05-17-2017 07:21 AM - edited 03-17-2019 10:21 AM
HI,
I have CUCM 10.5 on my network. In IP Phone corporate directory when user search output, the output shows "Last name, First Name".
Can it be changed to "First name, Last Name"? Also can the search options be modified to contain other search parameters like Alias, contains and not just Begin with.
Solved! Go to Solution.
05-17-2017 07:28 AM
Not possible with existing architecture, see below
https://supportforums.cisco.com/discussion/11815911/corporate-directory-name-display-order
(Rate if it helps)
JB
05-17-2017 07:30 AM
The corporate directory is provided as is, if you want to add fields to search, show more info, etc. You need to build your own directory, or buy a 3rd party option.
05-17-2017 07:28 AM
(Rate if it helps)
JB
05-17-2017 07:40 AM
Thanks, very detailed discussion link.
05-17-2017 07:30 AM
05-17-2017 07:39 AM
Thanks i appreciate your quick response. I will stick to the running Directory so i don't complicate my architecture.
05-17-2017 07:54 AM
Happy to help
Just a side note, It also requires Developer contact for troubleshooting as TAC would only support CUCM Corporate Director, if you switch to 3rd party XML directory solution it is not supported by TAC.
(Rate if it helps)
JB
05-17-2017 07:39 AM
Enhancement that were open for the same.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuq30437/?reffering_site=dumpcr
(Rate if it helps)
JB
