Modify SIP Profil "P-Asserted-Identity"; Privacy:id
Hi all
I want to modify the SIP request, sent to the SIP Provider...
I like to modify the "P-Asserted-Identity" as well as I like to modify the Privacy status from "none" to "full".
Here is was our CUBE receives:
Received:
INVITE sip:*69100XXXXXXXXXXX@192.168.116.101:5060 SIP/2.0
Via: SIP/2.0/TCP 10.250.1.122:5060;branch=z9hG4bK85aa5b1cdc5498
From: "firstname surname" <sip:+XXXXXXXXXXX@10.250.1.122>;tag=37908225~5452b1e5-3a51-fcc6-cf3e-3d9a867d82eb-91500171
To: <sip:*69100XXXXXXXXXXX@192.168.116.101>
Date: Mon, 20 Jun 2016 07:46:41 GMT
Call-ID: 1f13cc00-76719f61-6e62c7-7a01fa0a@10.250.1.122
Supported: 100rel,timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM10.5
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=DESKTOP
Cisco-Guid: 0521391104-0000065536-0000009630-2046949898
Session-Expires:  3600
P-Asserted-Identity: "firstname surname" <sip:+XXXXXXXXXXX@10.250.1.122>
Remote-Party-ID: "firstname surname" <sip:+XXXXXXXXXXX@10.250.1.122>;party=calling;screen=yes;privacy=off
Contact: <sip:+XXXXXXXXXXX@10.250.1.122:5060;transport=tcp>;+u.sip!devicename.ccm.cisco.com="SEPAAAABBBBCCCC"
Max-Forwards: 69
Content-Type: application/sdp
Content-Length: 313
The Goal is to have the Privacy aktiv and I like to send the P-Asserted-Identity as follows:
P-Asserted-Identity: "Anonymous" <sip:anonymous@10.250.1.122>
At the SIP-Profil, I added the following line for Privacy but it doesn't work:
request INVITE sip-header P-Asserted-Identity add "Privacy: id"
Hope somebody can help me because I'm not very familiar with SIP profiles...
Thank you very much and I wish you a nice day.
Kind regards,
Pascal
5 Replies 5
Leszek Wojnarski
Pascal,
Try this one:
request INVITE sip-header Remote-Party-ID modify "(.*screen=)(yes;)(privacy=)(off)" "\1no;\3full"
request INVITE sip-header P-Asserted-Identity modify "P-Asserted-Identity: (.*)<sip:\+XXXXXXXXXXX@10.250.1.122>" "P-Asserted-Identity:\"Anonymous\" <sip:anonymous@10.250.1.122>"
Leszek
Hi Leszek
Thank you for your answer.
It works as I asked for but I guess I have another issue.
The ISP told me that I need the "Privacy: id" information in the SIP Request.
When I add it with the command
it will be added at the end of the Request. See example below.
Sent:
INVITE sip:XXXXXXXXX;phone-context=national@aaa.bbb.ccc.ddd SIP/2.0
Via: SIP/2.0/UDP 192.168.116.171:5060;branch=z9hG4bKF9E5C1B8B
From: <sip:anonymous@anonymous.invalid>;tag=83E8A618-129
To: <sip:XXXXXXXXX;phone-context=national@aaa.bbb.ccc.ddd>
Date: Mon, 20 Jun 2016 09:49:26 GMT
Call-ID: 1C33ADCD-360311E6-ADF78F2D-6EAAE112@192.168.116.171
Supported: 100rel,timer,resource-priority,replaces,histinfo,sdp-anat
Min-SE:  1800
Cisco-Guid: 1156947072-0000065536-0000009766-2046949898
User-Agent: Cisco-SIPGateway/IOS-15.5.3.S2
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1466416166
Contact: <sip:anonymous@192.168.116.171:5060>
History-Info: <sip:XXXXXXXXX;phone-context=national@aaa.bbb.ccc.ddd>;index=1
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 68
P-Asserted-Identity: "firstname surname" <sip:XXXXXXXXX;phonecontext=national@192.168.116.171>
Content-Disposition: session;handling=required
Content-Length: 256
Privacy: id
But my ISP expect this Information just before the "Session-Expires:  3600" line.
Is there a possibility to add this line at a specific location?
Thank you very much for your help.
Kind regards,
Pascal
Hi Pascal,
I don't know an easy was to put it in the specific place in the header. Maybe there is some method to do it but I'm not aware of any. You can try doing this:
request INVITE sip-header Session-Expires remove
request INVITE sip-header Privacy add "Privacy: id"
request INVITE sip-header Session-Expires add "Session-Expires: 1800"
What this will do is it will just remove previous Session-Expires header and put it at the end so "Privacy: id" will be before "Session-Expires: 1800" but they will be at the end of the header - I'm not sure if that will work for you service provider.
Max-Forwards: 70
Content-Length: 201
Privacy: id
Leszek
I know this has been asked a long time ago but maybe someone will find this useful.
If you have the topology like:
Phone----CUCM----CUBE----ITSP
then the following setting works just fine and achieving what is expected by telco:
On CUCM:
On route pattern:
Calling Line ID PresentationRequired Field to  Restricted
Calling Name PresentationRequired Field to Resticted
On SIP trunk check:
Remote-Party-Id
and
asserted-Type change to PAI
This way CUCM will send to CUBE:
P-Asserted-Identity: "Leszek Wojnarski" <sip:+888888888@10.10.10.10>
Privacy: id
And then on CUBE need to put on dial-peer to telco something like:
voice-class sip asserted-id pai
voice-class sip privacy-policy passthru
this is just to forward all the information related to PAI as it to ITSP.
Leszek
Very helpful, thank you for the post!
