MGCP FXO calling name not displaying
Ayaz Khan
I have Cisco 2901 GW configured as MGCP.  IOS version 15.0(1r)M12.  We are not getting Calling name, it is appearing as "O".  Calling number is working fine.  The only option I can find to turn on this feature is under the voice port, Caller-id enable.
If anyone has encountered this problem or has any ideas please let me know.  If more infomration is requied please let me know.
Debug voice ccapi inout
ABOY-MA-VG-01#ter mon
ABOY-MA-VG-01#
Jun 22 11:07:08.378 EDT: //-1/C522BD518768/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=19058476800
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=8250
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Jun 22 11:07:08.378 EDT: //-1/C522BD518768/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x30D4DCD4, Call Info(
   Calling Number=19058476800,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=8250(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=999000, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Jun 22 11:07:08.378 EDT: //-1/C522BD518768/CCAPI/ccCheckClipClir:
   In: Calling Number=19058476800(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=19058476800(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Jun 22 11:07:08.378 EDT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jun 22 11:07:08.378 EDT: :cc_get_feature_vsa malloc success
Jun 22 11:07:08.378 EDT:  cc_get_feature_vsa count is 1
Jun 22 11:07:08.378 EDT: :FEATURE_VSA attributes are: feature_name:0,feature_time:716741080,feature_id:779
Jun 22 11:07:08.378 EDT: //754/C522BD518768/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=19058476800(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=8250(TON=Unknown, NPI=Unknown))
Jun 22 11:07:08.378 EDT: //754/C522BD518768/CCAPI/cc_process_call_setup_ind:
   Event=0x30D2F298
Jun 22 11:07:08.378 EDT: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 8250
   >>>>CCAPI handed cid 754 with tag 999000 to app "MGCPAPP"
Jun 22 11:07:08.378 EDT: //754/C522BD518768/CCAPI/ccCallSetContext:
   Context=0x31986C30
Jun 22 11:07:08.378 EDT: //754/C522BD518768/CCAPI/ccCallSetupAck:
   Call Id=754
Jun 22 11:07:08.378 EDT: //754/C522BD518768/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
Jun 22 11:07:08.378 EDT: //754/C522BD518768/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x0
   Call Entry(Connected=TRUE, Responsed=TRUE)
Jun 22 11:07:08.386 EDT: //754/C522BD518768/CCAPI/ccCallModify:
   Nominator=0x1, Params=0x31890370, Call Id=754
Jun 22 11:07:08.386 EDT: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x2B32E584, Interface Type=9, Destination=0.0.0.0, Mode=0x9,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
15 Replies 15
As above, Cisco will not change MGCP just because someone is billed.
