Mobile voice Access working but can't make outside calls
aysar3000
Dears
i configure mobile voice access and i can hear the IVR when i call from a PSTN Line and i input my Remote destination number then it ask me for my PIN and i put it then it ask to press one for a call and after that i dialed the number but it give busy tone
here is my configuration
my MVA number is 7999
my IOS COnfiguration
voice class codec 1
 codec preference 1 g711alaw
 codec preference 2 g711ulaw
 codec preference 3 g729r8
 codec preference 4 g729br8
voice translation-rule 3
 rule 1 /^9\(\)/ /\1/
voice translation-rule 4
 rule 4 /^22217/ /7/
 rule 5 /^2217/ /7/
 rule 6 /^022217/ /7/
 rule 7 /^0122217/ /7/
voice translation-rule 5
 rule 1 /^5/ /905/
 rule 2 /^1/ /901/
 rule 3 /^2/ /902/
 rule 4 /^3/ /903/
 rule 5 /^4/ /904/
 rule 6 /^6/ /906/
 rule 7 /^7/ /907/
 rule 8 /^8/ /908/
 rule 10 /^00/ /900/
 rule 11 /'+'/ /900/
voice translation-rule 9
 rule 1 /^5/ /05/
voice translation-profile MVA
 translate calling 9
voice translation-profile OUT
 translate called 3
voice translation-profile REDIAL
 translate calling 5
voice translation-profile SIP-NEW
 translate called 4
dial-peer voice 802 voip
 description ** SIP TO STC **
 translation-profile outgoing OUT
 destination-pattern 9T
 session protocol sipv2
 session target ipv4:10.208.9.69:5060
 session transport udp
 voice-class codec 1
 voice-class sip dtmf-relay force rtp-nte
 voice-class sip profiles 1
 dtmf-relay sip-notify rtp-nte sip-kpml
 fax rate disable
 no vad
 voice-class codec 1
 fax rate disable
 no vad
dial-peer voice 811 voip
 description ** SIP INCOMING FROM STC **
 translation-profile incoming SIP-NEW
 translation-profile outgoing REDIAL
 destination-pattern 7...
 session target ipv4:192.168.200.53
 incoming called-number 022217...$
 voice-class codec 1
 fax rate disable
 no vad
dial-peer voice 812 voip
 incoming called-number 22217...$
 codec g711alaw
dial-peer voice 7999 voip
Description "MVA"
 service mva
 incoming called-number 2217999
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 7991 voip
 destination-pattern 7999
 voice-class codec 1
 dtmf-relay rtp-nte
 fax rate disable
 no vad
in the service parameter
 False
 Complete Match
Thanks in Advanced
32 Replies 32
Hi.
Go to Call Routing --> Class of control --> Access list
Add new
-Add a Name
-Select the user associated too your RDP as Owner
- Select "Allowed"
- Click "Add member"
- As Filter mask  leave "Directory Number"
- As DN Mask put a  X!
Save and try again
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo
Still the same when i call from PSTN number i hear the whole authentication and press one to dial and then after i dialed i hear busy tone
but i find something that when i call from my remote destination which is my mobile number i cant hear anything no welcome message no authentication
Try to restart media streaming application service from cucm serviceability page and verify which locale is configured on RDP and which locale you added to Mobile Voice Access configuration.
Let us know
Carlo
Dears
i use same locale in both
Hi.
I don't know if you solved the problem but, in your sip trunk make sure you have "Redirecting Diversion Header Delivery Inbound" selected.
Carlo
I am too facing the same problem.
CUCM Version 10.5.2-10000-5 and SIP Gateway having normal E1 PRI termination.
MVA reaches to IVR and then when you try to reach a PSTN number it gives a fast busy tone and disconnects.
Thanks in advance.
Ashish Bagla
Check the Rerouting CSS
it should be able to reach the Partition of the PSTN Number you trying to call
it worked for me
Hi.
All leads to a call Routing/Permission issue.
To go in deep with this issue, we could setup a webex session.
Tell me if and when your are available and , if you agree, you can leave me your email address , even on a private message, where I can send you an invitation.
Let me know
Carlo
This would be very great out timming here is GMT +3
if it possible i can contact you in the next 2 days i will check which time i can go to the office coz it would be a holiday
and i wil contact you
my email is : infosec3000@gmail.com
Thanks in Advanced
Hi.
Ok let me know a possible date so I can organize my time ;)
Carlo
i change it to Remote Destination Profile + Line Calling Search Space"
still the same
Can you attach the CallManager traces for a test call?
You have to use H.323 gateway for MVA to work.  It doesn't work with SIP.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_0_1/ccmfeat/fsmobmgr.html#wp1125041
"Only H.323 VoIP gateways are supported for Mobile Voice Access."
Edit: Nevermind, it supports SIP in newer versions now:
"Both H.323 and SIP VoIP gateways are supported for Mobile Voice Access." from http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/10_0_1/ccmfeat/CUCM_BK_F3AC1C0F_00_cucm-features-services-guide-100_chapter_0110111.html#CUCM_TP_I193BE2E_00
Hi.
MVA works either with sip or H323 in the same way.
I have sip only VG at many customer's sites even in my head office.
did you add  "Media Resource" -->> Mobile Voice Access DN and secified language?.
In your sip trunk, did you configure redirect CSS?
Reset both Mobile Voce access and Media Streamin Application service
Carlo
Dears
yes i define the DN and the language
and i reset both link and configure the rerouting and still not working
