MOH not working CME 9.5 for PSTN
Have the following configuration:
Cisco 2921 Router with SRE-710 running CME 9.5
No calls are working when using the MOH file that we had been using on a 2821 with CME 8.6 with no problems
Have following commands in place
voice-port 0/0/0:23
 local-alerting
 timeouts interdigit 3
ccm-manager music-on-hold
telephony-service
moh "flash0:/butler5.au"
 multicast moh 239.1.1.1 port 16384
phones have multicast moh enabled and default code for ephone is g722-64
Is it possible this is getting tied up by my switches (Cisco 2960S)?
All calls are getting tone on hold.
15 Replies 15
The solution was that the G722-64 codec needed to be added to the dsp farm.  Make sure you shutdown the dspfarm first to add the codec.  Thank you again for all your help.
