IP Telephony and Phones
Labels
I have a PBX (E1) that doesn't provide me with CDR functionality. BRI data calls into the the PBX out on the E1.Since I all ready have CUCM with and MGCP gateway connected to E1, I was wondering if I could connect the PBX to my MGCP and have calls th...
Hi,My Customer developed the logo for any IP Phones (79xx), and would like know is possible apply this configuration in the first time only about specific floor. (For example 4 rd floor)                   |_______________ | n xx floor|_______________...
Hi,I just want to know that if i will change my cisco ip phone with another cisco ip phone (same model or different model) is it possible to move all the missed, received and placed calls data onto the new phone?These phones would be registered to Ci...
techguy by Level 4
  • 680 Views
  • 3 replies
Hello please i need a solution that can work with cisco CME to Accounting, Billing, record and when calls comes in to the reception desk, it should ogs in the caller name or company automatically.please which software could do this above solution.its...
rammany19 by Level 1
  • 777 Views
  • 2 replies
Resolved! CUEAC and CIPC
Hi All,Good day! May we know if possible to use CIPC in Attendant Console?Here is our scenario: We installed IP phone and Softphone for AC. When there is incoming calls we double click the callsthat appeared on the AC window. We want to answer this o...
hi,IS it possible to change any parameter lets say CSS or Route Partition or enable/ disable any feature for all the range of specific extension.For example if i want to change the CSS of extension 1200 to 1250, will have to do it one by one ? Thanks...
techguy by Level 4
  • 661 Views
  • 3 replies
