Multiple Vulnerabilities in Cisco Unified IP Phones 7900 Series.
learnsec
hy all,
Cisco generated an indication about the above vulnerability on June 01, 2011
they mention :
Cisco has released free software updates that address these vulnerabilities. There are no workarounds available to mitigate these vulnerabilities.
bug ID:  CSCtf07426    &    CSCtn65815
is there any information about severity and how this vulnerability can be exploit?
regards,
Jaime Valencia
Edit: sorry, thought you were looking for the fix.
I reviewed the bug info from the links you posted and, not sure how much info you can see, but there's a small explanation of how the exploit could be used and the severity assigned to it.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Yes little info provided about the bugs,
so i thought if someone has additional explanation or prevention to this vulnerability.
regards,
Upgrade the CUCM?
Upgrading is a big step, if case requiring upgrade is not severe it 's preferred to stay with the current running version,
Thanks anyway,
