01-08-2013 01:22 AM - edited 03-16-2019 03:02 PM
Hi there,
I'm not getting my BR1 gateway registered in cucm.
In my br1 gateway if i troubleshoot layer by layer i did the following
sh isdn status=> multiple frame established
sh ccm-manager=> callmager registered with 10.10.210.10
i removed mgcp bind control source-interface
i removed mgcp bind media source-interface
Re-added them
Did a " no mgcp " mgcp.
Under my controller t1 0/2/0 i configured pri-froup timeslots, 24 service mgcp
I have to mention i'm not able to add the following command under my serial interface 0/2/0:
isdn bind l3 ccmanager it's missing
But still my br1 gateway in cucm showe unregistered very strange.
I've added the branch gateway in callmanager domain name matches exactly but still no success.
Solved! Go to Solution.
01-08-2013 09:57 AM
Hi monasir81,
Can you shut the voice-port, serial interface, controller, after which, remove the pri-group command and re-add it back with service mgcp. Then check to see if you get the option for l3 ccm-manager. Dont forget to do a no shut on all 3 after doing this. Let me know how it goes.
Harmit.
01-08-2013 01:26 AM
HI
what is the router you are using and what is the IOS.
reagrds
Ronak Patel
01-08-2013 02:06 AM
Hi Ronak,
I'm using a 2801 router:
IOS:
c2801-adventerprisek9_ivs-mz.124-22.T5.bin
Hope this will help
01-08-2013 06:49 AM
Exactly what happens when you try to add:
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
01-08-2013 09:38 AM
Hi Jaime,
Unfortunaley that's not possible for me i cannot add the command "isdn bind l3 ccmanager
Only "isdn bind-l3 q931" is the available option.
Under my T1 controller config i've added:
pri-group timeslots 1-3,24 service mgcp
Could it be a problem of my cisco 2801 router with a old ios?
I have :
01-08-2013 09:57 AM
Hi monasir81,
Harmit.
01-08-2013 10:37 AM
Harmit,
It worked!
I've shutdown all the three re-added the pri-group.
Did a no shut....
isdn bind l3 ccm-manager is nowe available
I also see that under my serial interface q931 is baukhauled to ccm manager!
sh ccm-manager is registered and also in cucm.
Thanks men you are great!;-)
Mohamed
01-08-2013 10:40 AM
Awesome! Glad to hear that Mohamed :-) See you around.
Harmit.
