MoH Cme router 2900
hi, could someone help me in a setup on MOH cme router 2900? using only sip protocol, i really don't know where to start! currently if I pause a phone call there is only silence and I would like to increase this works for both LAN and WAN calls. Thanks for your help
6 Replies 6
balaji.bandi
Been away from Voice configuration and CUCM, but i have this resource to share you :(Hope that help you)
https://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-express/91535-cme-sip-trunking-config.html
BB
On CME it straight forward. You need to download moh file from cisco
website (this is the simplest way, otherwise you can create your moh). Then
configure moh file under telephony-service or voice register global. Ensure
that the codec of the moh file is same as your call codec or g711ulaw if
it's played to pstn.
***** please remember to rate useful posts
do you know by chance the configuration to insert the moh in voice register global? in the internet I only found for Telefony-service
good evening i solved with the following configuration:
telephony-service
moh name file.wav
in lan works with both scc and sip, but the call from wan not works.
Are you using the same codec as the MOH file for WAN calls.? If you are
using g729 for example on wan calls and your moh file is g711, it won't
work.
There are ways to play moh from remote routers for wan calls. Just look it
up in Google and you will get many examples.
Translator
from what I understand one of the important things apart from the codec is the multicast configuration and codec g729 for wan:
multicast moh 239.1.1.1 port 16384 route (loopback ip) 192.168.30.1 (fastethernet ip)10.10.30.1
right?
