10-26-2011 05:54 AM - edited 03-16-2019 07:42 AM
I'm performing a migration from 5.1 to 8.6. Our customer has several MGCP gateways connected against the CCM. IOS from gateways are 12.4.
My question is, could we have problems between MGCP gateways and CCM 8.6 due an incompatibility between IOS version and CCM?
10-26-2011 01:51 PM
hi my friend,
yes sure, yo need to check compatibility between the ios and the CUCM:
Best Regards,
Odai Jeriss
10-27-2011 01:04 AM
Thank you Odai.
I know that Cisco recomends IOS 15.1 for CCM 8.6. But I want to know if somebody has tested 12.4 with MGCP.
10-27-2011 03:31 AM
Best way is to test it and confirm if it dose the job or not
10-27-2011 03:40 AM
Yes of course, it's the best way.
But I cannot test it until the migration, so I don't know if I need to perform a rollback.
10-27-2011 04:07 AM
Use a ccm in a vmware and test it after hours with gateway
10-27-2011 06:45 AM
I'm all for testing in advance, where possible. However, see here for some further info as well: https://supportforums.cisco.com/message/3473488#3473488
It touches on a few items but has some gateway/IOS informational points as well.
Note the link provided above is a release summary and not a complete compatibility summary. That link is a baseline of the components used in verification of each release train.
Hailey
Please rate helpful posts!
10-27-2011 01:58 PM
Dumb question... Can't you just upgrade your gateway?
Save yourself the hassle of wondering what may break.
Ven
10-28-2011 01:44 AM
Of course, it would be the best option. But, do I need to purchase licenses to this?
10-28-2011 05:36 AM
Antonio
The fact that you are talking about upgrades from 12.4 to 15 infers that you must be using ISR-G1s (eg 28xx , 38xx)
type of routers.
To the best of my knowledge you do not need licenses, you just download the IOS files and upgrade as normal.
All of course if you have a CCO account with the correct privilages and entirlements.
The licensing issues come in to play for the ISR-G2s (29xx, 39xx)
Alex
10-31-2011 04:00 PM
i have 100 mgcp 2821 gateways connecting to call manager currently 7.1.3, we are in the process of upgrading to 8.6 but our routers have only 256mb of memory and are unable to upgrade to ver15 ios, what other choices do i have. i have already purchased ucs210m2 for the upgrade.
please advise
Con
10-31-2011 05:19 PM
Con,
You could try the latest 12.4T release this assuming you 64MB of flash & 256MB of DRAM
SP SERVICES | |
c2800nm-spservicesk9-mz.124-24.T6.bin | |
Release Date: 31/AUG/2011 | |
Size: 49665.07 KB (50857024 bytes) | |
Minimum Memory: DRAM:256MB Flash:64MB |
Alex
10-31-2011 08:20 PM
Hi my sites are running 2821 advanced ip services ver12.4T4 and im testing the T6 version
Will i still have compatability with T4 ios ???
11-01-2011 03:18 AM
If you are running 12.4.24T4 this IOS has been deferred by Cisco -- Many software bugs
T6 is the latest replacement.
Alex
Please rate useful posts.
11-11-2011 06:17 AM
hi all,
i have upgrade to cucm 8.5.1 su3 and running ios 12.4.t6 on 2821 router and now have fxs port issues,
the fax machine can receive faxes fine but when it tries to send their isnt even a dial tone and they are getting engaged tone.
any ideas in what has changed to cause this???
please advise
thanks in advance
Con
