Modify SIP-Header P-Asserted-Identity
In my environment, I am doing validation for outgoing calls based on the caller ID in my system. Basically we authorize outgoing calls only if the caller ID belong to my network. This validation is done checking the value on the P-Asserted-Identity field.
I want to know if I can manipulate the P-Asserted-Identity field with a specific caller ID or a specific number. In other words I want to just force a specific number in the P-Asserted-Identity filed for all my outgoing calls.
Is there a way to get this done?
I will appreciate your reply
Daniel
0 Replies 0
