MoH Not Works.
MehmetKaya
Hello MoH not works. I have collect logs from RTMP and faced the logs which was listed below. What is your advice about this problem.
When click hold(nothing heared). There is problem in ip phone to ip phone or pstn to ip phone.
The MOH files are not replicated and it doesn't matter that they register to the SUB1.
You need to upload the MOH file to ALL the MOH servers manually.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
7 Replies 7
MehmetKaya
Hello Log file;
23:24:16.874 HDR|07/04/2011 VoiceStrm,IST-IPTCM-1-Cluster,172.x.x.x,Error,8.5.1.11900-21
23:24:16.874 |   PITrace: *ERROR* [CRITIAL INFO]: platform install api isDeployedStandalone()= true
23:24:16.874 |   PITrace: *ERROR* [CRITIAL INFO]: platform install api prods[0]=CallManager
23:24:16.874 |   PITrace: *ERROR* [CRITIAL INFO]: Platform Box Configuration :0 (CCM:0,UNITY:1,CoRes:2,Unknown:3)
23:24:16.875 |   PITrace: *ERROR* Important info only, Category[DBMon]: productid_enable_flag=1, system_enable_flag=1
23:24:16.875 |   PITrace: *ERROR* Important info only, Category[Cisco Tomcat]: productid_enable_flag=1, system_enable_flag=1
23:24:16.875 |   PITrace: *ERROR* Important info only, Category[CAR]: productid_enable_flag=1, system_enable_flag=1
23:24:16.875 |   PITrace: *ERROR* Important info only, Category[CallManager]: productid_enable_flag=1, system_enable_flag=1
23:24:16.875 |   PITrace: *ERROR* Important info only, Category[CmiManager]: productid_enable_flag=1, system_enable_flag=1
23:24:16.875 |   PITrace: *ERROR* Important info only, Category[CtiManager]: productid_enable_flag=1, system_enable_flag=1
23:24:16.875 |   PITrace: *ERROR* Important info only, Category[Cisco TFTP]: productid_enable_flag=1, system_enable_flag=1
23:24:16.875 |   PITrace: *ERROR* Important info only, Category[CiscoAXLWebService]: productid_enable_flag=1, system_enable_flag=1
23:24:16.875 |   PITrace: *ERROR* Important info only, Category[Cisco Media Streaming App]: productid_enable_flag=1, system_enable_flag=1
23:24:16.875 |   PITrace: *ERROR* Important info only, Category[CiscoEM]: productid_enable_flag=1, system_enable_flag=1
23:24:16.875 |   PITrace: *ERROR* Important info only, Category[CiscoWebdialer]: productid_enable_flag=1, system_enable_flag=1
23:24:16.875 |   PITrace: *ERROR* Important info only, Category[CiscoIPMA]: productid_enable_flag=1, system_enable_flag=1
23:24:16.875 |   PITrace: *ERROR* Important info only, Category[RISSystemAccess]: productid_enable_flag=1, system_enable_flag=1
23:24:16.875 |   PITrace: *ERROR* [IMPORTANT INFO]  AppCrashCheckBase::AppCrashCheckBase() the RW_Process_Mutex is :/dev/shm/Category_CiscoMediaStreamingApp_Mutex_crash_checker
23:24:16.875 |   PITrace: *ERROR* [IMPORTANT INFO] AppCrashCheckBase::AppCrashCheckBase() acquire lock successed. : errno = 0; strerr = Success
23:24:16.875 |   PITrace: *ERROR* [IMPORTANT INFO]WriterSideCheck() open existing flag_check_mmf left from last run. : errno = 17; strerr = File exists
23:24:16.875 |   PITrace: *ERROR* [IMPORTANT INFO]ExAppCrashCheck::WriterSideCheck() create/open flag_check_mmf successed!!! : errno = 17; strerr = File exists
23:24:16.876 |   PITrace: *ERROR* {Debug infomation}: look from writer side, writer crashed last time : true
23:24:16.876 |   PITrace: *ERROR* CPICategory::loadXmlFile() Category: [Cisco Media Streaming App] xmlfile: [/usr/local/cm/conf/MediaAppPerfmon.xml]
23:24:16.888 |   PITrace: *ERROR* CPIClass::createMMF() MMF file : [/Category_CiscoMediaStreamingApp_PIClass_MEDIAAPP_GLOBAL_OBJECT_MDB] is started.(no error)
23:24:16.890 |   PITrace: *ERROR* ExObjectUpdateTracker::ExObjectUpdateTracker::_synchronizeMAP() m_nIndex
m_nRoundCount : 0  m_nTick: 0
23:24:16.890 |   PITrace: *ERROR* [SIGNIFICANT INFO]Category Name: Cisco Media Streaming App file: /usr/local/cm/conf/MediaAppPerfmon.xml enbled_flag: 1
23:24:16.890 |   PITrace: *ERROR* [SIGNIFICANT INFO]Add ITraceObj for Category Name: Cisco Media Streaming App, tid:27703l
23:24:16.890 |   PITrace: *ERROR* [SIGNIFICANT]::statsInit() enable_flag=1
00:05:22.959 HDR|07/05/2011 VoiceStrm,IPTCM-1-Cluster,172.x.x.x,Error,8.5.1.11900-21
00:05:22.959 |   [MTP][172.x.x.x]CTTCPSocket::HandleWrite *ERROR* EMPTY in TCP Write
00:05:22.963 |   [MTP][172.x.x.x.2]CTTCPSocket::HandleWrite *ERROR* EMPTY in TCP Write
03:18:59.348 |   [MTP][172.x.x.x]CTTCPSocket::HandleWrite *ERROR* EMPTY in TCP Write
03:18:59.359 |   [MTP][172.x.x.x]CTTCPSocket::HandleWrite *ERROR* EMPTY in TCP Write
Jaime Valencia
Have you started by reviewing the basics??
