My remote SIP phone don't receive calls
wrobynson
Hi everyone.
I have a problem: my SIP phone (3rd party) coudn't receive calls. It can make calls, bat I can't hear the other side.
voice register dn  6
 number 7275
 allow watch
 name 7275
 label TF4 7275
 mwi
voice register pool  69
 busy-trigger-per-button 2
 id mac 000B.000B.000B
 number 1 dn 6
 dtmf-relay rtp-nte sip-notify
 username 7275 password 0069x0000009999
 description GXP 2000 SJC
 codec g711ulaw
CME_3945#sh voice register pool  69
 Pool Tag 69
Config:
  Mac address is 000B.000B.000B
  Number list 1 : DN 6
  Proxy Ip address is 0.0.0.0
  Current Phone load version is Grandstream GXP2000 1.2.5.3
  Class of Restriction List Tag: default
    Incoming corlist name is PERFIL-5
  DTMF Relay is enabled, rtp-nte, sip-notify
  Call Waiting is enabled
  DnD is disabled
  Video is disabled
  Camera is disabled
  Busy trigger per button value is 2
  Description is GXP 2000 SJC
  keep-conference is enabled
  registration expires timer max is 3600 and min is 60
  Lpcor Type is local
  Lpcor Incoming is PSTNTrunk
  Lpcor Outgoing is
  Transport type is udp
  service-control mechanism is not supported
  registration Call ID is 1425b1bdf56d7bcf@10.132.8.45
  Registration method: per line
  Privacy feature is not configured.
  Privacy button is disabled
  active primary line is: 7275
  contact IP address: 10.132.8.100 port 5060
  conference admin: no
  conference add mode: all
  conference drop mode: never
  paging-dn: config 0 [multicast]  effective 0 [multicast]
Dialpeers created:
Dial-peers for Pool 69:
dial-peer voice 40080 voip
 corlist incoming PERFIL-5
 destination-pattern 7275$
 session target ipv4:10.132.8.100:5060
 session protocol sipv2
 codec  g711ulaw bytes 160
  after-hours-exempt   FALSE
The phone IP address is 10.132.8.45. But the created dial-peer to this extension (7275) point to 10.132.8.100
CME_3945#sh dial-peer voice sum | i 7275
40080  voip  up   up             7275$              0  syst ipv4:10.132.8.100:50
So, the calls to extension 7275 are forward to wrong IP 10.132.8.100. I can confirm this by debugging ip packet.
Can somebody help me, please?
15 Replies 15
Glad that you could solve the issue.
Response Signature
