MOH not working
adavila03
Hi everybody!!
I have an issue with MoH on CUCM System version: 7.1.2.30000-3 . When I place on hold a user calling from the PSTN or calling from a 1800 number I hear nothing I just get silence.
I have checked the following:
- Both MoH servers are registered to the subscriber
- moh audio file is uploaded on both servers and with the format .wav (ulaw,8000 hz, 64kbps, mono)
- MOH resources assigned to MRG
- MRGL assigned to MRG
- The MoH servers are enabled for unicast
- inside music on hold source file the check box play continuously (repeat) is checked
I have also reset and restarted de MoH servers and the IP voice media stream app .....
Also what I wonder is that when going to RTMT---> Performance---> Cisco MOH Device--> and whatever I choose I get " No cisco moh Device instances"
Do you have any ideas what could be happening???
thanks!
Can you disable CEF on the router as well
No IP CEF
It also could be this bug:
Unicast MoH fails if CEF is enabled Symptom:
Unicast MoH audio coming from CUCM will stop working after upgrade.
Conditions:
The symptom can be observed after upgrading a Cisco router to 15.0.1M4,
15.1(2)T1 or 151-3.T.
Workaround:
Option 1:
Disable CEF by adding the no ip cef command under global
configuration mode. Beware this can affect the router's performance and
functionality of CEF dependent configurations.
Option 2:
Enable Duplex Streaming in the CallManager service parameters. This does not
carry the same performance impact as disabling CEF on the voice gateway. There
is minimal signaling difference for this and no known negative side effects.
CSCtl21854 Bug Details
Tommer Catlin
Senior Collaboration Architect
ePlus Technology, inc.
1376 Borregas Ave.
Sunnyvale, CA 94089
p.408.220.1846 (Direct)
c. 415.845.9329
e.tcatlin@eplus.com
Cisco Designated VIP 2011
"A problem well stated is half solved."
Charles F. Kettering American engineer, inventor of the electric starter, 1876-1958
www.eplus.com<../../../../../../Documents%20and%20Settings/lmarcum/My%20Documents/emails/www.eplus.com>
The information contained in this electronic transmission and any attachments hereto may be considered proprietary and confidential. Unauthorized distribution of this material to anyone other than the addressed is prohibited. Any disclosure, distribution or use of this transmission for any reason other than their intended purpose is prohibited.
13 Replies 13
adavila03
I forgot , internal MOH(placing on hold between extensions) work just fine.
Does the gateway have the MRGL for MOH?
Hi Tommer,
How can I check that?
thanks.
Check your Device/Gateway (H323 or MGCP)
And see what is configured for Device Pool and Media Resources
I checked the Gateways which are  H323 device type. The device pool and Media Resources are the same as those configured under Device Pool --> X-Pool.
I attach the screens
Is this not working between sites? Remember, the Codecs selections must be set for the MOH server. For example, if the MOH server is in region/location A and the unicast stream has to go to region/location B and you have G729 configured between sites, you will need to ensure the Service Parameter is set correctly for this.
Also, in 8.5, Cisco decided that it would be “nice” to automatically turn this on for us. I have no idea why this is default. So even if you do not have G729 setup up between regions, it will still use G729 because of the service parameter.
Thanks for your assistance Tom!!
I checked what you said about the codecs. G711 and G729 are supported... and the issue I get it is when calling from the PSTN or from 1800 number to the site... there´s only one site.
attach the screen.
Tom, let me check again the region codec... and try... I´ll let you know...
thanks!
Hi Tommer, the codecs seem to be ok... also the thing is that when I place a call from pstn on-hold I get silence (no tone on-hold, no music on-hold)... what else could be wrong??
thanks!
Try putting "ccm-manager music-on-hold"
Thanks Tommer!
I tried it but same thing just silence... I really dont know what else to do , any other idea??
thanks again!
No IP CEF
Conditions:
Workaround:
Option 1:
Option 2:
Tommer Catlin
1376 Borregas Ave.
Sunnyvale, CA 94089
c. 415.845.9329
e.tcatlin@eplus.com
You´re the man Tommer!!
Thanks a lot and thanks for your time and support... I tried disabling CEF and it worked !!!  that´s why you are a VIP.
Cheers!!!
