Missing dsp services dspfarm command in 12.3(26)
russell.sage
Level 3
Level 3
hello
I have a Cisco 2620 router with a nm-hdv module fitted with vic-2mft-e1 card and 3 pvdm12 modules. Which I use for training and testing. I am trying to configure hardware transcoding and conference bridging.
I have a feature set that supports H.323 as I have the device configured as an H.323 gateway and this works with Call Manager 4.2(3) fine.
Trawling google, cco and this forum I need to enable dspfarm but prior to this on an NM-HDV module you have to issue the dsp services dspfarm card under the voice-card.
This command doesn't exists under my voice card
p1r3(config-voicecard)#?
Voice-card configuration commands:
  codec    Manage codec configuration parameters for voice card
  default  Set a command to its defaults
  exit     Exit from voice card configuration mode
  no       Negate a command or set its defaults
I have checked the command reference and the command was introduced in 12.2 so I am struggling to understand why this command is missing.
I have included the output from the show diag command
Slot 1:
        High Density Voice Port adapter
        Port adapter is analyzed
        Port adapter insertion time unknown
        EEPROM contents at hardware discovery:
        Hardware Revision        : 1.1
        Top Assy. Part Number    : 800-03567-01
        Board Revision           : F1
        Deviation Number         : 0-0
        Fab Version              : 02
        PCB Serial Number        : JAB04520CYT
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Product (FRU) Number     : NM-HDV=
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF 40 00 CC 41 01 01 C0 46 03 20 00 0D EF 01
          0x10: 42 46 31 80 00 00 00 00 02 02 C1 8B 4A 41 42 30
          0x20: 34 35 32 30 43 59 54 03 00 81 00 00 00 00 04 00
          0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        HDV SIMMs: Product (FRU) Number: PVDM-12
         SIMM slot 0: Empty.
         SIMM slot 1: Empty.
         SIMM slot 2: PVDM-12 SIMM present.
         SIMM slot 3: PVDM-12 SIMM present.
         SIMM slot 4: PVDM-12 SIMM present.
        VIC Slot 0:
        E1 (2 Port) Multi-Flex Trunk WAN Daughter Card
        Hardware revision 1.0           Board revision D0
        Serial number     33106754      Part number    800-04479-03
        Test history      0x0           RMA number     00-00-00
                                Connector type    PCI
        EEPROM format version 1
          0x20: 01 23 01 00 01 F9 2B 42 50 11 7F 03 00 00 00 00
          0x30: 68 00 00 00 05 02 12 00 FF FF FF FF FF FF FF FF
        HDV firmware: Compiled Fri 19-Nov-04 14:23 by michen
        HDV memory size 524280 heap free 167869
As always any help greatly appreciated.
vasank
Hey,
"show voice dsp"  to check the status of the dsp channels.
Give this a try too:
give "sccp" command in global config mode
no dspfarm in global config mode
enable "debug dspfarm all"
in global config mode : "dspfarm"
then try configuring again
Thank you for your prompt response. None of the commands are available. However I have now discovered that the conferencing and transcoding is only available in the IP Plus Feature which will require a memory upgrade on my router to support.
Once again thank you
good to hear russell that u were able to figure out what was casuing the issue. btw could you post the output of show version to know which version ur using and your memory .. it would be informational..thnks
