06-17-2016 12:01 AM - edited 03-17-2019 07:16 AM
I just have a problem to modify the "P-Asserted-Identity" as the provider expect a special value.
The "normal" unmodified P-Asserted-Identity looks like this
P-Asserted-Identity: "username" <sip:XXXX77@x.x.x.x>
I want to change this P-Asserted-Identity to this one
P-Asserted-Identity: "username"<sip:YYYYYYYY77@y.y.y.y:5060>
X = internal DN
x = internal IP of CUCM
Y = external DN
y = external IP
I tried to do this with this config
voice class sip-profiles 1
request ANY sip-header P-Asserted-Identity modify "P-Asserted-Identity:(.*)<sip:XXXX77@x.x.x.x>" "P-Asserted-Identity:\1<sip:YYYYYYYY77@y.y.y.y:5060>"
dial-peer voice 11 voip
description SIP-Outgoing
translation-profile incoming SipInbound
translation-profile outgoing SipOutbound
destination-pattern 0T
modem passthrough nse codec g711alaw
session protocol sipv2
session target ipv4:y.y.y.y
session transport udp
voice-class sip early-offer forced
voice-class sip profiles 1
dtmf-relay sip-notify rtp-nte
codec g711alaw
fax-relay ecm disable
fax-relay sg3-to-g3
fax nsf 000000
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
no vad
In the log I also see that dialpeer 11 should be used:
*Jun 16 15:16:31.242 MESZ: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=11 Is Matched
But the problem is that the P-Asserted-Identity is not modified and still the default value.
What did I wrong?
BR
Michael
Solved! Go to Solution.
06-20-2016 07:16 AM
you can try this to replace tel with sip, and you'd need to have previous command applied:
request ANY sip-header P-Asserted-Identity modify "P-Asserted-Identity:(.*)<(tel):(.*)>" "P-Asserted-Identity:\1<sip:\3:5060>"
Leszek
06-20-2016 10:39 AM
Hi Leszek,
I added your rule.
Call is now going out with the still added command "voice-class sip asserted-id pai" although the P-Asserted-Identity is still not totally correct.
At the moment the sip-profile looks like this:
request ANY sip-header P-Asserted-Identity modify "P-Asserted-Identity:(.*)<sip:784577@10.40.40.41>" "P-Asserted-Identity:\1<sip:0305878477@10.21.147.154:5060>"
response ANY sip-header P-Asserted-Identity modify "P-Asserted-Identity:(.*)<sip:784577@10.40.40.41>" "P-Asserted-Identity:\1<sip:0305878477@10.21.147.154:5060>"
request ANY sip-header P-Asserted-Identity modify "P-Asserted-Identity:(.*)<(tel):(.*)>" "P-Asserted-Identity:\1<sip:\3>"
The receivced P-Asserted-Identy is:
P-Asserted-Identity: "username" <sip:784577@10.40.40.41>
The sent P-Asserted-Identy is:
P-Asserted-Identity: "username" <sip:0305878477@10.35.6.9>
The problem is that there is the wrong IP 10.35.6.9 (internal DMZ IP and not the external IP as written in the SIP-profile) 10.21.147.154.
Also the :5060 after the correct external IP is missing.
I just removed the sip-profile from the outgoing dial-peer and the P-Asserted-Identity is still the same for received and sent.
What can I do to change the P-Asserted-Identy to
BR
Michael
06-21-2016 12:08 AM
Hi Michael,
This should do it:
request ANY sip-header P-Asserted-Identity modify "P-Asserted-Identity:(.*)<(tel):(.*)@(.*)>" "P-Asserted-Identity:\1<sip:\3@10.21.147.154:5060>"
Leszek
06-21-2016 03:01 AM
Hi Leszek,
sorry but the P-Asserted-Identy still is wrong although I added your rule.
response ANY sip-header P-Asserted-Identity modify "P-Asserted-Identity:(.*)<(tel):(.*)@(.*)>" "P-Asserted-Identity:\1<sip:\3@10.21.147.154:5060>"
session target ipv4:10.15.165.102
codec g711alaw
fax-relay sg3-to-g3
fax nsf 000000
no vad
Sent:
In the attachment please find the outgoing log file.
BR
Michael
06-21-2016 03:08 AM
because the debugs are not full, that's why it's a little tricky to troubleshoot the script
can you add this one line to script:
request ANY sip-header P-Asserted-Identity modify "P-Asserted-Identity:(.*)<(sip):(.*)@(.*)>" "P-Asserted-Identity:\1<sip:\3@10.21.147.154:5060>"
This way it will match both tel and sip
Leszek
06-21-2016 03:32 AM
Hi Leszek,
great it`s working :-)
I added your rule. The sip profile looks now like that:
response ANY sip-header P-Asserted-Identity modify "P-Asserted-Identity:(.*)<(sip):(.*)@(.*)>" "P-Asserted-Identity:\1<sip:\3@10.21.147.154:5060>"
Sent:
P-Asserted-Identity: "CANCOM" <sip:0207412577@10.21.147.154:5060>
BR
Michael
06-21-2016 03:59 AM
ok, great
If the answers were useful please mark them as correct so we can consider this subject closed.
Leszek
06-23-2024 11:39 PM
Dear Leszek,
how can i write sip profile for below details.
DID Range 8914560050 to 8914560079
Intercom numbers 141 to 190 (Cisco IP Phones Model :7841)
SBC IP: 10.5.109.147
Domain ap.ims.airtel.in
Username +918914560050@ap.ims.airtel.in
At present i wrote profile for particular numbers. i.e
request INVITE sip-header P-Asserted-Identity modify "187@ap.ims.airtel.in" "+918914560050@ap.ims.airtel.in"
request INVITE sip-header From modify "187@ap.ims.airtel.in" "+918914560050@ap.ims.airtel.in"
request INVITE sip-header P-Asserted-Identity modify "190@ap.ims.airtel.in" "+918914560050@ap.ims.airtel.in"
request INVITE sip-header From modify "190@ap.ims.airtel.in" "+918914560050@ap.ims.airtel.in"
Now i can able to outgoing calls from those extension numbers only.
