03-27-2013 01:54 PM - edited 03-16-2019 04:29 PM
Hello All...
I have the following setup, I am not sure if the will be suitable to enable the MVA feature !
I have CUCM cluster, but his CUCM cluster has no voice GW or DID .. but this CUCM cluster has Inter-cluster trunk to another CUCM cluster which has the DID numbers ?
Can I configure the MVA for this setup..
Appreciate your input.
Solved! Go to Solution.
04-06-2013 01:10 PM
this the problem , if you have any fxo or any PSTN connection you can finish the task. MGCP not support MVA , this is the problem.
Thank you
please rate if this will help.
03-27-2013 01:59 PM
You can add the gateway of the remote cluster to your call manager and configure the MVA
Anas
please rate if it is helpful
04-06-2013
12:37 PM
- last edited on
03-09-2022
11:27 PM
by
smallbusiness
The Gateway in the other cluster is MGCP , and all the PRI are backholded to the ccm
The requirements for the MVA, is h323.
04-06-2013 12:55 PM
It is ok to run both MGCP and H323 at the same IOS ,as long as the dial peer isn't a pots dial peer pointing to the PRI it will run independently of your MGCP.
Thank you
Please rate if this will help
04-06-2013 01:03 PM
But as I mentioned above, all PRI are binded to the CCM!
So how to invok the VXML application while all the DID numbers belong to the MGCP ..
04-06-2013 01:10 PM
Thank you
04-06-2013 01:16 PM
Ahmad,
you can do MVA even if you have MGCP gateway..You just need to be clever with it...please read this thread
https://supportforums.cisco.com/thread/2005673
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
04-06-2013 01:28 PM
Firstly many thanks for aokanlawon .That is completely true , but kindly be informed if you ask Cisco about that it will confirm that only H323 supported . I opened a case with Cisco before regarding to this issue.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_0_1/ccmfeat/fsmobmgr.html#wp1144501
Thank you
04-06-2013 01:51 PM
The most example which you can use in your case :
Here is what I think the call flow looks like (5000 is MVA number):
PTSN –> MGCP GW –> UCM (simple enough here) then
UCM with RP to MVA number — routes call to 5000-> H.323 GW then
H.323 — dial-peer to 5010 to UCM –> UCM then
Configuration
The H.232 config is here:
! this translation fixes the caller id back the the pstn number. The hairpinning overwrites the CLID.
voice translation-rule 5002
rule 1 /^5002$/ /2123942123/
voice translation-profile MVA
translate calling 5002
application
service CCM http://10.10.210.10:8080/ccmivr/pages/IVRMainpage.vxml
dial-peer voice 50100 voip
translation-profile incoming MVA
service ccm
destination-pattern 5000
session target ipv4:10.10.210.10
incoming called-number 5000
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
Thank you
