SIP from Telco to Internal PRI to PBX configuration example
dan hale
Level 3
Level 3
Hi All,
I will be taking in a SIP trunk from my Telephone company and converting it to our internal shortel PBX via PRI. I'm trying to go thru the configuration of what this will look like on my Cisco 4331 ISR gateway. Both the SIP and PRI will terminate on this ISR.
voice service voip
allow connections sip to sip
allow connections sip to H323
sip
voice translation-rule 1
rule 1 /^91/ /+1/
voice translation-profile Outbound
translate called 1
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
sip-ua
dial-peer voice 100 voip
description calls to Sip_Provider
destination-pattern 91[2-9]..[2-9]......
session protocol sipv2
session target (SIP Provider IP Address)
dtmf-relay rtp-nte sip-kpml sip-notify
voice-class codec 1
no vad
dial-peer voice 200 pots
description **Dial-Peer to match Incoming calls from SIP TRUNK to PRI**
incoming called number .
direct-inward-dial
port 0/1/1:23
interface Serial0/1/1:23
no ip address
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
no shutdown
card type t1 0 1
isdn switch-type primary-ni
voice-port 0/1/0:23
controller T1 0/1/0
threshold sd-ber 6
threshold sf-ber 3
framing esf
clock source line primary
linecode b8zs
cablelength long 0db
description PRI to Shoretel_PBX
Dan
0 Replies 0
