ccm_detected:
   CallInfo(ccm detected=TRUE)
3d00h: //3676/4FD0B8EB86F5/CCAPI/ccCallNotify:
   Data Bitmask=0x5, Call Id=3676
3d00h: ISDN BR0/1/1 Q931: TX -> CONNECT pd = 8  callref = 0xEA
3d00h: MGCP Packet received from 192.25.98.10:2427--->
MDCX 11190188 BRI/S0/SU1/P1/1@C2821-DTMSEVPR2.arconet.net MGCP 0.1
C: D000000001402738000000F58000006a
I: 1D0
X: 1
L: p:20, a:PCMU, s:off, t:b8
M: recvonly
R: D/[0-9ABCD*#]
Q: process,loop
3d00h: //3674/4E21CFDC86F4/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=3674
3d00h: //3674/4E21CFDC86F4/CCAPI/ccCallModifyExtended:
   Nominator=0x493ED678, Params=0x493ECB18, Call Id=3674
3d00h: //3675/4E21CFDC86F4/CCAPI/ccCallModify:
   Nominator=0x19830, Params=0x493ECCA8, Call Id=3675
3d00h: //3675/4E21CFDC86F4/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x46A564B4, Call Id=3675
3d00h: //3674/4E21CFDC86F4/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x46B48D98, Call Id=3674
3d00h: MGCP Packet sent to 192.25.98.10:2427--->
200 11190188 OK
v=0
c=IN IP4 192.24.5.1
m=audio 19232 RTP/AVP 0
a=X-sqn:0
MDCX 11190189 BRI/S0/SU1/P1/1@C2821-DTMSEVPR2.arconet.net MGCP 0.1
I: 1D0
X: 1
M: sendrecv
R: D/[0-9ABCD*#]
S:
Q: process,loop
v=0
o=- 464 0 IN EPN BRI/S0/SU1/P1/1@C2821-DTMSEVPR2.arconet.net
s=Cisco SDP 0
t=0 0
m=audio 23904 RTP/AVP 0
c=IN IP4 192.24.5.70
   Nominator=0x18E30, Params=0x493ECCA8, Call Id=3675
200 11190189 OK
3d00h: ISDN BR0/1/1 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x6A
3d00h: //3672/4E1B18F486F3/CCAPI/cc_handle_inter_digit_timer:
3d00h: //3674/4E21CFDC86F4/CCAPI/cc_handle_inter_digit_timer:
C2821-DTMSEVPR2#
There was a problem with a loop in the incoming calls to the BRI and outgoing on the PRI these were coming to
955658800 hiting the correct BRI hunting through them going to the CUCM via h323 and going out the PRI because of a problem with a time schedule applied to a partition and call routing changing the CSS on the h323 gateway. Once we looked in CUCM to find the partition that was missing during the schedule and changed the CSS we fixed the problem. Initially I thought we
were hitting a translation pattern in CUCM for 955658800 but in fact it was going to a pilot point for Unity and then to a Call Handler from there. Using the Digit Analyzer we were able to determine the calls going out the route pattern and coming back in from the telco.
