Multiple users with DN and one phone - interesting how to
p-blalock
All,
I have an interesting problem to solve, hope you can help.  I have multiple users requiring voicemail and the ability to be reached by their extension, but I have only one 7942 for use.  For example:
Phone line DN = 4000
Joe EN=4001
Jane DN=4023
Jim DN = 4042
Becky DN = 4051
Each has voicemail, but no phone.
I would like to be able to ring the phone extension, 4000, whenever someone dials any of the users extensions.  If busy or no answer, then forward to voicemail and use the user's extension as the forwarding number so that it goes directly to the user's inbox.  I have tried using a cti port to forward all to the phone's extension, 4000.  The forwarding works, but but it goes directly to the users voicemail without ringing the the phone.
I would like to accomplish the above without creating call handlers in Unity Connection.
If you know how to accomplish this, please let me know.
15 Replies 15
It is quite odd that this method worked while the EM profile approach did
not. Since, in most every way they are identical. Unless of course a
config step was missed when trying the variety of other approaches. Which
does seem possible.
Anyway, thanks for posting back to the forum with the solution.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
