missing command - session server-group IOS XE 17.09
Paul Austin
Level 4
Level 4
Hi All, Has the command "session server-group XX" been superseded by something else? The only options I get from the dial-peer are protocol, target or transport. Cannot find anything.
This is an ISR 4321
Paul
You’re missing this command on that dial peer.
session protocol sipv2
Response Signature
7 Replies 7
No it has not been replaced by something else. Have you enabled licensing for voice services?
Response Signature
Yes, It is currently running as a CUBE and registered with the smart account. All other commands are there.
Can you please share the running configuration of the router?
Response Signature
see attached. I cannot define session server-group 301 in dial-peer voice 301 voip
Response Signature
aaaaggggggg can't believe I missed that - thanks
Apart from that you don’t seem to use the version of IOS that you wrote in your initial post. Not according to the shared configuration at least.
Response Signature
