07-19-2013 07:07 AM - edited 03-16-2019 06:26 PM
Hey team,
I have been configuring MGCP communication between our communication manger and a Siemens PBX.
But I don´t have a DNS server at moment in our lab.
Can I configure the Domain name field with IP of the router?
thanks.
Solved! Go to Solution.
07-19-2013 09:00 AM
Hi Jean,
You are using BNC cable since u are using Co-axial connectors on VWIC card? Did u try swapping them.
Are u using some convertor between Siemens and router or on Siemens side u also have BNC connectors?
Can u share the show inventory/diag from the router?
regds,
aman
07-19-2013 07:27 AM
Hi Jean,
you can configure the command ip host [hostname of CUCM] [ip address of CUCM server] in MGCP router.
In Call manager under MGCP config----Domain Name [enter the hostname of router]
regds,
aman
07-19-2013 08:05 AM
Hey,
Commands has been done.
But My router MGCP does not register on CUCM.
Print file was attached..
My configuration is:
em01vg01#sh running-config
Building configuration...
Current configuration : 3598 bytes
! Last configuration change at 12:02:09 BRAZIL Fri Jul 19 2013 by cisco
! NVRAM config last updated at 11:59:46 BRAZIL Fri Jul 19 2013
version 15.1
hostname em01vg01
boot-start-marker
boot-end-marker
card type e1 0 0
! card type command needed for slot/vwic-slot 0/1
no aaa new-model
clock timezone BRAZIL -3 0
network-clock-participate wic 0
no ipv6 cef
ip source-route
ip cef
ip dhcp pool 1
network 10.13.1.0 255.255.255.0
dns-server 10.13.1.10 10.13.1.20
ip host em01cucmpub 10.13.1.242
isdn switch-type primary-qsig
--More-- crypto pki token default removal timeout 0
voice-card 0
dsp services dspfarm
voice service voip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
voice class codec 10
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
codec preference 4 g729br8
voice class h323 1
license udi pid CISCO2911/K9 sn FTX1652A1GZ
hw-module pvdm 0/0
username cisco privilege 15 secret 4 1wLgDhbOLsU0GdsP0B9e5YU2KA7gxZujqOLWf0j48q6
redundancy
controller E1 0/0/0
line-termination 75-ohm
pri-group timeslots 1-31 service mgcp
description PBX trunk
controller E1 0/0/1
--More-- !
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 10.13.1.151 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
no logging event link-status
isdn overlap-receiving
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
--More-- voice-port 0/0/0:15
echo-cancel coverage 64
cptone BR
ccm-manager redundant-host 10.13.1.156 10.13.1.157
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.13.1.242
ccm-manager config
mgcp
mgcp call-agent 10.13.1.242 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 10.13.1.242 identifier 10 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 10 priority 1
associate profile 200 register conference
associate profile 100 register transcode
dspfarm profile 100 transcode
description transcoder
shutdown
dial-peer voice 10 pots
description MGCP x Siemens
service mgcpapp
--More-- port 0/0/0:15
gatekeeper
shutdown
telephony-service
max-conferences 8 gain -6
transfer-system full-consult
07-19-2013 08:23 AM
Hi Jean,
Is your controller UP?
regds,
aman
07-19-2013 08:27 AM
My controller is down and my voice port also! Very strange..
em01vg01#sh controllers E1 0/0/0
E1 0/0/0 is down.
Applique type is Channelized E1 - unbalanced
Description: PBX trunk
Transmitter is sending remote alarm.
Receiver has loss of signal.
alarm-trigger is not set
Version info FPGA Rev: 08121917, FPGA Type: PRK4
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
International Bit: 1, National Bits: 11111
em01vg01#sh voice port 0/0/0:15
DS0 Group 0/0/0:15 - 0/0/0:15
Type of VoicePort is XCC
Operation State is DOWN
Administrative State is UP
No Interface Down Failure
Description is not set
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 0 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
07-19-2013 08:29 AM
I have already run the command "no shut"
07-19-2013 09:00 AM
Hi Jean,
regds,
aman
07-19-2013 09:15 AM
I´m gonna invert the cables.. If I have access at data center.
I will send a report when it done.
07-19-2013 09:24 AM
Hi Jean,
Make sure Siemens side is configured as netowrk side and router is user side.Under the serial port , issue the command isdn protocol-emulate user
also, share show controllers E1 output.
regds,
aman
07-23-2013 10:55 AM
Hey,
I have inverted the cables and controller status became up.
But my MGCP is not registered on CUCM.
em01vg01#sh controllers e1 0/0/0
E1 0/0/0 is up.
No alarms detected.
Data in current interval (765 seconds elapsed):
4075 Line Code Violations, 0 Path Code Violations
35 Slip Secs, 0 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins
35 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 20 Unavail Secs
Data in Interval 1:
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 900 Unavail Secs
Data in Interval 2:
Data in Interval 3:
Data in Interval 4:
Data in Interval 5:
Data in Interval 6:
Data in Interval 7:
Data in Interval 8:
Operation State is DORMANT
The Last Interface Down Failure Cause is Administrative Shutdown
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 128 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 1000 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is normal
Connection Number is not set
Initial Time Out is set to 15 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 60 s
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 30 s
Companding Type is A-law
Rx A bit no conditioning set
Rx B bit no conditioning set
Rx C bit no conditioning set
Rx D bit no conditioning set
Tx A bit no conditioning set
Tx B bit no conditioning set
Tx C bit no conditioning set
Tx D bit no conditioning set
Region Tone is set for US
Continuity Test Tone CO1 is set to 2010
Continuity Test Tone CO2 is set to 1780
Station name None, Station number None
em01vg01#sh interfaces serial 0/0/0:15
Serial0/0/0:15 is up, line protocol is up (spoofing)
Hardware is DSX1
MTU 1500 bytes, BW 64 Kbit/sec, DLY 20000 usec,
Encapsulation HDLC, crc 16, loopback not set
Keepalive set (10 sec)
Last input 00:00:08, output 00:00:08, output hang never
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 48 kilobits/sec
157 packets input, 627 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
158 packets output, 630 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
2 carrier transitions
07-23-2013 08:28 PM
Hi Jean,
Can share the output of commands :
show ccm-manager
show mgcp
debug mgcp packets
regds,
aman
07-23-2013 08:45 PM
Hi Jean,
Please also share output of
show isdn status
show version and show diag
regds,
aman
07-24-2013 06:14 AM
Hey,
Thank you so much!!
MGCP is working properly!!!
I have removed all configuration and I create again.
att.
07-24-2013 08:25 AM
Hi Jean,
Thanks for the rating.But could not find the root cause.
regds,
aman
