MVA calling name problem , on CUCM v7?.
jones.jack
Hello
Anyone , have a solution for MVA  calling name problem for CUCM v7?. The call is ok , but the calling name not appears?. Any ideas.
3 Accepted Solutions
Nadeem Ahmed
Did you configure the name while associating directory number in Remote destination profile.
Once you associate the DN ie user for MVA . You must have missed the name ie display (internal caller)
Let me know if have any queries
Nadeem
Br, Nadeem Please rate all useful post.
    go to RDP>click DN and give the caller name as in the below field,
Please rate if this helps
islam.kamal
Level 10
Level 10
On the remote destination profile , after you configure the line with same DN which will be used for RDP. Please as Mr/ Kaja mentioned , you have to go down  and type the calling name which you need to appear . This wont do automatically when you use a same existing DN , you have to type the Calling name. You have to see the calling name when the call connected or on missed calls.
Thank you
please rate all userful information
5 Replies 5
Nadeem Ahmed
Nadeem
it nevers work with me. I think it is a bug in this version
Anas
please rate all the helpful posts
islam.kamal
Level 10
Level 10
Thank you
Many thanks for help.
