01-08-2013 10:09 AM - edited 03-16-2019 03:03 PM
some ports seem to have gone in the VG224 (still working so i can backup config)
i have been sent a replacment VG
how do i copy all settings to the new device with as little hassle as possible.
Solved! Go to Solution.
01-08-2013 10:15 AM
VG224 is IOS driven so simply copy the "sh run" config" and apply to the new GW. If you are using SCCP or MGCP protocol to control the ports you will need to change the device name with the new MAC address of the GW in CUCM.
HTH,
Chris
01-08-2013 10:20 AM
Hi Jacob,
1> Take a backup of the config: Do a "write mem" --> "copy start flash".
2> Remove the flash card from the old VG224 and insert it into the new VG224.
3> Assuming the IOS is the 1st file in the flash, power on the new VG224 and it should pick up the IOS from the flash.
4> Once the VG224 is up, do a "copy flash start". Specify the filename of the saved config and it should copy it into the startup config.
5> Reload the VG224 and it should boot up with the config.
HTH.
Harmit.
01-08-2013 10:15 AM
HTH,
Chris
01-08-2013 10:34 AM
is it enough to just change the MAC and Description
or do i need to add a new device?
01-08-2013 10:20 AM
Hi Jacob,
HTH.
Harmit.
