So we have a cluster of 6 servers, all in mix mode. One of the servers went into read only mode and we had to re-install the server.
What is the best procedure in this case to re install the subscriber considering that this server was in mix mode ?
Right now, we re-installed the server with same IP, hostname, etc everything the same; To my surprise the server pulled the Database without a problem from publisher and it was showing a status of 2. The services were all turned off by default, but I didnt dare to turn on the Seurity services on this new (re-installed) server (CTL). What should I do? Do I need to use the wizard with the usb tokens to re-add the subscriber or just turn on the security service on this subscriber? Waht is the best procedure?
Right now the server has the Call Manager Service up and TFTP, some phones are registered without problems but we are still missing the CTL security service.
