mobility manager
mymite060708
Does anyone have a user / install guide for mobility manager and connect for callmanager 6
5 Replies 5
I need steps for mobility connect feature on CM6, I have followed the standard guide but keep getting the error
Not a valid mobile phone user
When I select the mobility softkey?????
you probably forget to configure the "Owner User ID" field in the device phone configuration. Try to add a user in that field and the issue should be solved.
Dom.
mserwon
That was exactly my issue also
The problem is due to known defect :
CSCsg64857    You are not a valid Mobile Phone user Displayed with Mobility softkey
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsg64857
- Sriram
