MGCP updates
Forcefield
Hi all
I need to change IP addresses for my routers for MGCP and currently I have changed the confgiurations of one of my sites.
The new configs show the updated new IP addresses but when I run show ccm-manager command I get the old IP address still registered against my primary server.
Do I need to reboot the router to get this changed or should resetting MGCP simply update the settings?
thank you in advance
FF
Jaime Valencia
Also make sure your config server is properly configured, if you have it
ccm-manager config server
And you should be able to just do a no mgcp / mgcp to get this going.
java
if this helps, please rate
Jitender Bhandari
check for below command
mgcp call-agent XXX.XX.XX.XX 2427 service-type mgcp version 0.1
reference link below
http://www.cisco.com/c/en/us/support/docs/voice/media-gateway-control-protocol-mgcp/23966-mgcp-pri-cm.html
JB
Jaime Valencia
java
