Multiple Corporate Directories in a single Cluster
cpi
Hi all,
I was curious if it is possible to have 2 separate Corporate Directories in a Single CM cluster. The users would be populate via Ldap entries to two separate Active Directories.
To give you some back ground, Our company is a subsidiary of a larger company. We are planning on adding the larger company to our cluster so they can have voip capabilities. Unfortunately we would like to keep the Corporate Directories separate.
Jaime Valencia
There is no version so i'll assume 7.1
Yes, you can create the directories you like as IP Phone Services.
We only provide the default corporate directory so you would need to develop your own directory script for the other LDAP.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Thanks for the quick reply,
I knew I forgot something, yes you are correct we are running Version 7.1
Makes sense creating them throug services, but is it safe to assume then that the Corporate will always be everyone in the user list in CM?
Java is correct.  Its only in the Corp directory is one listing.  And yes... it will show everyone in the EndUsers from CUCM.   If you are syncing LDAP, you will want to specify OUs you only want to show in the Corp Directory as well.  (gets a little tricky to exclude say for example AD service accounts, but there are work arounds, search netpros for this)
Thanks guys, answered my question perfectly
