I can make a call phone but extension doesn't receive the call
andresilva
Hi everyone,
I have a UC540 and two lines connected
When I make a call phone to one line, everything it is ok. However when I make a call for other line I can hear the call signal, but the extension doesn´t ring and doesn't receive any notification of the call. I tried change the extension but the problem keeps.
When I do a test with CCA "Dial Plan Test" the result of test is correct.
Anybody can help me?
paolo bevilacqua
Possibly the line is not connected properly, or not woring.
paolo bevilacqua
Sory I put this ansmwer as correct, but I don't know if it is correct.
I think that line is not connected properly I may not to hear signal of call correct.
Yes you would. Just like if you disconnect an home phone and someone calls, they will hear ringback and no answer.
