Multiple Sip Normalization Script on Single File
KY_
Level 4
Level 4
I have a strange issue with sip normalization scrip. Customer want to change  diversion header using with sip normalization script but same time they want to use refer-passthrou scrip on sip trunk .
Is that possible to use following script single file ?
#### refer-passs###
    This script is used to trigger REFER pass through. The following conditions
    must be met in order for the REFER to be passed through:
a.  The inbound REFER must be in-dialog
b.  The Refer-To header must not contain an embedded Replaces header
c.  The other call leg must be a SIP Trunk
d.  The endpoint represented by the other call leg must support REFER
    If any of the conditions above are not met, the REFER is processed locally by
    Cisco Unified Communications Manager.
M={}
function M.inbound_REFER(msg)
    -- the message should have the following headers
    local to = msg:getHeader("To")
    local referto = msg:getHeader("Refer-To")
    local referredby = msg:getHeader("Referred-By")
    if not to or not referto
    then
        return
    end
    -- see if the Refer-To header contains an embedded Replaces header
    if referto:upper():find("REPLACES")
    then
        -- pass through is not supported if the Refer-To contains an embedded Replaces header
        return
    end
    -- see if the REFER is in-dialog
    if not to:upper():find("TAG=")
    then
        -- pass through is not supported for out-of-dialog REFER
        return
    end
    -- this is an in-dialog REFER without an embedded Replaces header; pass it through
    local pt = msg:getPassThrough()
    if pt
    then
        pt:addHeader("Refer-To", referto)
        if(referredby)
        then
            pt:addHeader("Referred-By", referredby)
        end
        trace.format("Passing through inbound REFER")
    end
end
return M
####diversion-header####
M = {}
local mask = scriptParameters.getValue("Diversion-Mask")
  function mask_diversion(msg)
     if mask
     then
        msg:applyNumberMask("Diversion", mask)
     end
end
function M.outbound_INVITE(msg)
mask_diversion(msg)
end
return M
0 Replies 0
