Migration of CUCM on UCS C series to UCS B series.
dlockwald1
Planning a move from UCS rack servers to newer blades. I was wondering what the Cisco recommended method would be. I see allot of people saying that you should vMotion things over but also that there are allot of caveats with it. I have also heard some people recommend Cisco Prime Collaboration Deployment but I can't quite figure out how that would work. So I thought I would ask the community for it's opinion on the subject.
CUCM is on version 10.5, nothing will be patched or upgraded in the move just the guest OS will be moved over. Also, these platforms do not share storage, the C series have the guest stored local and the B series will have a SAN.
http://docwiki.cisco.com/wiki/Unified_Communications_VMware_Requirements#VMware_vMotion
java
if this helps, please rate
Jaime Valencia
PCD has nothing to do with what you're trying to do
You would need to perform a cold migration in your environment.
java
Cold? I could even vMotion?
java
Yup, there it is in black and white, thanks. By chance you wouldn't have a link to the proper method for moving a cluster do you? I know you move the pub first then the subs but I can't find a page that details the process.
