MGCP Domain Name
waqas sardar
Dear Team ,
I want to add gateway in call manager . But  "show ccm-manager " not showing the MGCP Domain Name ? Please see the configuration
version 15.4
hostname NLL-VG
boot-start-marker
boot-end-marker
card type e1 0 0
no aaa new-model
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
ip domain name nbkcapital.kwi
ip cef
no ipv6 cef
isdn switch-type primary-net5
cts logging verbose
voice-card 0
license udi pid CISCO2921/K9 sn FCZ192160YR
hw-module pvdm 0/0
redundancy
controller E1 0/0/0
 framing NO-CRC4
 pri-group timeslots 1-4,16 service mgcp
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 192.168.211.1 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0/0/0:15
 no ip address
 encapsulation hdlc
 isdn incoming-voice voice
 isdn bind-l3 ccm-manager
 isdn outgoing display-ie
 isdn outgoing ie redirecting-number
 no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
voice-port 0/0/0:15
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
mgcp
mgcp call-agent 192.168.211.15 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
ccm-manager music-on-hold
ccm-manager switchback immediate
ccm-manager fallback-mgcp
ccm-manager mgcp
ccm-manager config
gatekeeper
 shutdown
line con 0
 login local
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login local
 transport input all
scheduler allocate 20000 1000
ntp master 2
end
NBK-VG#sh ccm
NBK-VG#sh ccm-manager
MGCP Domain Name:
Priority        Status                   Host
Primary         Down                     192.168.211.15
First Backup    None
Second Backup   None
Current active Call Manager:    None
Backhaul/Redundant link port:   2428
Failover Interval:              30 seconds
Keepalive Interval:             15 seconds
Last keepalive sent:            11:24:07 UTC Jul 5 2015 (elapsed time: 00:06:51)
Last MGCP traffic time:         11:24:07 UTC Jul 5 2015 (elapsed time: 00:06:51)
Last failover time:             None
Last switchback time:           None
Switchback mode:                Immediate
MGCP Fallback mode:             Enabled/OFF
Last MGCP Fallback start time:  None
Last MGCP Fallback end time:    None
MGCP Download Tones:            Disabled
TFTP retry count to shut Ports: 2
Backhaul/Redundant link is down
Configuration Auto-Download Information
 No configurations downloaded
Current state: Waiting for commands
Configuration Download statistics:
Download Attempted             : 1
 Download Successful          : 0
 Download Failed              : 1
 TFTP Download Failed         : 0
Configuration Attempted        : 0
 Configuration Successful     : 0
 Configuration Failed(Parsing): 0
 Configuration Failed(config) : 0
Last config download command:
FAX mode: cisco
Configuration Error History:
TFTP File download failed
yahsiel2004
Level 7
Level 7
Did you just recently add the domain name? If so, bounce MGCP (no mgcp and then mgcp).
Yosh
HTH Regards, Yosh
mgcp domain name will populate automatically once the gateway registers with cucm. It will the gateway fqdn.
However, I think your problem is beyond the domain name. I think the gateway isn't registering with cucm
1. Did you configure mgcp endpoints in cucm.
2. Can you check reachability between cucm and your gateway using the assigned source interface
3. Please share the output of debug mgcp packets, sh mgcp endpoints, sh mgcp connections
