Multiple LDAP integration
SAIFUDEEN C .K
Hi All,
If we have multiple LDAP accounts integrated with CUCM,is there any way to identify end users from which LDAP it is synchronized.
I mean, if one user called X which is from LDAP A and user X is from LDAP B like that.
CUCM Version 10.5
Domain name is same for all the LDAP integrations
Please help.
Jaime Valencia
No, if that is a possibility (duplicates/overlapping) you need to choose a userID value which is unique across all the LDAP agreements, if there is no value, then there is no way to have a predictable behavior in CUCM as UDS is a flat directory, anyone who is synced is in the same bucket and CUCM will try whatever user finds first.
java
if this helps, please rate
