MGCP FXO Caller ID
FXO ports with calls coming in from the prima cell and configured for service MGCP are not providing caller ID
The system is running MGCP with voice gateway Cisco 2901
System version: 11.5.1.11900-26
caller ID is unknown when enable it from cucm appear 0 number
please help
Jinto Alakkal
Hi Mahmoud.Abdelkhalek,
What's your ios version. let me know.
Thanks!
Jinto.
C2900-UNIVERSALK9-M), Version 15.3(3)M2
Could you please try to upgrade the router to IOS version 15.4, earlier versions have Caller ID issues for MGCP. In case if you cannot upgrade the router, use SIP or H.323 as the protocol and you won't see this issue anymore.
Thanks!
Jinto.
iantra123
Level 3
Level 3
This is that worked for me, on the voice-port
caller-id alerting ring 2
shutdown
no shutdown
