Mobile Connect and Access Lists
paul_romsos
Good Afternoon.
When setting up a user for Mobile Connect, Using CM6.1, do you need to apply and access list to the Remote Destination? Or can you just leave the Allow and Deny access lists to <none>? We'd like all calls to our sales people to ring to all their remote destinations. If possible I'd like to avoid having to create an access list for each user to allow everything.
Any help or advice is appreciated.
Paul
jrockhill
I have the same question, seems like you should be able to.
No need to set an access list. Just an available feature.
Jon
