Music on Hold
p.horwood
Can anyone tell me where I can change the default audio source on ccm 5.1
allan.thomas
Level 8
Level 8
Open the CallManager service parameters and expand to list all advance parameters to be sure.
Locate the clusterwide parameters - (Service), here you can change the default audio source id for both Network and User.
Allan.
Pls rate helpful posts.
Jaime Valencia
you mean the actual audio file??? or where to change the selection??
the selection is an enterprise parameter, then a device pool setting, then device and then line. they take precedence in the reverse order i put them
java
if this helps, please rate
java
Thanks to all
Hi Paul, we're here to help if we can, hope we were able to provide you with the help that you needed?
All the best.
Allan.
Please rate helpful posts. Thanks.
