I was asked to run a report for Missed Calls for a certain extension. The only way I could figure out how to do this is run a report on all incoming calls and filter them for calls that are zero seconds in length. Does anyone know of a better way or a best practices way to run a Missed Calls report for an extension? -Beth
Thank you Jaime, for the feedback. I appreciate it very much since my customer thinks there should be more missed calls than the report reflected. I wanted to make sure I was using an accurate method of identifying those missed calls.
I just finished to write a comprehensive certificates preparation for Cisco Meeting Server Clustering. Through 60 pages I explained in detail, how to create certificates for database cluster, callbridge cluster, certificate chain for webbridge3, certifica...
view more
Translation Pattern is the most important tool in the Call Routing Process for Cisco Unified Communication manager. Largely used in the Globalized Dial Plan, inter-site and intra-site dialing, and a powerful tool to solve the problem of overlapping direct...
view more
Customer relationship management (CRM) tools are essential for managing relationships, collaborating with your team, and closing deals. The most forward-thinking CRM companies now integrate artificial intelligence (AI) into their software. The combination...
view more
Setting up a scenario to explain the Translation Pattern with the "Route Next Hop By Calling Party Number" option to route a call based on the calling number.In this scenario, the Executive Director instructs the admin to block calls coming from internati...
view more
