MGCP Issues Secure call-FAX-MODEM-FireAlarms
heathmiller75
Hello all,
I need some major support. I have a ticket open already but CISCO tech support has not made any contact. I took over this network to get it running for the military standards to allow secure calls. It was in really bad shape before I got here. I reconfigured the system to run MGCP as this is required to be able to function for secure calls via either STE's aor Vipers by GD. The problem I have is now is FAX's, Modems do not work not even sure my firealarms are really reporting correctly and rekeying of secure terminal is really flaky and secure calls do not last very long. I have read tons of documentation such as the v.150 MER essential requirement as well as my military deployment guide. My equipment meets all the specs. Below is the configuration currently and im game for changes im aslo assuming I have CUCM setup correctly as well.. I need help and advice please.
Telco-PRI-GW(ISR-4351)-MGCP-CUCM-SCCP-VG350-FAX/MODEM/FireAlarms/Secure STE phones
Telco-PRI-GW(ISR-4351)-MGCP-CUCM-SIP-VIPER
=====ISR-4351========
voice service voip
no ip address trusted authenticate
media bulk-stats
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 3 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
modem passthrough nse codec g711ulaw
modem relay sse redundancy interval 16
sip
call service stop
mgcp
mgcp call-agent ***.***.***.*** 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode nte-gw
mgcp rtp unreachable timeout 1000 action notify
mgcp modem relay voip mode sse redundancy packet 5
mgcp modem relay voip sprt retries 10
mgcp modem relay voip sprt v14 receive playback hold-time 20
mgcp modem relay voip sprt v14 transmit hold-time 12
mgcp modem relay voip sprt v14 transmit maximum hold-count 22
mgcp codec clear-channel packetization-period 20
mgcp ip qos dscp cs6 signaling
mgcp playout adaptive 15 15 30
mgcp package-capability mf-package
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp package-capability mdste-package
mgcp package-capability fm-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp validate call-agent source-ipaddr
mgcp fax t38 inhibit
no mgcp fax-relay sg3-to-g3
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0/0.252
mgcp bind media source-interface GigabitEthernet0/0/0.252
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp rtp payload-type nte 101
mgcp profile default
sccp local GigabitEthernet0/0/0.252
sccp ccm ***.***.***.*** identifier 1 version 7.0
sccp ccm ***.***.***.*** identifier 2 version 7.0
sccp ccm ***.***.***.*** identifier 3 version 7.0
sccp
ccm-manager fallback-mgcp
ccm-manager redundant-host ***.***.***.*** ***.***.***.***
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager config server ***.***.***.*** ***.***.***.***
ccm-manager config
======VG-350=========
voice service voip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
modem relay latency 250
modem relay sse redundancy packet 2
modem relay sse t1 2100
modem relay sse retries 5
modem relay sprt retries 10
modem relay sprt v14 receive playback hold-time 32
modem relay sprt v14 transmit hold-time 12
modem relay sprt v14 transmit maximum hold-count 22
sip
call service stop
voice-port #/0/#
timeouts initial 60
timeouts interdigit 60
timeouts ringing infinity
dial-peer voice ####### pots
service stcapp
port #/0/##
heathmiller75
****Update FAX now operational*** All others non operational. My contacts who dial in to my modem recieve Error678 on microsoft dialing service which means the device is basically not answering the call. But the device does recieves calls if you dial it and get tone burst. So Im thinking it has to do with my gloabl MGCP configuration. We have test this conenction through our regular analog switchboard and the modem works just fine. I just removed T38 fax protocal from both the isr4351 and vg350 in the voice service voip
router# voice service voip
 fax protocol pass-through g711ulaw
voice service voip
media bulk-stats
removed >>>>>fax protocol t38 version 3 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
replaced>>>>>fax protocol pass-through g711ulaw
sip
call service stop
mgcp
mgcp sdp simple
sccp
ccm-manager mgcp
ccm-manager config
voice service voip
replaced>>>>>fax protocol pass-through g711ulawmodem relay latency 250
sip
call service stop
voice-port #/0/#
timeouts initial 60
service stcapp
port #/0/##
