Microsoft LDAP and CUCM Sync Issue !
souamzouhair
HI,
I have done the integration between CUCM and MS LDAP, but i can’t retrieve users created in LDAP on CUCM (when i perform a manual sync) ?
Can you help me !!
Thanks in Advance.
Jaime Valencia
Are you sure all the LDAP info you used in CUCM is correct???
User has right permissions???
End users have SN populated???
Try looking at the LDAP logs to find out the root cause.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
Has anyone changed the password on the account you're using to pull LDAP?
souamzouhair
All LDAP info are correctly added on CUCM using the administror credential and the LDAP directory service was successfuly added.
Does the CUCM must be synchronised with LDAP ?
i used 'utils ntp status' ---> unsynchronised.
Thanks in advance !
