Mobile voice access not reponding
Luis Rodriguez
I have setup MVA correctly on one site, after a few months, the call just comes into the voice gateway and then it drops, I have already setup the following:
1- Media Resources --> Mobile voice access number
2- Service parameters --> Mobile voice access number and mobile voice access is enabled
3- The partition that the number has is the correct one
4- On the voice gateway I have the following config:
dial-peer voice XXXX voip
destination-pattern 2938
session target ipv4:CUCM pub IP
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice XXXX pots
service ccm
incoming called-number 2938
no digit-strip
direct-inward-dial
service CCM http://<CUCM pub IP>:8080/ccmivr/pages/IVRMainpage.vxml
I have opened a TAC case but they are not sure where the problem is and the h323 config is fine because the rest of the calls are working correctly.
7 Replies 7
islam.kamal
Level 10
Level 10
1- Did you check the registeration for your application , by do: show  call application voice ccm.
2- When you do a call did you hear the welcome message?. when the call drop?.Make sure that your mobile voice access is enbaled on service parameters
3- for the voip dial-peer if your internale dial-plans starts with 2XXX , so you do not need this specified  voip dial-peer for MVA?.Because for sure you have already have other VOIP dial-peer for your internal ext 2XXX.
Thank you
please rate all useful information
Hi Islam,
See the answer to your questions bellow:
1- Did you check the registeration for your application , by do: show voice call application ccm.
Script Name : CCM
       URL  : http://:8080/ccmivr/pages/IVRMainpage.vxml
       Type : Service
       State: Registered
       Life : Configured
       Exec Instances: 0
Script Code Begin:
VXML Application CCM
    URL=http://10.1.6.10:8080/ccmivr/pages/IVRMainpage.vxml
    Security Level: not trusted
            47 incoming calls
            0 calls handed off to it
            0 call transfers initiated
            0 pages loaded,  75 successful
            47 prompt play attempts, 0 successful
            0 recorded messages
The VXML Script is:
           http://::8080/ccmivr/IVRCalleridLookup.do" method="get" namelist="remotedest srcdir"/>
           http://::8080/ccmivr/IVRCalleridLookup2.do" method="get" namelist="dest srcdir accessCount"/>
I don`t hear the welcome message the call stays active and silent for about 2 seconds and then it just drops
3- for the voip dial-peer if your internale dial-plans starts with 2XXX , so you do not need this specified voip dial-peer for MVA?. correct I just setup this dial peer to make sure I have the specific number on a dial peer
1- Please make sure that under the service parameters mobile voice access is enable.
2- Please do debug isdn q931.
Thank you
Please also type the below command
interface
h323-gateway voip interface
h323-gateway voip bind srcaddr xxx.xxx.xxx.xxx (Interface's ip address).
voice service voip
* please also check if your make complete match & partial match try to change it. If you using complete ,try to use partial and if you use partial try to use complete
Thank you
All this config was already on the router except for the complete match, I changed it to partial match but I still have the same problem. Here`s the debug isdn q931:
082025: Oct 10 19:45:06.309: ISDN Se0/1/1:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 22042153
082026: Oct 10 19:45:06.309: ISDN Se0/1/1:15 Q931: Sending SETUP  callref = 0x5EF0 callID = 0xDE71 switch = primary-net5 interface = User
082027: Oct 10 19:45:06.309: ISDN Se0/1/1:15 Q931: TX -> SETUP pd = 8  callref = 0x5EF0
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839E
                Exclusive, Channel 30
        Progress Ind i = 0x8183 - Origination address is non-ISDN
LACRSJRO06#
        Calling Party Number i = 0x0081, '22042153'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '22042938'
082028: Oct 10 19:45:06.533: ISDN Se0/1/1:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0xDEF0
082029: Oct 10 19:45:06.665: ISDN Se0/1/1:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xDEF0
082030: Oct 10 19:45:06.869: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0300
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA98389
                Exclusive, Channel 9
        Progress Ind i = 0x8583 - Origination address is non-ISDN
        Calling Party Number i = 0x2081, '22042153'
                Plan:Unknown, Type:National
        Called Party Number i = 0x81, '2938'
                Plan:ISDN, Type:Unknown
082031: Oct 10 19:45:06.869: ISDN Se0/1/0:15 Q931: Received SETUP  callref = 0x8300 callID = 0x4756 switch = primary-net5 interface = User
082032: Oct 10 19:45:06.881: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8300
082033: Oct 10 19:45:06.881: ISDN Se0/1/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x8300
082034: Oct 10 19:45:07.241: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x8300
        Cause i = 0x8090 - Normal call clearing
082035: Oct 10 19:45:07.313: ISDN Se0/1/1:15 Q931: RX <- CONNECT pd = 8  callref = 0xDEF0
        Date/Time i = 0x0D0A0A0D2D00
                Date (dd-mm-yr)   = 13-10-10
                Time (hr:mnt:sec) = 13:45:00
082036: Oct 10 19:45:07.313: %ISDN-6-CONNECT: Interface Serial0/1/1:29 is now connected to 3212075 N/A
LACRSJRO06#
082037: Oct 10 19:45:07.313: ISDN Se0/1/1:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x5EF0
082038: Oct 10 19:45:07.749: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x0300
082039: Oct 10 19:45:07.749: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8300
082040: Oct 10 19:45:07.853: ISDN Se0/1/1:15 Q931: RX <- DISCONNECT pd = 8  callref = 0xDEF0
        Progress Ind i = 0x8288 - In-band info or appropriate now available
082041: Oct 10 19:45:07.853: ISDN Se0/1/1:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0xDE71
LACRSJRO06#
082042: Oct 10 19:45:08.073: ISDN Se0/1/1:15 Q931: TX -> RELEASE pd = 8  callref = 0x5EF0
082043: Oct 10 19:45:08.237: ISDN Se0/1/1:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xDEF0
Can you please share with me the "show call application voice summary" command ?. Maybe there are a problem on the VXML when your router is trying to open the VXML application.
Thank you
If it's possible then please share "debug voice ccapi inout" & "debug voice dialpeer" separately.
Also share your running config of VG.
Nishant Savalia
Regards, Nishant Savalia