MOH server registered?
MOH in right codec?
MOH in devices MRGL?
Tried restarting IPVMS?
java
java
I want to explain the problem. I have 5 cucm server in cluster(pub-sub1-sub2-sub3-sub4). I used specific audio file (
Myfile 72sn.g729.wav). This file upload to pu(just pub. not uploaded to subs)b. But when I looked the MOH audio server all moh servers looks register to sub1. Maybe this explain my problem.
the some logs is below;
17:03:16.471 |   CMOHMgr::PlayStream (12,2005,0) /usr/local/cm/moh/Myfile 72sn.g729.wav failed to start
17:03:38.241 |   [ANN][x.x.x.x] DeviceMgr::recvStationStopMediaTransmissionMsg *ERROR* Conference ID is invalid!, passThruPartyID=101460594, callRef=102603193
17:03:41.865 |   [ANN][x.x.x.x] DeviceMgr::recvStationStopMediaTransmissionMsg *ERROR* Conference ID is invalid!, passThruPartyID=50534249, callRef=65959921
17:03:50.552 |   [ANN][x.x.x.x] DeviceMgr::recvStationStopMediaTransmissionMsg *ERROR* Conference ID is invalid!, passThruPartyID=50534292, callRef=65960048
17:03:54.056 |   [ANN][x.x.x.x] DeviceMgr::recvStationStopMediaTransmissionMsg *ERROR* Conference ID is invalid!, passThruPartyID=67734390, callRef=83576315
17:03:55.635 |   CIpPlayWav::StartPlaying.ST_PLAYING_FIRST (12,2001,0) *ERROR* Error openning WAV file (/usr/local/cm/moh/Myfile 72sn.g729.wav)
17:03:55.635 |-->CIpPlayWav::ErrorCleanup.ST_ERROR (12,2001,0)
17:03:55.635 |<--CIpPlayWav::ErrorCleanup.ST_ERROR (12,2001,0)
17:03:55.635 |   CMOHMgr::PlayStream (12,2001,0) /usr/local/cm/moh/Myfile 72sn.g729.wav failed to start
17:03:59.651 |   CIpPlayWav::StartPlaying.ST_PLAYING_FIRST (12,2001,0) *ERROR* Error openning WAV file (/usr/local/cm/moh/Myfile 72sn.g729.wav)
17:03:59.651 |-->CIpPlayWav::ErrorCleanup.ST_ERROR (12,2001,0)
17:03:59.651 |<--CIpPlayWav::ErrorCleanup.ST_ERROR (12,2001,0)
17:03:59.651 |   CMOHMgr::PlayStream (12,2001,0) /usr/local/cm/moh/Myfile72sn.g729.wav failed to start
17:04:12.706 |   CIpPlayWav::StartPlaying.ST_PLAYING_FIRST (12,2001,0) *ERROR* Error openning WAV file (/usr/local/cm/moh/Myfile 72sn.g729.wav)
17:04:12.706 |-->CIpPlayWav::ErrorCleanup.ST_ERROR (12,2001,0)
17:04:12.706 |<--CIpPlayWav::ErrorCleanup.ST_ERROR (12,2001,0)
-(dont understand what you mean)
-Yes all servers looks register to sub1
MOH in right codec?
-all supported codecs was selected.
-yes
-yes
java
java
Thanks. I will do what you said and reply to you.
I have uploded the file to all servers. And problem was solved.
Thanks.
As a result;
1 ) The moh file must uploaded to all servers.
2 ) Moh File type should be PCM 16bit mono( 16,32,48 KHz....I used: 32KHz)
