06-02-2011 11:32 PM - edited 03-16-2019 05:16 AM
hy all,
Cisco generated an indication about the above vulnerability on June 01, 2011
they mention :
Cisco has released free software updates that address these vulnerabilities. There are no workarounds available to mitigate these vulnerabilities.
bug ID: CSCtf07426 & CSCtn65815
is there any information about severity and how this vulnerability can be exploit?
regards,
06-03-2011 06:45 AM
Edit: sorry, thought you were looking for the fix.
I reviewed the bug info from the links you posted and, not sure how much info you can see, but there's a small explanation of how the exploit could be used and the severity assigned to it.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
06-20-2011 10:53 PM
Yes little info provided about the bugs,
so i thought if someone has additional explanation or prevention to this vulnerability.
regards,
06-21-2011 03:15 PM
Upgrade the CUCM?
06-27-2011 11:27 PM
Upgrading is a big step, if case requiring upgrade is not severe it 's preferred to stay with the current running version,
Thanks anyway,
