06-14-2022 08:28 AM
hi, could someone help me in a setup on MOH cme router 2900? using only sip protocol, i really don't know where to start! currently if I pause a phone call there is only silence and I would like to increase this works for both LAN and WAN calls. Thanks for your help
06-14-2022 09:16 AM
Been away from Voice configuration and CUCM, but i have this resource to share you :(Hope that help you)
06-14-2022 10:58 AM
06-14-2022 11:03 AM
do you know by chance the configuration to insert the moh in voice register global? in the internet I only found for Telefony-service
06-15-2022 09:19 AM
good evening i solved with the following configuration:
telephony-service
moh name file.wav
in lan works with both scc and sip, but the call from wan not works.
06-15-2022 11:15 AM
06-15-2022 12:08 PM
from what I understand one of the important things apart from the codec is the multicast configuration and codec g729 for wan:
multicast moh 239.1.1.1 port 16384 route (loopback ip) 192.168.30.1 (fastethernet ip)10.10.30.1
right?
