Modify a sip invite
Amit Shah
We have a sip invite coming from Lync with the first name and the last name. The call is being denied by the ITSP because they need a DID in the from field.
From: <sip:glenn.orcutt@1.1.1.1>;tag=1207269~b2e7ab81-19a9-49f9-adaf-eb693f51e143-47259121
what i would like to do is replace "glenn.orcutt" with "1111111111". I cannot use a blanket replace all header. I was trying to find out if there is a way to match the character "." (dot) in the sip profile
Hi Amit.
Where do you need to modify the invite message?
On a Cube or CUCM?
Please let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
On the CUBE, sorry forgot to mention that.
Hi Amit
Create voice class sip profile such as
voice class sip-profiles 100
 request INVITE sip-header From modify "\"(.*)\" <sip:(.*)@(.*)>" "\"\" <sip:1111111111@1.1.1.1>"
add that profile to outgoing dialpeer to lync
dial-peer voice 10 voip
voice-class sip profiles 100
Carlo
I was able to use this script and make it work
request INVITE sip-header From modify "<sip:[a-z]+\.[a-z]+@" "<sip:1111111111@"
tested it at
http://sip-profile.54.227.241.219.xip.io/
