Migrating directory from CUCM to LDAP-sync
Hello
I've got a customer infrastructure based on CUCM 8.6 hosted on BE6000.
There are willing to deploy CUPS and Jabber on PC.
It looks pretty much easier to consider an AD integration rahter than using UDS on CUCM.
Could you please give me some advices / considerations to bear in mind while migrating the user's directory (manually created on CUCM) towards an AD sync ?
They have also Unity Connection 8.6 deployed. So same question applies for this as well...
Many thanks in advance !
As long as the userIDs from what you have on CUCM/CUC match the one in LDAP, you'll be fine, otherwise, any user who doesn't match, will be marked as inactive, and then deleted.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
betha yamini
Hi slaurenti,
Hope  below link would help u migrating to ldap
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/directry.html
Thans for your reply Betha,
Unfortunatelly it does not give information on the migrate path.. that's my major concern actually...
java
java
