04-19-2011 06:24 AM - edited 03-16-2019 04:35 AM
I have a CUCM 7.1.5 running in my office..
I have configured Mobile Voice Access and it works fine.
The issue is that I want to listen to the message in Greek...
I have the GR Locale installed, I reboot but it doesn't work.
In the mobile voice access configuration I put the Greek Locale ONLY but nothing changed..
I still hear the message in English and not in Greek
Any ideas?
Thanks in advance!!
Solved! Go to Solution.
04-19-2011 10:44 AM
Can you try the following ?
- Restart the Mobile Voice Access service on the Pub, from the serviceability page
- Remove the MVA service from the dialpeer on the H.323 gateway, and add it back in
Example :
application
no service ccm
service ccm http://x.x.x.x:8080/ccmivr/pages/IVRMainpage.vxml
Test again and check.
If you still hear English, send me the screenshot of the MVA config page, and the Mobile Voice Access Service logs set to Debug.
- Sriram
Please rate helpful posts !
04-19-2011 10:44 AM
Example :
application
no service ccm
- Sriram
10-23-2012 11:37 PM
Thanks.
This did work for me as well !!
04-21-2011 02:16 AM
It works!!!
Thanks!!
04-21-2011 12:37 PM
Glad to know it helped !
- Sriram
