11-04-2013 09:41 PM - edited 03-16-2019 08:14 PM
I plan to execute an upgrade of CUCM and CUCX from version 7.1.3.30000-1 to a version 9.1.1.20000-5 (CUCM) as well CUCX 7.0(1)SR05_Build504 to 9.0.2.10000-71(CUCX) respectively on a VMware ESXI 5.0 . I will be grateful if someone finds a little time to help me to make the upgrade plan
Cisco unified contact center express
Current version :Cisco application administration-7.0(1)SR05_Build504
pakage cisco unified ccx premium
cluster default
New version: Cisco Unified CCX Administration
System version : 9.0.2.10000-71
Cisco Unified Call Manager
Current version :sysystem version 7.1.3.30000-1
New version:system version 9.1.1.20000-5
Please check the snapshot of the current versions
Akhilesh Nambiyath
11-04-2013 10:20 PM
Start by reviewing the CUCM and UCCX, HW and SW compatibility guides.
Then read the RNs for both products, along with the upgrade guides, all such info is available on cisco.com.
Thats your first step in choosing an upgrade plan.
At some point once you're on versions which are supported on ESXi, you'll DRS from MCS into UCS
11-05-2013 07:30 AM
Since you're a partner you should be able to go here, then it's time to do some reading
https://communities.cisco.com/community/partner/collaboration/migration?view=overview
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
