MGCP on 3640 router
pminguy
I want to configure a 3640 router to act as FXS ans PRI gateway. I had found how to configure ccm 4.2 but what configuration i have to put in the router ???
there is plenty of documentation on the matter if you take 5 minutes and search CCO
How to Configure MGCP with Digital PRI and Cisco CallManager
http://www.cisco.com/en/US/partner/tech/tk1077/technologies_configuration_example09186a00801ad22f.shtml
Configuring the Cisco IOS MGCP Gateway
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_tech_note09186a008017787b.shtml
Configure MGCP Gateway and FXO/FXS Ports on a Cisco CallManager Server
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_tech_note09186a008017825e.shtml
java
if this helps, please rate
java
thanks but the links are forbidden i can't reach them
use your CCO to log in or remove partner/ from url and try again
java
