Multiple codecs
Bob Greer
Level 4
Level 4
Hi there,
Thanks for reading.
Shouldn't this command reflect what our provider has told us they are encoding with?  Shouldn't it be a couple entries long?  I THINK the list should include the encoding method our provider is sending calls via plus whatever encoding I need to have internally.  Am I on the right track?
dspfarm profile 1 conference
 description conference
 codec g711ulaw
 codec g711alaw
 codec g729ar8
 codec g729abr8
 codec g729r8
 codec g729br8
 maximum sessions 4
 associate application SCCP
Thanks!
Bob
Jaime Valencia
Yes, you only want the codecs that any of your devices or PSTN will use in the list.
java
if this helps, please rate
Jaime Valencia
java
